Old 09-24-2008, 11:53 AM   #1
Mangudai
Mangudai's Avatar
Mangudai is an unknown quantity at this point
Recommend me a low pro jack
Its really annoying having to use the scissor jack to get the car high enough to use the service jack, I just want to be able to slide a jack to the from crossmember and get it done. I also have large plastic ramps but if I have the alt out (like i do now) and im alone theres no way i can push it up the ramps. Using 2x4's doesnt work as the lever on the service jack needs just a little more space than is allowed to jack up. So what is a good, reliable low pro jack? My car isnt slammed.
Mangudai is offline   Reply With Quote
Old 09-24-2008, 12:02 PM   #2
JDMB0iKT
JDMB0iKT's Avatar
JDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfectionJDMB0iKT is close to perfection
Send a message via AIM to JDMB0iKT
You could go to Harbor Freight and order a jack. Should run you about $90.
Instagram
JDMB0iKT is offline   Reply With Quote
Old 09-24-2008, 12:15 PM   #3
Maiku240sxS14
Trader Rating: (37)
Maiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enoughMaiku240sxS14 will become famous soon enough
Feedback Score: 37 reviews
I don't know how low you need the jack to be....but I use the aluminum low profile jacks that AutoZone or Kragens carry. You can usually find them on sale for about $100.
Maiku240sxS14 is offline   Reply With Quote
Old 09-24-2008, 12:15 PM   #4
Dousan_PG
Dousan_PG's Avatar
harbor freight is the easiest and cheapest bet
it wont be more then 120 iirc
it works ok
but over time, its a pos
Aaron
Pink GodziRa
Old 09-24-2008, 12:16 PM   #5
dynamicck
dynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to beholddynamicck is a splendid one to behold
Stack the 2x4's
Why cant you drive the car up onto the ramps, rather than push it?
Anyway, go to Costco, they have low pro aluminum jacks for like 120?
It might be steep, but Costco still offers LIFETIME warranty. (not avail on electronics)
dynamicck is offline   Reply With Quote
Old 09-24-2008, 12:18 PM   #6
YoungGun
YoungGun's Avatar
Harbor Freight. 80 dollar low aluminum jack FTW.
3.5 inches is the lowest, so its easy to get it under the diff, and it holds 3000 lbs. IIRC.
YoungGun is offline   Reply With Quote
Old 09-24-2008, 12:19 PM   #7
twistedsymphony
twistedsymphony's Avatar
twistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of lighttwistedsymphony is a glorious beacon of light
I just bought a really nice 2.5 ton jack from NAPA for ~$115
I asked a similar question on another board and heard nothing but praise for the NAPA jacks. (lots of people recommended against the Craftsman jack saying they dont last, but that the NAPA ones go for years and years)
it's lower than most jacks but still not low enough to get under the 240 to lift from the engine cross member.
I ended up building some ramps out of 2x6 planks of wood. I drive up on those and then jack up the front.
the jack is fine in the rear of the car without ramps, and if you made an adapter block to jack from the pinch weld it would be fine for that too... Similarly if you're crazy enough to jack the front from the cross member that would work but I personally don't feel safe jacking from there.
Most hot rod shops that deal with slammed rides will drive up on planks of wood in order to get the jack under there.
the Ramps I build have a 5ft piece with a 3ft piece on top of that and a 1ft piece on top of that... the car could have 1.5" of clearance with 24" of "nose" and the ramps will effectively lift it 4.5"
twistedsymphony is offline   Reply With Quote
Old 09-24-2008, 12:20 PM   #8
SoSideways
SoSideways's Avatar
Yup, that's the same one I've got.
Works pretty well, and does indeed get under the diff of the car until you're really slammed, then you'll have to probably back up on ramps made out of stacked 1x4s so you can make a gradual climb, until it's high enough to put the jack under your car.
Old 09-24-2008, 12:21 PM   #9
S14DB
AFC #1
S14DB's Avatar
I have a low pro jack. While I can clear the core support to get it to the front cross-member. I can't pump the lever more than an inch without it hitting the bumper.
If I can't drive/push the car onto the ramps. I jack one side up and put the mini ramp under the wheel. then repeat on the other side. Then I have enough room to jack up the car from the cross-member.
Old 09-24-2008, 12:25 PM   #10
GSXRJJordan
GSXRJJordan's Avatar
Seriously... real men have intercoolers and aero, so you can't lift from the crossmember.
I used the Kragen low pro jack for years, then it failed out of warranty... I will eventually rebuild it, in the meantime I use an Autozone lightweight aluminum jack. I'm all about Cosco's lifetime warranty though...
Old 09-24-2008, 12:28 PM   #11
codyace
codyace's Avatar
Trader Rating: (58)
Feedback Score: 58 reviews
Craftsman Low Profile jack, got it on sale like 2 yeras ago. Only bitch is that you gotta bleed it/refill it once a year. No drift issues, still in great shape. I throw it all over the place, it keeps loving me back. We got a US General one for the service truck from HF...it works pretty good, but drifts more than I like it. But who cares if you have stands.
It kicks ass. It's Slammed VW approved as well.
Put it right under the middle of the car (on the side). Jacks the entire side up at once. Bam, 2 jackstands on the dirver side.
Repeat for the passenger side.
I wouldn't lift ANY car from the front rad support. Half of them are all rusted to shit and fucked up anyway
Old 09-24-2008, 12:30 PM   #12
ZX88
ZX88's Avatar
Originally Posted by codyace View Post
Craftsman Low Profile jack, got it on sale.
i cant get to the rear diff with my craftsman with out 2 2x4 under each wheel it keeps hitting my gas tank i wanna get another floor jack and just jack the cr from the rails on both sides lol.
