Old 02-18-2008, 08:32 AM   #1
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
Output Shaft C-Clip
Ok so I've searched all day for this...
When i swapped my ring gears on my diff awhile ago i noticed my drivers side output shaft didn't have a c-clip on it, and that made is not stay into the diff, well my friend said it'll be fine since the axle will hold it in place so we installed it, now after about 2 months, I've noticed my diff doesn't really lock that well, on uneven surfaces like going out of parking lots the wheels feel like they aren't both catching, and I've noticed some gear oil in the driveway after driving...
Where can i get this clip and do you think thats what is causing all of these problems, well at least the leaking part which is causing the rest of them...
Slip Gypsies Blog
not sure if you realize this
Old 02-18-2008, 09:27 AM   #2
KA-T_240
KA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond reputeKA-T_240 has a reputation beyond repute
Look and see if you can visually find a leak. Could be the rear cover is not all the way tight. As for the C-Clip, you can probably pick up an open diff from a local for like $20
KA-T_240 is offline   Reply With Quote
Old 02-18-2008, 09:54 AM   #3
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
Feedback Score: 40 reviews
It actually called a snap ring look here under "round wire snap ring" you going to have to do some measuring.
http://www.arconring.com/wire.htm
http://www.arconring.com/pdfs/1000.pdf
or
Get it from Nissan, they call it a "CirClip"
Part number: 38225-35F00
Old 02-18-2008, 09:54 AM   #4
gmarzan
gmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of lightgmarzan is a glorious beacon of light
I dunno if that's the main cause of your problem. But, I think the c-clip (circlip) that you're looking has a part number 39600F. You can double check by checking Courtesyparts.com and use their online visual (or whatever u call it) guide. Hope this helps
gmarzan is offline   Reply With Quote
Old 02-18-2008, 10:02 AM   #5
UNISA JECS
UNISA JECS's Avatar
Trader Rating: (40)
39600F is only the part code which identifies what your a looking at when looking at the Nissan Fast part screen but the part number is what I posted just above.
Old 02-18-2008, 10:15 AM   #6
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
there are seals on each side of diff.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 02-18-2008, 02:55 PM   #7
projectRDM
projectRDM's Avatar
You need the clip, period. Under load the output shaft can easily slide for/aft, loosing fluid from the seal and slipping off the differential's splines, causing it to bind. The axle doesn't have enough tension to hold it in place, even if it was solid (it's not, the CV joints have a good deal of give in them).
FORMERLY R240NA
