Old 08-21-2008, 01:02 PM   #1
Nikeboy355
Nikeboy355's Avatar
Nikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond reputeNikeboy355 has a reputation beyond repute
Time to CAGE my S13... NitinJ is back!... PICS!...
I parted my S13 out a couple of months ago and recently pulled it back out to started it's new rebuild... Version 2.0 if you like...
I ordered a cage from S&W Racecars and could use some help figuring out what configuration I should weld it in as well as any other chassis prep I should take care of now that the car is almost back to a bare chassis...
Here is the specs on the cage:
10 point
1-3/4 x .120" wall DOM tubing
Mild steel
Nascar style driver side door bar setup
Gusset plates (Dimple die plates... whatever)
Cage will be TIG welded...
Mild Steel - DOM, 10 Point Roll Cage, 10 Point Roll Cage Race Car Dragster Chassis, Rollbars, Cages, Suspensions, Parts
I know others have purchased their cages and they look great... I put up an album of other peoples cages that myself and the fabricator are getting ideas from...
Picasa Web Albums - Nitin - Chassis work
I wanted to tie in the front suspension as well as create a permanent strut bar... We were also thinking of spot welding the chassis from the inside (I have to learn more about this)...
I would like the chassis to be stiff but I understand that NASA/SCCA rules don't allow for the cage to go through the firewall... That might be OK since this car will hopefully only see Time Attack competition duty which is a little bit more relaxed...
Structurally what should I understand about installing this cage and prepping the chassis?... My fabricator is excellent and we want to do this correct... Safety first and chassis rigidity a close second...
Under the hood will be another NA KA that I'm rebuilding right now... This time with a 350Z six speed trans behind it though... Stay tuned...
Nikeboy355 is offline   Reply With Quote
Old 08-21-2008, 01:18 PM   #2
OMGZBRO
OMGZBRO has made poor choicesOMGZBRO has made poor choicesOMGZBRO has made poor choicesOMGZBRO has made poor choicesOMGZBRO has made poor choicesOMGZBRO has made poor choices
sounds nice cant wait to see the fitment
OMGZBRO is offline   Reply With Quote
Old 08-21-2008, 01:22 PM   #3
wow-thats-a-cool-car
wow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfectionwow-thats-a-cool-car is close to perfection
Send a message via AIM to wow-thats-a-cool-car
subscribed
can't wait for it to be done
wow-thats-a-cool-car is offline   Reply With Quote
Old 08-21-2008, 01:22 PM   #4
steve shadows
steve shadows's Avatar
Not too stiff.
I thought your car was too stiff before without the cage fyi.
I can handle the 8/6 though because Ill be using R-Comps only although 7/5 might still be in the works (progressive springs)
Like Me on FaceBook !
Old 08-21-2008, 01:27 PM   #5
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
If I ever build my cage I plan on running a bar from each strut tower to a central point on the underdash bar. I will weld them to the firewall as well and probably re-enforce the firewall where the bars go through. I would also run a strut tower bar as well in the front, probably the carbing aluminum one to save weight. What I want to do to brace the front end on the bottom is build a custom tubular front subframe where the subframe and the tension rod brackets/power brace are one solid unit. If you want to seriously campaign the car in time attack you should also attach the roll bars to the a and b pillars for extra rigidity. I plan on attaching my main roll hoop to the chasis directly above the front mounting points for the rear subframe. The rear downbars will be attached to the strut towers, NOT the wheelwells like every pre-fabbed cage I have ever seen. I will have a permanently welded in rear strut bar and a welded in x bar that attaches to the rear strut towers and directly above the rear mounting points for the rear subframe. If you want it as a track only car and have no need for passengers I hear a diagonal bar that goes from the top of the roll-hoop, behind the driver's head, to where the front cage leg attaches to the floor, on the passenger's side, makes a HUGE difference.
Old 08-21-2008, 01:29 PM   #6
racepar1
racepar1's Avatar
Originally Posted by steve shadows View Post
Not too stiff.
There is no such thing as "too stiff", that is purely a myth.
Old 08-21-2008, 01:42 PM   #7
Om1kron
Om1kron's Avatar
That's what she said... j/k
cant wait to see the progress, I love build and fabrication threads. subscribed.
