Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Misc & Accessories
Old 01-21-2009, 02:39 PM   #2461
pink godzila
pink godzila's Avatar
Trader Rating: (226)
pink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond reputepink godzila has a reputation beyond repute
Feedback Score: 226 reviews
"Diameter change to be compatible with SWIFT springs, offer Swift version" good idea, but is there still a 8 weeks wait if someone wants a 8k/6k for their S-chassis? hope not.
Also, look forward for soem streetable coilover!! stiff is good but for daily is crazy..
pink godzila is offline
Old 01-21-2009, 02:45 PM   #2462
DC Dan MAX USA
DC Dan MAX USA's Avatar
Trader Rating: (79)
DC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond reputeDC Dan MAX USA has a reputation beyond repute
Feedback Score: 79 reviews
Originally Posted by irritatedmax View Post
That looks like a lot of graphic for a coilover. I like simple.
I was thinking more about this comment. The graphic would wrap around 3 sides of the lower mount so if you look at the coilovers mounted in the car on one side you have TSUISOpro, the other side you have MAXドリフト and the cars are on the backside of the knuckle mount where you wouldn't seee them except for when the coilovers come out of the box.
If you look at any automotive coilovers out there they are all simple looking so youre right its alot of graphic for your average coilover. Just throwing out there whatever we think is cool. I was thinking outside the box drawing inspiration from other action sports like Jump bikes/ motoX where suspension graphics are commonplace seen below.
We have 6KG in stock in the USA now $60/pair
How To order: You can order directly from our zilvia advertiser threads. When you add to cart, you get an instant shipping estimate, & the cart will remember all of your items as you move between forum threads and our website www.poweredbymax.net until you remove them or check out. I can also calculate estimates manually for you but the cart's estimates are way faster and more accurate.
Order Inquiry: IM me your real name and paypal address.
Thanks for your business!
DC Dan MAX USA is offline
Old 01-21-2009, 02:49 PM   #2463
SoSideways
SoSideways's Avatar
Kinda off topic, but do you guys have a coilover shock dyno somewhere?
SoSideways is offline
Old 01-21-2009, 03:05 PM   #2464
DC Dan MAX USA
Trader Rating: (79)
yes
POWERED BY MAX: Forums フォーラム / クレイジードリフタ―河森に質問 As k Eisuke San and MAX staff questions / MAX shock dyno charts
Shock Dyno stats: Front shock at maximum damping setting: Damping test at 229rpm (.6M/sec) Tension = 748.8KG Compression = 94.8KG Front shock at minimum damping setting: Damping test at 229rpm (.6M/sec) Tension = 625.7KG Compression = 92.9KG Rear shock at maximum damping setting: Damping test at 191rpm (.5M/sec) Tension = 642.6KG Compression = 99.5KG Rear shock at minimum damping setting: Damping test at 191rpm (.5M/sec) Tension = 591.8KG Compression = 94.4KG
Old 01-21-2009, 03:22 PM   #2465
SoSideways
SoSideways's Avatar
Thanks.
Darn, I don't know how to read those ones lol I know how to read the other kind haha
Old 01-21-2009, 03:44 PM   #2466
txrxs
txrxs's Avatar
txrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfectiontxrxs is close to perfection
This my be a shot in the dark and I know the gen 2 coils are just in the conceptual stage...
Are we looking at like 3 months-ish or more like next year?
DRIFTINDY
txrxs is offline
Old 01-21-2009, 03:48 PM   #2467
harangatang
harangatang's Avatar
harangatang can only hope to improve
s14 version 2 camber arms and toe arms, s14 subframe spacers, the water-air separator tank and a spin turn knob shipped to 76065
harangatang is offline
Old 01-21-2009, 04:06 PM   #2468
DC Dan MAX USA
Trader Rating: (79)
Originally Posted by SoSideways View Post
Thanks.
All you really need to know is that they have low compression damping and high rebound damping that makes them easily absorb impact yet control the bounce of the 8/10 KG springs compaired to others.
Its up to Eisuke San to work on the damper engineering so I dont know. I'm just taking this window of opportunity to contrubute some good ideas to the next generation before they get set in stone.
$588
Old 01-21-2009, 04:38 PM   #2469
harangatang
thanks man :]
Old 01-21-2009, 04:45 PM   #2470
LongGrain
LongGrain's Avatar
swift springs option with 9k/7k rates would be the cat's pajamas
LongGrain is offline
Old 01-22-2009, 02:39 PM   #2471
DC Dan MAX USA
Trader Rating: (79)
DG5's with swift call for 8/6 on the S13 and 9/7 on the S14
CST with swift calls for 8/6 as standard
...but obviously you can get any KG rate you want
Old 01-22-2009, 02:56 PM   #2472
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
Okay, Dan, now I get what you are saying about the graphic. I was thinking it would be placed with the words perpendicular to the length of the coilover so you would have to rotate the coilover to see it all. I wasn't thinking of putting it so the words are long ways with the coilover. This, as you said, would divide the graphic into three parts. Make sure the branding is visible during tire changes so when people be like "Dang, how you drift so good?" they can peep the coils. Haha, I am a marketing genius!