Old 09-24-2008, 12:32 PM   #13
blackrms13
blackrms13's Avatar
i got the medium size harbor freight one on sale for like lil over $70 out the door
i think mine was like a 3inch saddle height
its one of those silver body with blue side and blue handle
blackrms13 is offline   Reply With Quote
Old 09-24-2008, 12:58 PM   #14
S14DB
AFC #1
S14DB's Avatar
Note that he said CROSSMEMBER not Rad support. Where the engine and LCA's bolt to. It's a hard point to jack from in the FSM.
Also, he was quoting me where I said my jack cleared the rad support to get to the cross-member. The problem with most jacks is not the shoe getting under the cross-member but the pivot box being to high and hitting the rad support or the bumper.
Old 09-24-2008, 01:10 PM   #15
Om1kron
Om1kron's Avatar
haha it's soo much work to jack up a lo profile car. I seriously would invest in air jacks if I was to put a full on cage in my car... why the fuck not right?
Wayne Edwards
https://om1kron.blogspot.com
Old 09-24-2008, 02:28 PM   #16
aznpoopy
aznpoopy's Avatar
the high lift low clearance aluminum racing jack is on sale at harbor freight for 160
get it. its bulky but awesome
before that i used the smaller $100ish hf aluminum jack with a 14"+ lift. its nice to do stuff on the corners quickly but sucks if you have to get under. just not enough lift to get the stands extended.
Old 09-24-2008, 02:47 PM   #17
240=180
240=180's Avatar
240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about240=180 has a spectacular aura about
harbor freight FTW... LOL I work there. Get the rapid pump. It goes to full lift in 6-7 pumps.... And get the extended replacement plan cause if it goes out you'll get a new one
240=180 is offline   Reply With Quote
Old 09-24-2008, 02:53 PM   #18
Z33dori
Z33dori's Avatar
I need to invest in those ramps.....
and invest in a race jack.....
Old 09-24-2008, 02:54 PM   #19
HyperTek
i got one of these NRG ramps
front aero still has to come off, so any jack will do after that
wood works just fine, i used to carry pieces of wood in my s13 lmao
Keep it Classy
Old 09-24-2008, 03:09 PM   #20
dori_sil8t
dori_sil8t's Avatar
dori_sil8t is making a name for him/her selfdori_sil8t is making a name for him/her self
wally world(wal mart) big red aluminum jack. its gets under the diff nooooooo problem
its been to many track days, and never let me down once
unionautoclub.com
dori_sil8t is offline   Reply With Quote
Old 09-24-2008, 04:04 PM   #21
kuruptR
kuruptR's Avatar
kuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfectionkuruptR is close to perfection
Send a message via MSN to kuruptR
Got these too, but they do not work in a garage. They slide around and are hard to get on. 2x4's are the best.
kuruptR is offline   Reply With Quote
Old 09-24-2008, 04:20 PM   #22
projectRDM
projectRDM's Avatar
http://www.thetoolwarehouse.net/shop/OME-29023.html
The best money can buy, 2.5" minimum height, extra long reach, 2ton capacity. You can skimp and buy a shit ass Torin jack from Northern, Harbor Freight, or Costco but you'll be replacing it within a year or tracking down parts to replace the lost rollers, handle, etc. Craftsman makes a good one but it's not long enough for a good reach to the crossmember or diff. The Omega one above is THE jack for a lowered car. Buy right or buy twice. Add a pair of low profile plastic ramps from Ebay ($49) and you're set to raise anything.
FORMERLY R240NA
Old 09-24-2008, 04:34 PM   #23
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Why not? Its not like the crossmember doesn't support the engine or anything
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 09-24-2008, 06:18 PM   #24
aznpoopy
aznpoopy's Avatar
that jack rdm posted looks pretty good. wish i saw that a week ago.
Old 09-24-2008, 06:36 PM   #25
projectRDM
projectRDM's Avatar
Apparently someone doesn't know shit about his own car. But hey, it's not like that's a new thing here, confusing one part for a completely different and unrelated one. Crossmember, core support, steering wheel, radio, they're all the same thing really.
FORMERLY R240NA
Old 09-24-2008, 06:37 PM   #26
S14DB
AFC #1
S14DB's Avatar
I swear people get the core suport and cross-member confused.
Red X = Core Support, Don't jack here.
Green Line behind the oil pan = Cross-Member, jack here.
Old 09-24-2008, 06:44 PM   #27
projectRDM
projectRDM's Avatar
Dude, people get the engine and transmission confused on here. Shit.
FORMERLY R240NA
Old 09-24-2008, 09:54 PM   #28
Mangudai
Mangudai's Avatar
Originally Posted by projectRDM View Post
Omega 29023 2-Ton Heavy Duty Low Profile Service Jack Order#*OME29023 www.TheToolWarehouse.Net
That's whats up. Just to clarify with you so im sure though, how low is your car? Like I said the one I have now has no problem going under the car its just the lever doesnt have enough space to move up. I would hate to get this thing and still not be able to jack up.
Crappy pic
Thanks guys
Old 09-24-2008, 10:00 PM   #29
projectRDM
projectRDM's Avatar
Crappy pic
Thanks guys
Shit, you're fine. I'm way lower than that, and have a lip. The main thing is the long reach this jack offers, the handle has plenty of room to move.
FORMERLY R240NA
Old 09-24-2008, 10:30 PM   #30
5t341tH
5t341tH's Avatar
5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute5t341tH has a reputation beyond repute
Send a message via AIM to 5t341tH
Crappy pic
Thanks guys
lol. u have plenty of room. the HF one thats <100 bucks will work fine for u. its 3" saddle height
lexus baby
5t341tH is offline   Reply With Quote
