Old 01-10-2008, 01:25 AM   #1
kamechikara
kamechikara is an unknown quantity at this point
sr20 build words of wisdom??
So I need to replace my turbo and tranny on my sr so i am going to do a build. looking for 300-350 to the wheels. any advise on parts to buy or what to build to make that power? Here is the specs of the car:
thanks!
Engine:
Redtop sr20det w/30,000mi.(roughly)
New Headgasket, front and rear main seals, intake, ehaust, and valve cover gaskets
Spitfire Triple Platinum Spark Plugs
T28 turbo from an s14 blacktop
hks divorced chamber turbo elbow
3" downpipe and exhuast all the way back with Megan Racing Test Pipe
Stainless header with support bracket (SS Autochrome)
Custom turbo charge pipe
HKS style BOV
Greddy VSPL Intercooler Kit
Koyo Aluminum Radiator
New Radiator Hoses
New Water Pump
New oil pan,
300zx fuel filter
SARD 550cc fuel injectors
Universal O2 sensor
New Optima Red Top Battery re-located to the back (gel cell battery can be mounted in any direction and wont spill)
Walbro Fuel Pump
New cross drilled Magnum rotors
Axis Ceramic brake pads
Phase 2 Motor sports rocker arm stoppers
Phase 2 sub-frame spacers
Suspension:
Suspension Techniques front and rear sway bars
energy suspension bushing front and back also
Tanabe GF210 Springs
KYB Gr-2 Struts
Front and rear megan racing strut tower bars
Drivetrain:
KA24DE transmission with 60K miles still has original SR bell housing
Stock 91 240sx open differential with Phantom Grip LSD installed
Pilot Motor sports short shifter.
Electronics:
Pioneer head unit
10 inch sub
Amp in trunk
Apexi S-afc air fuel controller
Apexi AVC-R boost controller
Apexi turbo timer
Boost gauge
Interior:
Sparco sprint seat (passenger)
Sparco circuit seat (driver)
Custom 6 point roll cage
Sparco 3inch 4 point harnesses
kamechikara is offline   Reply With Quote
Old 01-10-2008, 04:05 AM   #2
GSXRJJordan
GSXRJJordan's Avatar
You'll need a bit bigger turbo to hit those numbers... even with cams, T28s are hard pressed to get 300whp. You could try cams + GT28RS, or just go with a GT2871 .64 and forget about the cams.
If you don't already have wheels/tires, I'd plan on doing that as well, and Z32 brakes. Coilovers wouldn't be a bad call either.
Old 01-10-2008, 07:58 AM   #3
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
You might try to find a better manifold than an SS Autochrome. They're common but still not the greatest build quality; you might end up replacing it, or repairing it, sooner than you think. Decent manifolds (i.e. not Ebay/SSAC/Megan) are usually pricey, but you could probably look around and find some sort of deal.
I'd advise against an HKS "style" BOV, you can find a BOV from a legit company for a decent price.
You shouldn't need a new oil pan, unless the factory one is dented. Unless you meant a larger aftermarket pan, which is always a good idea for an SR.
Universal O2 sensor, eh, why not get an OEM one? =)
Cross-drilled rotors won't have any benefit for you, unless you'll be tracking the car and heating up the brakes a lot. If it's just a street car, I'd say just go with quality blank rotors.
I'd advise you to spend an extra $150-200 and get KYB AGX shocks. They're adjustable and more suited to sport springs; the GR-2s won't last as long on a lowered car.
Also, Taka turbo lines (or Circuit Sports, or whatever other brand makes braided stainless lines) will make your life a LOT easier if you ever remove/install the turbo, especially if the engine's in the car. You don't want to have to deal with the stock lines.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 01-10-2008, 08:00 AM   #4
Dousan_PG
Dousan_PG's Avatar
2871R !!!!!
.64
cams
z32 mafs
real tune
good boost controller
dooone
Aaron
Pink GodziRa
Old 01-10-2008, 08:10 AM   #5
smelly240
smelly240's Avatar
^^stuff that makes sure the cams dont asploderate stuff, are good too
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope
smelly240 is offline   Reply With Quote
Old 01-10-2008, 08:13 AM   #6
Slidin240Wayz
Slidin240Wayz's Avatar
Sell it now.
Save up for a house.
Money well spent.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 01-10-2008, 10:11 AM   #7
kamechikara
like what?
thats what im looking for. what should i do to the block to make sure i dont blow it with more power and boost?
Old 01-10-2008, 10:32 AM   #8
burnsauto
burnsauto's Avatar
some ppl throw in a metal head gasket for good measure, but it all depends on how much boost your running..for 300-350 hp..the stock one should hold up.
if you plan on upgrading the cams, pay attention to not just the duration, but also the lift...if its more on the aggressive side, they may advise you to swap out the valve springs for a little stiffer ones.