I also must give you +rep for producing a coilover dyno. That is usually a question that is asked to bust a vendors nuts and it is never addressed. I mean, honestly, who actually knows how to read them?
irritatedmax is offline
Old 01-22-2009, 03:11 PM   #2473
Z33dori
Z33dori's Avatar
Dan what recommendation for rear break pads, or solutions to locking up the rear brake faster...
i have a welded diff if that makes a difference
Z33dori is offline
Old 01-22-2009, 03:25 PM   #2474
DC Dan MAX USA
Trader Rating: (79)
Precisely. Sweet my nuts are safe... LOL
I use BRIG pads from Japan, they are fanfriggintastic
Old 01-23-2009, 09:47 PM   #2475
240Driver39
240Driver39 is making a name for him/her self240Driver39 is making a name for him/her self
Send a message via AIM to 240Driver39
I would like a set of the subframe collars. Could i get a price shipped to 19711. Thanks
1990 240sx 5spd fastback
240Driver39 is offline
Old 01-26-2009, 01:25 PM   #2476
DC Dan MAX USA
Trader Rating: (79)
$61.50 shipped to you.
Old 01-28-2009, 05:43 PM   #2477
DC Dan MAX USA
Trader Rating: (79)
We've got the miller TIG welder up and running in the shop now so hit us up if you have any aluminum fab needs.
Old 01-28-2009, 07:22 PM   #2478
w0nderbr3ad
Trader Rating: (50)
w0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to allw0nderbr3ad is a name known to all
Feedback Score: 50 reviews
Send a message via AIM to w0nderbr3ad
Dan, you used to have an oil cooler setup forr sale on the PBM site. what happened to it?
w0nderbr3ad is offline
Old 01-29-2009, 12:18 PM   #2479
DC Dan MAX USA
Trader Rating: (79)
We dont carry that anymore.
Old 01-29-2009, 12:24 PM   #2480
Flipzide
Flipzide's Avatar
Flipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfectionFlipzide is close to perfection
Hey Dan, can I get a set of subframe collars for my s14? If you do, I'd like to send payment tonight and pick-up tomorrow around noon.
D-Street.net | bcuison.wordpress.com
Flipzide is offline
Old 01-29-2009, 12:28 PM   #2481
DC Dan MAX USA
Trader Rating: (79)
In stock ready to go
$50
come and gitem!
Old 01-29-2009, 12:52 PM   #2482
Flipzide
Flipzide's Avatar
thanks for the quick response. i sent payment just a minute ago, can you PM me back to confirm? thanks. i'll see you tomorrow!
Flipzide is offline
Old 01-29-2009, 12:59 PM   #2483
kafanylovesme
kafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfectionkafanylovesme is close to perfection
Send a message via AIM to kafanylovesme
Can you PM me how much you can get those BRIG pads for? S14 pleasee.
Originally Posted by PHLIP View Post
Fuck, I wouldn't let 30 year old seasoned veterans drive my car to the grocery store a quarter mile from my house, let alone a young/dumb/full-of-cum teenager.
kafanylovesme is offline
Old 01-29-2009, 02:00 PM   #2484
DC Dan MAX USA
Trader Rating: (79)
got it, see you soon.
I think they are about $150 shipped from Japan.
Old 01-29-2009, 08:07 PM   #2485
Marcus
Marcus's Avatar
Trader Rating: (18)
Marcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfectionMarcus is close to perfection
Feedback Score: 18 reviews
you can go to industrial liquidators. they got em. sammich plates, lines and a shit ton of different sized coolers. i recently priced one out, (avg sized cooler+plate+lines) 250bucks.
Dan, have the stickers been cut yet?
btw, the coils/arms were awesome for drift(obviously) AND track (grip) events. impressed.
Marcus is offline
Old 01-29-2009, 10:54 PM   #2486
w0nderbr3ad
Trader Rating: (50)
sweet shit.thanks marcus
Old 02-01-2009, 05:22 PM   #2487
Flipzide
Flipzide's Avatar
Thank you Parts Shop MAX. You made my subframe pretty and adjustable to my needs.
Expect an order for a hydraulic brake from me in the future !
Flipzide is offline
Old 02-01-2009, 10:46 PM   #2488
aa87
aa87's Avatar
aa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant futureaa87 has a brilliant future
Send a message via AIM to aa87
Any word on those solid bushings to raise the subframe?
Hookers and blow.
aa87 is offline
Old 02-02-2009, 03:09 AM   #2489
JayDee M Rolly
JayDee M Rolly's Avatar
JayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really niceJayDee M Rolly is just really nice
Send a message via AIM to JayDee M Rolly
will the Ikeya Tie Rods fit oem tie rod ends?
-Lloyd
Originally Posted by Taniguchi_Is_#1 View Post
are you an angel? because i want to put my penis in your vagina.
http://yourenotdown.net/
JayDee M Rolly is offline
Old 02-02-2009, 03:22 AM   #2490
Z33dori
Z33dori's Avatar
yes. Dan actually recommends oem S14 ends
Z33dori is offline
