P1706 Park/Neutral Position Switch
My check engine light is on because of the P1706 Park/Neutral Position Switch. Is is hard to replace? Can I do it myself or do I have to bring it to the nissan dealer. Is there a how to on this forum for the P1706 Park/Neutral Position Switch replacement. obtw I have a 98 kouki. I also did a search and found nothing useful.
Thanks |
![]() Join Date: Jul 2007
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
This is an automatic trans right? It should be on the side of the trans and the shift rod should go through it. I have never really looked at an automatic 240 so I could be wrong, but that is where it normally is.
Manual trannies don't have park/neutral switches, they have a neutral safety switch and a clutch pedal switch. Was the car converted to a manual trans from an auto trans? Are you running an a/t ecu to eliminate the speed limiter? That's what it sounds like to me.
#5 | |
I bought the car as a manual. I don't think the car was converted to manual because the previouse onwer didn't mention anything about it being an auto. Is the switch important? CAn I just reset my light? O yeah the check engine has two codes, both was the P1706 Park/Neutral Position Switch. |
![]() Join Date: Oct 2007
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 0 reviews
Yes the manual trans has a neutral switch. Same thing when I got my s14, cel is on for the neutral switch. It's easy to replace just like the sensors but kind of hard to reach. I ordered the part from a nissan dealer, just go there and ask for the neutral switch. They don't usually have it in stock so you need to order it and it's about $37. It's the one closest to the shifter assy when you looked under the car on the passenger side all the way almost to the top of the trans housing.
#7 | |
#8 | |
Plz help, bugging the shit out of me
I replace the neutral switch and reset my check engine light. It was fine for a few day, but then the check engine light came back on. This is really annoying. Is there any way to delete this code completly, so it will disappear forever? Do I even need a neutral switch?
#11 | |
I have the same problem. It's annoying, especially when someone new gets in ur car....they look over and ask, y is ur CEL on???
I feel like socking them!
Rock wha U jock and don't talk if U ain't got!! ![]() ![]() |
#16 |
![]() Join Date: Nov 2006
Trader Rating: (54)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 54 reviews
^ well have you switched out the sensor yet? if not, start with that and make sure all your connections are connected properly.
- Jimmy Wanted: TBD For Sale: TBD |
#18 |
Trader Rating: (54)
dude, find your fsm or get one online. do a little searching for yourself. spoon feeding you is going to help you.
