Old 02-13-2008, 09:05 AM   #1
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
Feedback Score: 73 reviews
Fuel pump doesn't pump?
I'm going back to NA after having a bad experience with KA-T...
I however cannot get the car to run, the fuel pump doesn't give the engine fuel.
I've checked for a visible clog in the rubber lines at the pump.
I've checked for visible clogs at the fuel filter.
BOTH of the lines going to the fuel pump are DRY
When the pump is NOT connected to the fuel lines, the pump doesn't even send fuel at all.
Is there a pressure system that helps the pump send fuel? Is it possible I got the fuel lines reversed?
My car has been down so long I may have possibly reversed the lines in trying to figure out this fuel pump problem.
HELP!
I have currently:
2 stock KA24DE fuel pumps
1 Walbro
2 Fuel Pump carriers.
The fuel pump primes/whines/clicks/vibrates or whatever.
I just can't get it to PUMP fuel.
I'm out of ideas.
Do you guys have anything?
FaLKoN240 is offline
Old 02-13-2008, 09:12 AM   #2
Captain_Ron80
Captain_Ron80's Avatar
Captain_Ron80 is making a name for him/her selfCaptain_Ron80 is making a name for him/her self
I believe you can get the lines reversed. The line from the fuel filter should go to the line within the intake... and then the line from the FPR should go to the other line that re-routes back to the tank. Did you try and disconnect the line at the engine and just turn the pump on briefly? Better to do that with a buddy into a container...
Captain_Ron80 is offline
Old 02-13-2008, 09:12 AM   #3
Slidin240Wayz
Slidin240Wayz's Avatar
http://www.zilvia.net/f/showthread.php?t=84406
There are also plenty of threads already pertaining to this issue.
Slidin240Wayz is offline
Old 02-13-2008, 11:32 AM   #4
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
My problem isn't my fuel pump NOT activating, it's the fuel pump ACTUALLY sending fuel.
I saw that thread and it didn't pertain to my situation.
Old 02-13-2008, 11:34 AM   #5
johngriff
johngriff's Avatar
take off the lines at the sender, and click the key on to see if its getting fuel out of the sender first.
Did you need to ID which line is which? Let me go look at my car.
[email protected]
johngriff is offline
Old 02-13-2008, 11:38 AM   #6
downshift_sideways
No Limit Soldier.
downshift_sideways's Avatar
downshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfectiondownshift_sideways is close to perfection
Send a message via AIM to downshift_sideways
^I'd agree.
Have you checked your fuel pump fuse?
allntrlundrgrnd: "you never really appreciate your parents fridge until you look into your own and its full of condiments only"
downshift_sideways is offline
Old 02-13-2008, 11:38 AM   #7
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
What's the sender?
I'm not too experienced with touching power mods, and after failing at installing my turbo, and now failing just to get my car running I'm very hesitant to try it EVER again.
Old 02-13-2008, 12:03 PM   #8
johngriff
johngriff's Avatar
The sender is in the trunk, remove the cover with the 10mm bolts, then you will see the lines.
[email protected]
Old 02-13-2008, 12:31 PM   #9
downshift_sideways
No Limit Soldier.
http://www.240edge.com/manuals/91-94_240sx/fe.pdf (page3)
As John said. Take apart your fuel pump cover. take off the sender line.
Turn the key on. If gas squirts out. You should be good.
If no gas comes out..then you have a wiring problem or a shot Fuel pump..
Your ecu sends ground signal to your Fuel pump Relay (EGI)
Could be a simple case of your fuel pump going out. Or the motor on the pump.
Old 02-13-2008, 11:10 PM   #10
FaLKoN240
Super Moderator
FaLKoN240's Avatar
Trader Rating: (73)
I fixed it, I just soldered my Walbro back up and everything was peachy.
I don't know what the problem was nor do I care.
