Old 07-08-2008, 01:28 PM   #1
tsx1racer04
tsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to beholdtsx1racer04 is a splendid one to behold
75A Fuse Help
Hey guys,
Sorry to open another thread about electrical problems. I hear that the 75A fuse is culprit behind nothing working cept the headlights. I checked my fuse box and noticed that my 75A fuse was burnt. I just recently replaced it, and no luck what so ever.
Did I miss something? Was I suppose to disconnect the battery terminals? Am I suppose to let the car run for awhile to charge up? The fuse is still good.
The car runs and drives fine, just no gauges, brake lights, turn signals etc. only head lights working.
Any help?
BTW- I'm located in Socal, if anyone would like to come down sometime and check it out, I'm more than willing to pay for gas and for the time for diagnosing the problem.
tsx1racer04 is offline   Reply With Quote
Old 07-08-2008, 01:32 PM   #2
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
i had the same problem before check to see where there is a red clip where u connect the positive to the battery. make sure those two plugs that go into the redclip are tight in their.
Old 07-08-2008, 01:43 PM   #3
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
do i get a mcDs iced coffee???
http://www.zilvia.net/f/showthread.php?t=182370
kensreliableb18b is offline   Reply With Quote
Old 07-08-2008, 03:43 PM   #4
tsx1racer04
Thanks guys for the help.
Ill try these out ASAP. Just got home and need to rest a lil. Damn road blocks; Hahaha, yeah I'll get you some Iced coffee : ).
Old 07-08-2008, 03:54 PM   #5
brokeAs240sx
brokeAs240sx's Avatar
Trader Rating: (40)
brokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond reputebrokeAs240sx has a reputation beyond repute
Feedback Score: 40 reviews
check to make sure the fuse isn't burnt again - I had a similar problem - you don't need to take off the battery terminal or anything.
When the car starts, check to make sure you are getting 14v or around there as well.
bew bews!
brokeAs240sx is offline   Reply With Quote
Old 07-08-2008, 05:49 PM   #6
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
i had the same problem...it being a ground issue...if u want i can rll over and bring some extra 75A's just in case
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 07-10-2008, 11:59 PM   #7
tsx1racer04
Just a quick update, I made sure the two clips connecting to the positive terminal were in tight, they had this black gunk in there (don't know if that may be the problem).
But after the car is on for a few minutes, the red LED lights up for the battery indicator. I don't know if that is a factor?
Any help, would be much of appreciated, DALAZ 68, I'll pm you on the info so we can meet up
Thanks for all the help guys, much appreciated.
Old 07-11-2008, 01:49 AM   #8
brokeAs240sx
Trader Rating: (40)
have you tried what I suggested?
bew bews!
Old 07-11-2008, 11:30 AM   #9
tsx1racer04
I have not tried it, I was not able to get a hold of a volt meter. I'll rent one from Autozone ASAP. I'm a total noob when it comes to this stuff. Do you know where I would hook up the volt meter?
Old 07-11-2008, 12:02 PM   #10
brokeAs240sx
Trader Rating: (40)
I'm amazed you haven't gotten flamed for not searching... you really should search "how to use voltimeter" on google or something...
check your fuse again - it may be blown.
bew bews!
Old 07-11-2008, 04:45 PM   #11
tsx1racer04
Ahhh, I have found out how to use. I will check if there are any ground issues and see if I'm getting passed 12V. Will do, I'll check the fuse again.
Old 07-11-2008, 05:13 PM   #12
projectRDM
projectRDM's Avatar
Sounds like a dead alternator.
FORMERLY R240NA
Old 07-11-2008, 05:14 PM   #13
tsx1racer04
Okay, after much looking around. On the left side under the dash. I have found this fuse box, and this fuse box contains no fuses at all! Quite surprisingly, I think this may be my problem....
Thanks for the help.
Old 07-11-2008, 05:15 PM   #14
tsx1racer04
Could it be that too? It does make a squeal and the red LED lights up on the battery indicator after awhile the car has been on.
Old 07-11-2008, 05:19 PM   #15
projectRDM
projectRDM's Avatar
And there it is. The indicator signals low voltage, the squealing belt is symptom of the alternator slipping or seizing.
FORMERLY R240NA
Old 07-11-2008, 08:31 PM   #16
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
ur scaring me...now i think i need a new ALT cuz everytime i turn my car on....i have to throttle up to 2k for my lights to reach full lumanecent
PSN
