Old 12-12-2008, 08:55 PM   #1
LA_phantom_240
LA_phantom_240's Avatar
LA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfectionLA_phantom_240 is close to perfection
Suspension question!
Other than physical length, the only difference between s13 and s14 struts is the top mount, correct? And of course a different spring rate.
Originally Posted by SoSideways View Post
Come on, this isn't Gran Turismo.
Originally Posted by DOOK
your balls are either ballin, or they aren't... no second hand nut sweat can change that.
3/28/09 Buy this stuff!
http://zilvia.net/f/sale-items/24807...-stuff-fs.html
LA_phantom_240 is offline   Reply With Quote
Old 12-12-2008, 09:05 PM   #2
JDS Performance
JDS Performance's Avatar
Trader Rating: (53)
JDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of lightJDS Performance is a glorious beacon of light
Feedback Score: 53 reviews
Figure it out yourself - try and help someone and they talk crap!
JDS Performance is offline   Reply With Quote
Old 12-12-2008, 09:34 PM   #3
LA_phantom_240
Hmmm.... But what about the upper mounts?
Old 12-12-2008, 09:37 PM   #4
JDS Performance
Trader Rating: (53)
Old 12-12-2008, 09:40 PM   #5
LA_phantom_240
Yeah. Well, I just wanted another opinion. I'm positive they're different. The mounts on an s13 are smaller (in total diameter) than in s14.
Looks like I have some business to settle.
Old 12-12-2008, 09:59 PM   #6
JDS Performance
Trader Rating: (53)
Old 12-12-2008, 10:09 PM   #7
Def
I'm almost positive the rear S14 shock mounts are larger than the S13 ones.
Old 12-12-2008, 10:16 PM   #8
JDS Performance
Trader Rating: (53)
Old 12-12-2008, 10:26 PM   #9
LA_phantom_240
Originally Posted by JDS Performance View Post
I am not saying anyone is wrong but KYB is a pretty good company nad they have both chassis listed the same.
When I bought KYBs they didn't come with upper mounts anyway.
Yes, for the record S14 rear upper mounts are larger.
Second question. Would I be able to swap my rear upper mount onto rear coilovers that have the s13 top mount?
Old 12-12-2008, 10:29 PM   #10
JDS Performance
Trader Rating: (53)
Old 12-12-2008, 10:34 PM   #11
LA_phantom_240
I know some have used the camber pillow ball mounts on shock/spring combos with little mods - but vise versa not sure - I never tried it and why would you want to take off the pillow mount on the coilover for a stock shock mount anyways?
We're talking rear here. Damn, are you some kinda illiterate?
Rear doesn't have pillowballs.
This is my problem...
Now you get it?
Old 12-12-2008, 11:27 PM   #12
McRussellPants
gotta make sure you have the right spacers/sleeves on the shock to the top hat or it'll be loose and break or too small and won't go together.
but yeah the top hats should interchange between coilovers from the same company.
McRussellPants is offline   Reply With Quote
Old 12-12-2008, 11:40 PM   #13
LA_phantom_240
Wait... what?
Old 12-12-2008, 11:43 PM   #14
projectRDM
projectRDM's Avatar
Your first post said strut. The rear is clearly not a strut. So for the rear shock, yes, the S14/S15 upper mount is larger in diameter with the studs further apart. It will not work on an S13 chassis. The front though will work fine, they're all the same bolt spacing for S13-S15.
FORMERLY R240NA
Old 12-13-2008, 12:01 AM   #15
McRussellPants
Oh wait, you're dumb/cheap as fuck and you're trying to put coilovers on stock top hats?
yeah, go for it dude, whatever happens happens.
Old 12-13-2008, 12:01 AM   #16
LA_phantom_240
I realize this. What I need to know is if I can take my OEM strut upper mount, and mount it on the rear coilovers I got. Apparently I got lied to when I bought "s14 coilovers" on here. Ksport wants $78 a piece for the upper mounts, and I really don't want to eat that. I got the fronts on (which is odd if they're s13 coilovers, with the bigger bolts and all), but the rears don't work, because they have the smaller, s13 mount.
No, I got lied to by the guy I bought them from here on Zilvia. So fuck off.
Nice edit. Thanks for trying, honestly... But man you gotta learn to read.
Old 12-13-2008, 06:08 AM   #17
xs240
xs240 is an unknown quantity at this point
go to Nissan Road Racing Forums - Powered by vBulletin for your suspension needs
xs240 is offline   Reply With Quote
Old 12-13-2008, 07:08 AM   #18
LA_phantom_240
Eh.... I'm already on enough forums... but I'll give it a shot.
Old 12-13-2008, 11:52 AM   #19
LA_phantom_240
Fuck it, I'll just get the mounts from KSport this paycheck...
Old 12-14-2008, 06:42 PM   #20
Def
NRR is a good forum, you should join. But besides that, you just need to make sure the ID of the stock shock mount is the same as the coilover strut. Take them both apart, measure and compare. Then if you need to just get a sleeve spacer to reduce the ID of the stock housing, but it looks like the same OD shock shaft from the pics.
Take it apart and it should answer your questions.
