Old 01-29-2008, 01:11 PM   #1
TOMKAIRA93
TOMKAIRA93 is making a name for him/her selfTOMKAIRA93 is making a name for him/her self
WRX engine under my 240sx hood
yeah, that's how my car sounds. I've posted before things that I've gone through with my car and after all has been corrected (fuel pump hose, plugs, boost leaks, etc...) now my car sounds like a WRX.
Its not the coil packs, or MAF. The car does not feel too underpowered, but its definetely not running right and it idles fine.
If you've gone through this, please post your experience and corrected action. I would appreciate any help/ suggestions.
OH...car specs: Stock SR red top with FMIC
TOMKAIRA93 is offline   Reply With Quote
Old 01-29-2008, 01:13 PM   #2
Slidin240Wayz
Slidin240Wayz's Avatar
Dead coil pack.
I have extra if you want to buy a set or just one.
Edit...woops.
My bad...check the FSM.
How did you check the coil packs?
Burnt ECU?
Carlos
Slidin240Wayz is offline   Reply With Quote
Old 01-29-2008, 01:14 PM   #3
johngriff
johngriff's Avatar
exhaust gasket(s) blown out, check for leaks around the turbo.
[email protected]
Old 01-29-2008, 01:19 PM   #4
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
Timing, plugs, coilpacks, injectors, or gasket leak.
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 01-29-2008, 01:20 PM   #5
!Zar!
!Zar!'s Avatar
One of your coilpacks or injectors.
Make your car sound like a suby but you don't loose too much power.
Old 01-29-2008, 01:21 PM   #6
MomentumGT
MomentumGT's Avatar
MomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to beholdMomentumGT is a splendid one to behold
I've dealt with a similar problem on my sr a couple of times. 1)there was water/moisture in the spark plug wells 2)spark plug electrod melted off 3)bad coil pack.
-Jon
momentumgt.com - "building blocks of speed"
MomentumGT is offline   Reply With Quote
Old 01-29-2008, 01:23 PM   #7
iRONDONkey
iRONDONkey is on a distinguished road
man thats awesome hahha. that exhaust sound is so beastly. be sure to post up a vid!
iRONDONkey is offline   Reply With Quote
Old 01-29-2008, 01:33 PM   #8
mehsilvia
mehsilvia's Avatar
Trader Rating: (39)
mehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfectionmehsilvia is close to perfection
Feedback Score: 39 reviews
I had a similar problem. Resulted in a bad connection between the coilpack and harness, where the two connect with the large plugs. Some of the wires on the engine harness side were not secure so the connection was bad (similar to bad coil like mentioned above).
mehsilvia is offline   Reply With Quote
Old 01-29-2008, 01:36 PM   #9
JandMmotorsports
JandMmotorsports's Avatar
JandMmotorsports is an unknown quantity at this point
Send a message via AIM to JandMmotorsports
check your compression in each cylinder. check yo head gasket
JandMmotorsports is offline   Reply With Quote
Old 01-29-2008, 01:51 PM   #10
SHIFT_*grind*
SHIFT_*grind*'s Avatar
SHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfectionSHIFT_*grind* is close to perfection
Mine did that, it was a coilpack problem.
My seller review thread
SHIFT_*grind* is offline   Reply With Quote
Old 01-29-2008, 02:03 PM   #11
TOMKAIRA93
Thanks for the replies guys...out of all the solutions am inclining towards the blown gasket theory. I beleive there's a slight gasket leak around the turbo so that could very well be the culprit. We checked the coil packs by taking off one by one. All seemed to affect the idle when taken off. I removed all spark plugs as well a few times and didn't see any moisture or weird things. ECU is good cuz my brother in law hooked it up to his SR and it worked fine. And I just hope is not the head gasket at all. this car hasn't even driven more than 50 miles combine since installing the engine. The motor is good cuz I pulled it myself from the car in japan, so I know the engine was in good running condition before removal. I think my next step is to replace the turbo manifold gasket. It's a cheapie one anyways. Will be getting metal type. Thanks again guys. +1 for all the inputs.
Old 01-29-2008, 04:03 PM   #12
johngriff
johngriff's Avatar
gasket material doesnt matter as much as making sure the downpipe is mounted to the trans, that not being hooked up kills those gaskets.
--= :-D
[email protected]
Old 01-29-2008, 05:17 PM   #13
S-Nation S13
S-Nation S13's Avatar
Trader Rating: (92)
S-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-knownS-Nation S13 is making his/her stupidity well-known
Feedback Score: 92 reviews
lol ive had this problem
if you swapped or installed new injectors...did you make sure you used new O-Rings?...and if yo did did you lube the rings enough to where when you installed then it didnt feel like it was rubbing?
trust me cause i did that and my cylinder 1 was flooded and on top of that it got worse to the point to where my car shut down.....
hope this help
S-Nation S13 is offline   Reply With Quote
Old 01-29-2008, 05:23 PM   #14
KOUKI KAN KAN
KOUKI KAN KAN's Avatar
KOUKI KAN KAN is making his/her stupidity well-knownKOUKI KAN KAN is making his/her stupidity well-knownKOUKI KAN KAN is making his/her stupidity well-knownKOUKI KAN KAN is making his/her stupidity well-knownKOUKI KAN KAN is making his/her stupidity well-known
Check out your sparkplugs thats what it was for me .