Wayne Edwards
https://om1kron.blogspot.com
Old 08-21-2008, 03:18 PM   #8
Dutchmalmiss
Dutchmalmiss's Avatar
Dutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfectionDutchmalmiss is close to perfection
Send a message via AIM to Dutchmalmiss
Subscribed. I was waiting for the comeback haha.
Pignose, biaaatch.
Dutchmalmiss is offline   Reply With Quote
Old 08-21-2008, 03:26 PM   #9
seto_s14
seto_s14's Avatar
seto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud ofseto_s14 has much to be proud of
Send a message via AIM to seto_s14
hell yeh for sticking with the KA (kick ass) engine lol
San Gabriel Car Detailing
https://www.ocdshine.com
seto_s14 is offline   Reply With Quote
Old 08-21-2008, 03:40 PM   #10
ProjNightshade
ProjNightshade will become famous soon enoughProjNightshade will become famous soon enoughProjNightshade will become famous soon enoughProjNightshade will become famous soon enough
man, I'm subscribed. The car looks gorgeous. Makes me want to find another hatch chassis to make a sil-80 all the more.
Can you give us a little insight on the na ka plans? I'm pretty interested in what you have up your sleeve.
ProjNightshade is offline   Reply With Quote
Old 08-21-2008, 03:54 PM   #11
Dutchmalmiss
Hey Nitin, how much power do you plan on making? What diff are you using with that tranny?
Pignose, biaaatch.
Old 08-21-2008, 04:23 PM   #12
steve shadows
you sure about that? haha
not for drifting. there isnt
Old 08-21-2008, 04:29 PM   #13
racepar1
racepar1's Avatar
I got the idea that you were referring to chasis stiffness. It is not possible to make a chasis too stiff, 0 flex is ideal there. For suspension stiffness (springs and sways) it is totally possible to go too stiff. As a matter of fact 99.9999999% of coilovers come right on the verge of being too stiff, especially for street tires.
Old 08-21-2008, 04:30 PM   #14
Nikeboy355
Nikeboy355's Avatar
The longblock will be stock and will actually be a copy of my last rebuilt KA that made 155WHP, 155WTQ...
This is the graph with and without the silencer in the exhaust...
But the plan is to have some fun with adding ITBs and a custom header that will exit somewhere on the driver side of the car... I'm not sure what tuning I will go with... Either milk what a tuned ECU can do or a full standalone... And E85 fuel...
So in summary:
OEM rebuild longblock
GSXR ITB setup
Custom header with side exit
E85 fuel
Tuned ECU or standalone
With the 350Z trans I will end up with an effective final drive around 4.6...
A nice clutch and a helical LSD will finish it off...
The longterm plan is to have a complete head package and a twin scroll turbo setup... I already have an EVO turbo lying around...
The other plans for the car involve a lot of aero and suspension development that I'm learning myself as we go along... The last setup was pretty basic and I've watched my S2000 friends really advance a lot in those areas...
I hope it all works well...
Old 08-21-2008, 04:44 PM   #15
Nikeboy355
Nikeboy355's Avatar
And here is some examples of my fabricator's work...
He can make anything...
And this is how he rolls... He has to rent that RV for $500/day just to take the truck out to Glamis... Tight...
Old 08-21-2008, 08:19 PM   #16
ProjNightshade
I'm really interested in how you're gonna do this. That's why I'm asking alot of questions. I have a set of GSXR 750 tb's, but I never got around to doing anything with them.
I had considered going the megasquirt way, but the idea of a trigger wheel on the crank pulley or rigging up something to work in a way it wasn't intended kinda turned me off.
Like I said, I'm watching closely. Your fabricator looks like he does amazing work.
Old 08-21-2008, 08:22 PM   #17
forum04pl
forum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond reputeforum04pl has a reputation beyond repute
Send a message via AIM to forum04pl
Can't wait to see the fabbing
forum04pl is offline   Reply With Quote
Old 08-22-2008, 03:43 PM   #18
FABitALL
FABitALL is an unknown quantity at this point
yea.. come on nikeboy. wats up with the updates on the fabbing??
FABitALL is offline   Reply With Quote
Old 08-22-2008, 04:21 PM   #19
Nikeboy355
Nikeboy355's Avatar
The cage comes in at the end of next week...
