Old 03-05-2008, 07:16 PM   #1
Entry Speed
Entry Speed's Avatar
Entry Speed is just really niceEntry Speed is just really niceEntry Speed is just really niceEntry Speed is just really niceEntry Speed is just really niceEntry Speed is just really niceEntry Speed is just really niceEntry Speed is just really niceEntry Speed is just really nice
S13/S14 Tie rods interchangeable?
I have a brand new set of Tien Inner/Outer tie rods with spacers for S13, but sold my s13 and now own another s14.
Does anyone know if these tie rods will work on my S14?
I've tried searching, with no definitive answer. Thanks in advance for the help!
Entry Speed is offline   Reply With Quote
Old 03-05-2008, 07:20 PM   #2
slider2828
slider2828's Avatar
I believe they fit.
Turn and Burn!
Old 03-05-2008, 07:28 PM   #3
garagelu
Trader Rating: (60)
garagelu is on a distinguished road
Feedback Score: 60 reviews
Yes s13 and s14 have the same tie rods.
garagelu is offline   Reply With Quote
Old 03-05-2008, 07:34 PM   #4
rican_nick
rican_nick's Avatar
rican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfectionrican_nick is close to perfection
Send a message via AIM to rican_nick
yeap.. currently have Tein tie rods from my s13 on my s14
Nick O.
97 240sx
My Seller's Review Thread
rican_nick is offline   Reply With Quote
Old 03-05-2008, 08:02 PM   #5
Entry Speed
You guys rock, thanks for the help
Old 03-05-2008, 08:08 PM   #6
JesusFreakDrifter
JesusFreakDrifter's Avatar
JesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud ofJesusFreakDrifter has much to be proud of
same as z32 tie rods
JesusFreakDrifter is offline   Reply With Quote
Old 03-05-2008, 08:51 PM   #7
!Zar!
!Zar!'s Avatar
The part that bolts up to the steering rack is the same.
But the s13/14 outters are different threads.
Old 03-05-2008, 09:04 PM   #8
Entry Speed
Then how are people running s13 TR's in s14s? is there some kind of rig or mod?
Old 03-05-2008, 09:09 PM   #9
louisdaboois
louisdaboois's Avatar
Trader Rating: (28)
louisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfectionlouisdaboois is close to perfection
Feedback Score: 28 reviews
s14's are just a bit beefier, you can only use s14 tie rod ends with the teins, not the s13's. and they're interchangeable on the racks.
louisdaboois is offline   Reply With Quote
Old 03-05-2008, 09:10 PM   #10
!Zar!
!Zar!'s Avatar
If you're using s13 inners, use s13 outters. If you're using s14 inners, use s14 outters.
Old 03-05-2008, 09:12 PM   #11
Entry Speed
I see, thanks for the input guys
Old 03-05-2008, 10:01 PM   #12
projectRDM
projectRDM's Avatar
Good lord what a cluster fuck of bad info.
S13 tie rods are a smaller diameter than S14/Z32, therefore the rod end is as well. If you have both the tie rod and the tie rod end you can swap them both as a set between chassis. If you only have one part of the setup, you cannot.
S13 -> S13
S14 -> S14
FORMERLY R240NA
Old 03-06-2008, 09:17 AM   #13
Dream240
Dream240's Avatar
Dream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond reputeDream240 has a reputation beyond repute
+1 to Russ(As if he needed it).
You can't inter-mix the S13 and S14 tie rods on the same car. The diameters are different. Like he said, get ALL S13 or ALL S14.
Don't mess with my monkey...he's loaded.
Dream240 is offline   Reply With Quote
Old 03-06-2008, 10:50 AM   #14
chuonthis
chuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the roughchuonthis is a jewel in the rough
Don't forget, a lot of aftermarket inner and outer tie rods (such as the Tein ones) are interchangeable with S14 parts.
Zar, you probably want to correct your post so people don't get confused. The last sentence should be "If you're using s13 inners, use s13 outers."
chuonthis is offline   Reply With Quote
Old 03-06-2008, 11:48 AM   #15
rican_nick
rican_nick's Avatar
from my understanding the Tein components are exactly the same between both chassis.. so if he has both Tein inner/outer rods as he stated it would cross over fine.
If they were OEM then yes both inner/outer need to be specific to each other.
Nick O.
97 240sx
Old 03-06-2008, 12:27 PM   #16
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
because they are the same part number - of course they would.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 03-06-2008, 01:58 PM   #17
rican_nick
rican_nick's Avatar
exactly.. just wanted to clear it up.. so the OP doesnt get confused.
his question was if the Teins would crossover.. yes they would... chassis doesnt matter as its the same for both.
Nick O.
97 240sx
Old 03-06-2008, 02:14 PM   #18
Entry Speed
Thanks again guys! all doubts/questions have been cleared up
Old 03-06-2008, 03:53 PM   #19
!Zar!
!Zar!'s Avatar
Ehh. I typoed. I ment s13 inner, s13 outter, s14 inner, s14 outter.