KOUKI KAN KAN is offline   Reply With Quote
Old 01-29-2008, 08:22 PM   #15
S-Nation S13
Trader Rating: (92)
ok if you want i can tell you how to step by step to determine where you are at fault pm me if interested
Old 01-31-2008, 08:47 AM   #16
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
damn you for making me think this was a build thread
Sir is offline   Reply With Quote
Old 01-31-2008, 09:42 AM   #17
TOMKAIRA93
It does not mean you have the right to give me negative rep.
Old 01-31-2008, 10:32 PM   #18
S-Nation S13
Trader Rating: (92)
tomkaira93 you fig out what the prob. was hit me up if you have anymore questions?
Old 01-31-2008, 10:36 PM   #19
180sx_Drifter
180sx_Drifter's Avatar
180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection180sx_Drifter is close to perfection
check your coilpacks. but before you do that check for any leaks. mine was sounding nasty and ended up being a loose nut on the manifold to turbo connection.
180sx_Drifter is offline   Reply With Quote
Old 01-31-2008, 10:40 PM   #20
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
I would say it's a clogged fuel injector!
while car is running, pull 1 injector electric plug off, if it doesn't make a difference in idle thats your cylinder with issue...
Remove injector and replace...
This is only a shot in the dark from what I have read...but I would bet 83% sure thats it... I will call cylinder #3 too! lol...
pm me when you check and lmk...hahaha...
sillyvia13 is offline   Reply With Quote
Old 02-01-2008, 12:47 PM   #21
water
water has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud ofwater has much to be proud of
Well you know your ecu is good but did you try another ecu on your car? There's always the possibility that its your harness.
When you look at the plugs, does any one look dramatically different than the others?
water is offline   Reply With Quote
Old 02-01-2008, 12:51 PM   #22
TOMKAIRA93
I beleive the problem is turbo manifold leak...if not, I will check "injector 3". LOL Nah, I should have an answer this weekend. I'm going to work on the gaskets and then check the injectors. I'll post my results when done.
Old 02-21-2008, 06:41 AM   #23
TOMKAIRA93
I ended up replacing the turbo mani gasket (had a leak), but still didn't take the roughness away. I check all the injectors and discovered that when I pulled injector #1 the car would stay the same while the rest made a difference (ran worst). So you were right man...the only problem I have now is that the car still runs the same even after I replaced the injector. This is the weirdest thing ever...I mean, the car was running perfectly fine until my fuel pump hose took a plunge and now everything's going down hill.
To be honest and fair to everyone, I haven't attempted much after I replaced the injector...I figure I'd give it a few weeks. In the mean time, I've been working on the body in preparation for a paint job (will make new thread for this DIY Paint job). So yeah, I been having fun pounding the metal back to its original shape. LOL
But yeah, my car still doesn't run smooth, that's the bottom line.
Old 02-21-2008, 11:57 AM   #24
MomentumGT
MomentumGT's Avatar
^Might be an O-ring
-Jon
Old 02-21-2008, 12:05 PM   #25
steve shadows
steve shadows's Avatar
What if someone did swap a 2.5 liter wrex motor in a 240....
hmmm
Like Me on FaceBook !
Old 02-21-2008, 12:09 PM   #26
TOMKAIRA93
hmmm
that'd be interesting, but an SR sounding like one
Old 02-21-2008, 12:10 PM   #27
unicoladron
unicoladron's Avatar
unicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choicesunicoladron has made poor choices
hmmm
it'd be a bitch to change the spark plugs lol
1993 KA24DE for sale with 180k..running when pulled.... need to get rid of ASAP...i'm moving
unicoladron is offline   Reply With Quote
Old 02-21-2008, 12:11 PM   #28
rps13sh
rps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nicerps13sh is just really nice
Send a message via AIM to rps13sh
Originally Posted by Slidin240Wayz View Post
Dead coil pack.
Edit...woops.
Burnt ECU?
Carlos
yes, what he said
rps13sh is offline   Reply With Quote
Old 02-21-2008, 12:43 PM   #29
Neejay
Neejay's Avatar
Neejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfectionNeejay is close to perfection
hmmm
I would LOVE to do this (as I plan on getting a wrx/sti).
That's what I was hoping for when I clicked this thread.
Neejay is offline   Reply With Quote
Old 02-21-2008, 02:51 PM   #30
johngriff
johngriff's Avatar
Test for resistance on the injector plug to the corresponding ecu plug, and check for supply power on the other pin.
Then check spark.
If all that is good, its the injector/oring. Is it running rich/black smoke out of the tail pipe/check for burn on the spark plug.
John
[email protected]
