Old 12-16-2007, 07:11 PM   #1
g6civcx
g6civcx's Avatar
Recommend me brake calipers
I'm looking for suggestions for calipers. The only constraints is they have to be OEM. They can be from any car, but it has to be OEM. I would like to also exclude exotic marques like Porsche, Ferrari, etc., namely due to price and availability.
Right now my top choice is Evo 8-9 Brembos or Z33 Track Brembos.
Any suggestions?
Old 12-16-2007, 07:18 PM   #2
Quigs
Quigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond reputeQuigs has a reputation beyond repute
Can I ask why you wanna stay with OEM options?
Quigs is offline   Reply With Quote
Old 12-16-2007, 07:22 PM   #3
OptionZero
OptionZero's Avatar
z33 track brembos are heavy as fuck
wilwood is probably the best bang for the buck, but for whatever reason u want OEM...
is there any reason why aluminum 30mm 300zx calipers aren't good enough...?
Old 12-16-2007, 07:23 PM   #4
Dousan_PG
Dousan_PG's Avatar
wilwood for sure
cost
availability
and quality
Aaron
Pink GodziRa
Old 12-16-2007, 07:24 PM   #5
Slidin240Wayz
Slidin240Wayz's Avatar
R32 GTR setup from courtesy.
Old 12-16-2007, 07:30 PM   #6
g6civcx
g6civcx's Avatar
This is what everybody says, but the brakes is the one part I don't mind unsprung weight on.
I prefer bigger for roadracing, but Z32 calipers are actually my 3rd choice. I'm carrying more front end weight than an average S13 so every bit helps.
OEM = discount on replacement parts. When you go through a set of pads every other week, it adds up.
Old 12-16-2007, 07:41 PM   #7
sijia10358
sijia10358's Avatar
sijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfectionsijia10358 is close to perfection
just get the F430 yellow brembo brakes with the carbon rotors lol j/k....wilwoods are good but..$$$
[email protected]
TIRE CENTRAL "DONALD" 626-227-0150
DRIFT SPEED "QUOC" 562-342-9000
sijia10358 is offline   Reply With Quote
Old 12-16-2007, 08:41 PM   #8
yokotas13
yokotas13's Avatar
Listen, all i have to say
is my R32 GTR, with drilled rotors, stinless lines, and stock BMC, with endless CCR and CCX (i have both) stops my 3800 lbs wagon, in the mountains, for liek 30 minutes at a time
OEM is best IMO.
yokotas13 is offline   Reply With Quote
Old 12-16-2007, 09:46 PM   #9
g6civcx
g6civcx's Avatar
OEM is best IMO.
I have Z32 1 1/16" master, full stainless lines from master to caliper, 180SX front and stock rear.
I can't do drilled discs for my application because repeated triple digit stops will crack it even factory Brembo drilled discs.
I think right now Z32 aluminium is my top choice unless I can source Brembo calipers at a cheaper price. I can get the Z32 for about $300US for the front pair.
Old 12-16-2007, 09:49 PM   #10
xcusememisswyn
xcusememisswyn's Avatar
xcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfectionxcusememisswyn is close to perfection
Z32's with the proper BMC setup rocks.
On street tires at full weight, they never let me down.
I imagine with a race setup, at the cost, they would be more than sufficient.
You gonna drive it, or buy it a dress?
xcusememisswyn is offline   Reply With Quote
Old 12-16-2007, 10:22 PM   #11
98koukile
98koukile's Avatar
98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough98koukile will become famous soon enough
Z06 6 piston calipers are like $200 each new IIRC. Just need to find a 14" rotor I think
Just talking about cars, one at a time
Horsepower sells cars torque wins races -Shelby
98koukile is offline   Reply With Quote
Old 12-16-2007, 10:25 PM   #12
xcusememisswyn
200 each for the calipers?!?!
No way. Not a chance.
Maybe 2000?!
Edit:
These are dirt cheap actually.
But the 6-Pistons, not so much.
Although the 6-pistons at that price would still be a badass setup.
Old 12-16-2007, 10:33 PM   #13
ROIDMONKEY
ROIDMONKEY's Avatar
ROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfectionROIDMONKEY is close to perfection
After a few problems i finally finished my brake setup. i have Z32 calipers(aluminum) with PBM 13" rotors at front using HAWK PADS , for the rear im using also a Z32 calipers with (Z32) Project MU rotors using SPL lines all around . fucking amazing how this thing brake no joke
totally went over my budget with this setup . i spent way more that what i spected
ROIDMONKEY is offline   Reply With Quote
Old 12-16-2007, 10:33 PM   #14
ROIDMONKEY
ROIDMONKEY's Avatar
Maybe 2000?!
Edit:
plus u need special brackets for the calipers
Old 12-16-2007, 10:48 PM   #15
g6civcx
g6civcx's Avatar
Fabrication is no problem. I can get any caliper to fit.
Z06 calipers? Maybe I'll look into that.
