Old 06-09-2008, 05:11 PM   #1
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
Hydro Ebrake Set Up!
I got a neal turning brake from ebay. cut it in half for a hydro e brake...
I need a 1 way valve to install in line between hand brake and master...
for a s13 of course...any help?
I googled it...
call every parts place in my neck of the woods!
I know there has got to be a 1 way valve to toss in line, I CANT FIND! IT!
EDIT!
A 1 way checked valve!
sillyvia13 is offline   Reply With Quote
Old 06-09-2008, 05:38 PM   #2
azndoc
azndoc's Avatar
Trader Rating: (47)
Feedback Score: 47 reviews
Wouldn't this work better in the Tech section?
You'd get more advice.
Just a suggestion.
Old 06-09-2008, 05:41 PM   #3
sillyvia13
sillyvia13's Avatar
I guess...mods wanna move?
I just wanna make skid marks that is all. with both tires via a big fucking hand brake.
Old 06-09-2008, 05:42 PM   #4
rps13drift
rps13drift's Avatar
rps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfectionrps13drift is close to perfection
I heard of people using slave cylinders for hydro e-brakes! you mkight want to look into that.
rps13drift is offline   Reply With Quote
Old 06-09-2008, 05:43 PM   #5
rps13drift
rps13drift's Avatar
or just spend a few bucks on a cnc hydro e-brake! me and a buddy of mine run it and its gnarly
Old 06-09-2008, 07:04 PM   #6
Fries
Fries's Avatar
I know Powered By Max offers a Hydraulic[sp?] Handbrake.
Join theyre site and go to the forums.
www.poweredbymax.net
Old 06-09-2008, 07:12 PM   #7
sillyvia13
sillyvia13's Avatar
I already have it in car...
I will see what I can do...
It will be same as CNC but just hill billy rigged i guess...
need a ball and spring style 1 way check valve up in this mother!!!!!!!!!!!!!
Old 06-09-2008, 07:37 PM   #8
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
luke did a write up and install deal a few years back on hydraulic handbrake.. might want to search it out... it was very easy setup to do and not too costly...
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 06-13-2008, 11:33 PM   #9
sillyvia13
sillyvia13's Avatar
any one...
I will pay you!!!!!!!!!!!
I have it all installed...
I would think it had a valve in it... maybe the other side was the part valved? I should swap it to that one...FUK!!!!!!
I hate being cheap sometimes... not really.
Old 06-14-2008, 11:13 AM   #10
McRussellPants
I googled it...
lol at putting one way valve in your brake lines
smoooooth.
McRussellPants is offline   Reply With Quote
Old 06-14-2008, 11:23 AM   #11
Sileighty_85
Sileighty_85's Avatar
smoooooth.
I was thinking that too lol
If you put a one way valve in that system then once you pressurize that line and it flows past the check valve for that line it will stay pressurized cuz of the check valve unless you have a relief valve installed after the check valve
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 06-14-2008, 02:47 PM   #12
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
yeah you cant really plumb the system up like that. if your using a regular brake cylinder on hydro handbrake, then you need secondary e-brake caliper.
if you want to use it with the existing brake, then you need a slave cylinder from a staging brake, so that you can plumb it inline with the existing rear brakes.
lazierhobo is offline   Reply With Quote
Old 06-15-2008, 10:09 AM   #13
sillyvia13
sillyvia13's Avatar
smoooooth.
you helped alot...thanks.
you guys are such wiseass's
use your head...You think that wasnt thought off...
DO NOT POST IF YOUR AN ARSE HOLE! with nothing but shit to lay down.
a neal turnoing brake was used... A CNC! brake. but it was cut in half and now I have 2! it should have bolted in and been fine!?
dunno tho!
I was gonna run dual calipers BUT I can get a new cnc brake for 99
I got the setup I have for like 50 so 2 for 50!?
well see...
I am stubborn and will make it happen.
Old 06-15-2008, 11:08 AM   #14
lazierhobo
can you throw up a picture of the setup you have....i think it would aid in coming up with a good solution.
your problem sounds similar to what i ended up with. i just found a different cylinder to bolt to the cnc brake frame, by far the easiest solution i could come up with...im always kinda weary of ghetto rigging rigging brake stuff cause you have to trust it to stop your car later.
Old 06-15-2008, 10:31 PM   #15
sillyvia13
sillyvia13's Avatar
I think I bought a bad hand brake from EBAY!!!!! no?
It is leaking internally...
I am gonna take it apart and replace the seals...see how it goes...
It has to have a 1 way check valve internally...or it wouldnt work...I guess the seal is gone and was leaking back into master...now that its in car and has sat for a few days I can see a small bit of fluid on the base of cylinder...
oh well, live and learn...this time being cheap took longer, but well worth it if I EVER GET ER! DONE!
Old 06-15-2008, 10:51 PM   #16
theslows13
theslows13 will become famous soon enoughtheslows13 will become famous soon enoughtheslows13 will become famous soon enough
he obviously didnt think out his master plan fully. first thing that went thru my head was what you and mcrusselpants said.
theslows13 is offline   Reply With Quote
Old 06-16-2008, 12:07 PM   #17
McRussellPants
what are you talking about.
stop cutting up whatever peice of shit brake you bought.
buy the hand brake from driftworks or get a K-sport and put a wilwood master in it.
done.
not rocket science.
Old 06-16-2008, 02:47 PM   #18
lazierhobo
there is no way to use a one way valve to plumb in a second master cylinder.
the leaking fluid you saw was from leaving the lines pressurized, eventually it will leak back past the seals, master cylinders are only designed to hold pressure for a certain period of time
Old 06-22-2008, 08:35 AM   #19
g6civcx
g6civcx's Avatar
Look at this pix and think about it for a second.
