Old 01-14-2008, 06:13 PM   #1
powersteeringless180sx
powersteeringless180sx's Avatar
powersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfectionpowersteeringless180sx is close to perfection
Wheel Well Clearance
at full lock to the left my drivers side wheel is rubbing against harness boot and part of the wheel well. i have 17x9 w/ 215 45's on my front wheels. i was thinking about just taking a hammer to it but i wanted to see what other people did 1st.
here's a pic of how it looks.
how low i'm at in the front
powersteeringless180sx is offline   Reply With Quote
Old 01-14-2008, 06:15 PM   #2
ThatGuy
Admin Asshole
ThatGuy's Avatar
Relocating the harness is the "RIGHT" way to go about it.
Grab a hammer and beat the hell of it works for the metal. The harness needs more finesse then that.
Old 01-14-2008, 06:16 PM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
This topic was discussed before.
Relocate or protect with sheetmetal/aluminum.
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 01-14-2008, 06:21 PM   #4
S14DB
AFC #1
S14DB's Avatar
How much caster you running?
Old 01-14-2008, 06:24 PM   #5
stock as far as i know
Old 01-14-2008, 06:26 PM   #6
ALEXTHESUS*PECT
ALEXTHESUS*PECT's Avatar
the hammer is one option, also changing to 215/35 tires will help some too.
TEAM SUS*PECT
Old 01-14-2008, 06:28 PM   #7
ThatGuy
Admin Asshole
ThatGuy's Avatar
BTW, if you aren't gonna take car of those wheels, give them to me.
Are you using pure dust for brake pads?
Old 01-14-2008, 06:31 PM   #8
BustedS13
BustedS13's Avatar
i lol'd. msglength
Old 01-14-2008, 06:31 PM   #9
jspaeth
jspaeth's Avatar
and will throw off your height like woah lol
Daily driven
Old 01-14-2008, 06:32 PM   #10
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
take a day off and do the right thing... just relocate the harness, it may be more work but at least youll have a clear mind that your not rubbing against it and not damaging anything...
bejota180sx is offline   Reply With Quote
Old 01-14-2008, 06:40 PM   #11
S14DB
AFC #1
S14DB's Avatar
so ,you droped it with stock TC rods? You caster prolly went down. Crank it upto 7* and it shouldn't rub in th back.
Old 01-14-2008, 06:42 PM   #12
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
While your doing all that relocating make sure you look around at the other areas and see if theres any rubbing anywhere else. If so then just pound the shit out of that area.
GL
Old 01-14-2008, 06:52 PM   #13
lol sorry the car needs a wash..
i didn't think i needed to relocate cuz the only part that's rubbing is the rubber boot and the metal around it.
Old 01-14-2008, 07:07 PM   #14
gprb25
gprb25's Avatar
gprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of lightgprb25 is a glorious beacon of light
You are going to have to move the harness sometime anyway (ie: different alignment, going lower, new wheels)
Enjuku sells something called AP Boss LAP Fender Harness Protector for 240sx...
I say check that out, and if you're creative...you can come up with something and make your own.
gprb25 is offline   Reply With Quote
Old 01-14-2008, 07:08 PM   #15
A Spec Products
A Spec Products's Avatar
I think you meant 215/40/17
Mainly caster and hammering / ziptie harness out of the way should work
You don't need to physically relocate the whole thing to engine bay
Just get slack from the front side in engine bay and the harness from the harness boot should have more slack to pull backwards out of the way
A SPEC PRODUCTS CORP
Old 01-14-2008, 07:20 PM   #16
thanks logan. caster and hammering was what i was thinking too.
Old 01-14-2008, 07:34 PM   #17
Sliders562
Sliders562's Avatar
Sliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfectionSliders562 is close to perfection
Send a message via AIM to Sliders562 Send a message via Yahoo to Sliders562
i remember going thru tat, my harness unclipped in my driver fender well and the tires roasted the wires and my car went into a hault. ended up pushing the car to the side. EK! got a new harness and relocated it, but not everything is functional correctly its all good. ghetto wind wipers ftw.
Sliders562 is offline   Reply With Quote
Old 01-14-2008, 07:38 PM   #18
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
thats what i did.
CoasTek240 is offline   Reply With Quote
Old 01-14-2008, 07:54 PM   #19
95KA-Turbo
95KA-Turbo's Avatar
95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of95KA-Turbo has much to be proud of
Is there a way to relocate it into the frame the fender covers? I want to move mine but don't want to move it INTO the engine bay...mainly because it'll look like crap. I don't have my alignment yet so I'm just going to change the caster and use a hammer at first, but if that doesn't work I want a good plan...other then running wires all over the place, I'd like them to be as hidden as possible (I'm thinking I don't get that option).
95KA-Turbo is offline   Reply With Quote
Old 01-14-2008, 07:57 PM   #20
lflkajfj12123
hammer them shits
ziptie the harness out of the way
DONE
Old 01-14-2008, 09:51 PM   #21
Rod
Rod's Avatar
Rod will become famous soon enoughRod will become famous soon enoughRod will become famous soon enoughRod will become famous soon enough
theres enough play that you can pull and route the harness along-side the frame (in between Fender and Frame). I then ziptied it and never again had a rubbing problem. I did this when I had the fenders out the car, so don't know how difficult it would be with the fenders on there. Here's how low the car is currently:
Rod is offline   Reply With Quote
Old 01-14-2008, 10:22 PM   #22
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
usually the tire rubs the top of the harness. It looks as if you are rubbing more towards the rear. I would think something is bent like your control arms.
Jung918 is offline   Reply With Quote
Old 01-14-2008, 10:33 PM   #23
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
You guys all fail.
Put 8* of caster up front and kiss your harness rubbing problems goodbye.
I had the same problem on my car in the front too.
DON'T HAMMER BACK THERE.
Not necessary.
Old 01-14-2008, 11:12 PM   #24
Bushido
Bushido's Avatar
8 easy steps to solve wheel well clearance problems:
1 put your wheels on.
2 drive, hard.
3 take wheels off.
4 note where there is rubbing.
5 smash it in with BFH.
6 spray paint wheel well.
7 drive, hard.
8 remove wheel and inspect for rubbing again.
repeat if necessary.
not rocket science.
but yeah, in your case, the reason why you're rubbing the harness is because your caster needs adjustment, and 215/45's are tall.
run a lower profile next time and also take an hour to ziptie your harness up, then you can lower your car down to the es100 letters.
Bronze wheels look better dirty.
Old 01-14-2008, 11:40 PM   #25
Flybert
More caster. Done.
Old 01-14-2008, 11:54 PM   #26
hitman
hitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfectionhitman is close to perfection
Send a message via AIM to hitman
hammer until your fingers are bloody
driftparty.com
hitman is offline   Reply With Quote
Old 01-14-2008, 11:56 PM   #27
!Zar!
!Zar!'s Avatar
Hammer till you see daylight.
Old 01-14-2008, 11:57 PM   #28
Dousan_PG
Dousan_PG's Avatar
hammer hammer hammer
some caster
215/40s
lower car more
you'll be set
Aaron
Pink GodziRa
Old 01-15-2008, 12:12 AM   #29
okay got it caster and hammer. just wanted to make sure i was gonna do the right thing.
Old 01-15-2008, 05:39 AM   #30
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
I made a small steel bracket to hold mine out of the way, works great and only took about 10 minutes.
khilgers is offline   Reply With Quote