Old 12-16-2007, 11:29 PM   #16
cdlong
Maybe 2000?!
no, he's right, like $200 each. i saw it too on a corvette forum. maybe even the one you posted. there was a huge brake thread here a while back and i think they were in it.
this is what i was talking about. starts on page 7 i think.
http://www.zilvia.net/f/showthread.p...ighlight=brake
this is where the info came from. don't know if the prices are still valid.
http://forums.corvetteforum.com/show...light=calipers
cdlong is offline   Reply With Quote
Old 12-16-2007, 11:32 PM   #17
98koukile
98koukile's Avatar
I found the older Z06 calipers for $110 brand new but its only a 2 piston caliper like the Q45
Old 12-16-2007, 11:36 PM   #18
xcusememisswyn
Click the links in my post, they are just the underlined words.
The 2-piston ones are dirt cheap, the 6-pistons are over 2K
Old 12-16-2007, 11:57 PM   #19
yokotas13
yokotas13's Avatar
My Cedric has Blanks with GTRs (well HCR32 right now i took the GTR off to rebuild) and from triple digit to slower, and hten back i never had a problem with endless pads.
i also added stainless lines front and rear, and Trust brake fluid.
Old 12-17-2007, 01:12 AM   #20
cdlong
thanks, i know how to use the internet. he said the calipers cost $200 each and you implied that they cost $2k each. the kit costs a lot, but in the link i posted it was $1k less. even still, for a system of that caliber $2400 for all four wheels is cheap.
also, the sliders you posted are far from complete. you still need pads, rotors, and brackets.
Old 12-17-2007, 01:26 AM   #21
Anto
Anto's Avatar
Anto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfectionAnto is close to perfection
What about STi Brembos?
Evo/STi calipers use a 32mm rotor, z32 is 30mm I think z33 brembos are 30mm thick too.
Just be careful with the evo 8 brown-bo's. the first gen calipers always fade and peel.
Anto is offline   Reply With Quote
Old 12-17-2007, 08:41 AM   #22
xcusememisswyn
thanks, i know how to use the internet. he said the calipers cost $200 each and you implied that they cost $2k each(sarcasm fixed with edit). the kit costs a lot, but in the link i posted it was $1k less(still not $400). even still, for a system of that caliber $2400 for all four wheels is cheap(duh. read edit).
also, the sliders you posted are far from complete. you still need pads, rotors, and brackets.(but thats still cheap for four calipers!!)
Thats what my edit said.
You may know the internet, but you fail at sarcasm and reading comprehension.
R32 GTR is a brembo setup right? Is it really that much better than Z32s?
Doin brakes over the winterrrrr
Old 12-17-2007, 08:52 AM   #23
Slidin240Wayz
R32 GTR is a Sumitomo setup.
R32 GTR VSpec (II) is a Brembo setup.
Old 12-17-2007, 08:56 AM   #24
ROIDMONKEY
ROIDMONKEY's Avatar
i think there is a brembo setup and a none brembo for the R32. dont think is a big of a diferent tho
Old 12-17-2007, 08:57 AM   #25
ROIDMONKEY
ROIDMONKEY's Avatar
U the man,,,,,,,,,,,,,,,,,
Old 12-17-2007, 08:57 AM   #26
TheWolf
TheWolf's Avatar
TheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant futureTheWolf has a brilliant future
the porterfield pads for my alcons are $75 a caliper last multiple track day events. I've got 4 on them right now and plenty of pad life. OEM pads just won't hang.
Eye on the Prize
TheWolf is offline   Reply With Quote
Old 12-17-2007, 09:10 AM   #27
g6civcx
g6civcx's Avatar
I don't mind going with aftermarket pads so long as they fit OEM calipers. At least in a pinch I can get OEM pads easily without having to wait for specialty pads to arrive.
I actually like my setup now. I run Hawk pads and Brembo discs, but I know that if I need replacement parts and can't wait for shipping, I can always run auto parts store Maxima pads and Altima discs.
I only want to upgrade the calipers because I'm going 5 lug.
Old 12-17-2007, 09:16 AM   #28
xcusememisswyn
Is this what I see on the IFXX thread?
Old 12-17-2007, 12:23 PM   #29
pbcstylez
pbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfectionpbcstylez is close to perfection
Send a message via AIM to pbcstylez
What about porsche 993 brakes?
http://www.ecstuning.com/stage/edpd/...CS%20Stage%203
parking lot pimpin...
Seller Feedback here:
http://www.zilvia.net/f/showthread.p...ight=pbcstylez
pbcstylez is offline   Reply With Quote
Old 12-17-2007, 12:40 PM   #30
Full-Lock
Full-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfection
Send a message via AIM to Full-Lock
there was a dude i saw that was rolling aston martin calipers on his s14. looked awesome. they were HUGE. ill look for the pic. but if anyone has it..post it up!!
Full-Lock is offline   Reply With Quote