I'll get the exact amount but it came out to $850 shipped... Including tax...
That was for the cage, nascar door option, and the gusset plate kit... Shipped to Los Angeles...
Their customer service so far has been top notch... Here is their contact info:
S&W Racecars
800-523-3353
11 Mennonite Church Rd.
Spring City, PA
19475
ask for George... extension 117
or
[email protected]
Old 08-22-2008, 04:22 PM   #20
Wiisass
Wiisass's Avatar
Wiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond reputeWiisass has a reputation beyond repute
Send a message via AIM to Wiisass
So if this fabricator is so good, why would you buy a crappy S&W cage?
And be careful with a permanent strut bar if you're thinking about running it straight across. Although it would be funny to see someone do that and not be able to get the engine back in through the top.
TIP Engineering
R/T Tuning
Drift and RWD Sport
DriftAssNation
Wiisass is offline   Reply With Quote
Old 08-22-2008, 04:38 PM   #21
suprmods
suprmods's Avatar
suprmods is an unknown quantity at this point
I've never read a NASA/SCCA rule that prohibited this. I know in Honda Challenge there is a rule on adding a weight penalty if the cage goes through the firewall, and I might have even seen a few crx's with such a cage.
suprmods is offline   Reply With Quote
Old 08-22-2008, 05:43 PM   #22
Def
Why stick with an NA KA? Just seems like a simple turbo setup is easier than NA after a point, and the cost is almost negligible once you factor in all the tuning you need on an NA setup to eek out that last 5-10 rwhp.
Old 08-22-2008, 07:24 PM   #23
racepar1
racepar1's Avatar
Because N/A is better! LOL! I personally wouldn't want to run a turbo motor in cali, especially if you wanna drive the car to and from the track. A big intercooler and a BOV is basically a big neon "PULL ME OVER" sign in most of so-cal. I think that is the reason that you see a lot of so-cal guys selling their SR's right now. Even a god damn exhaust ticket requires a trip to the ref and a full inspection. I wanna do a N/A KA just to prove that it can be done reliably and can produce sufficient power (200 whp) while still being "smog legal" (basically the bolt-ons will be carb legal and I will use a "stock" intake mani).
Old 08-22-2008, 07:27 PM   #24
Om1kron
Om1kron's Avatar
You haven't been paying attention to california smog have you?
state ref is out of commission until further notice homie...
California Department of Motor Vehicles
Wayne Edwards
Old 08-22-2008, 07:33 PM   #25
racepar1
racepar1's Avatar
I saw that, but that does not mean that if you get a ref ticket you are off the hook. It means that you will HAVE to pay the fine. It's effed up, but that's the way it works.
Old 08-22-2008, 07:35 PM   #26
racepar1
racepar1's Avatar
I was thinking the same exact thing.
Old 08-22-2008, 07:36 PM   #27
Def
If I was set on NA I'd probably drop a VQ35 in there. They've got to be getting cheap/plentiful enough to do the swap for not all that much money. Keep it roughly stock and it'll easily outpower any NA KA that will last for more than a few hours. And it'd be smog nazi legal.
Just my take on it.
The build looks like fun though.
Old 08-22-2008, 07:42 PM   #28
Def
On this same line of thought, what about a good custom SMIC? It would make cooling a snap, and a recirc. BOV is essentially silent. Get a quiet exhaust setup for at least the street and you're good to go. It'd be a PITA for inspections, but it wouldn't be that horrible to pull most of that junk off and get it smogged essentially stock.
Would be a pretty easy 300 rwhp capable setup if you put some thought into it.
My S13 with a stock SR setup with SMIC was pretty stealth, especially with the 4x4 stock suspension and steelies on it(swap happened early in its life with me due to a friend being a little "over zealous" when I let him borrow it).
Old 08-22-2008, 09:24 PM   #29
McRussellPants
shush steve.
lets not get into which cars run 18/18kg and which run 8/4kg
im sure you don't want to know the answer.
McRussellPants is offline   Reply With Quote
Old 08-22-2008, 09:42 PM   #30
clark
clark's Avatar
clark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfectionclark is close to perfection
badass...subscribed
clark is offline   Reply With Quote
