Old 02-28-2009, 03:45 PM   #1
DDDsquad_s13panda
DDDsquad_s13panda is making a name for him/her selfDDDsquad_s13panda is making a name for him/her self
DID SOME UPGRADES.. now my car idles @ 1500
:SR20DE: S13
Alright after 4-5 months my car have been down. i finally had some money to get it fix and also put some upgrades on.
255 WB fuelpump
Freddy intake manifold
Z32 TT fuel filter
370cc injectors with DET rails
I change my TB because my original one broke so i used a G20 TB which was about the same but i had to fabricate it so it sits right with the cable. And i also detach the TPS to do so.
Now my car idles @ 1500 warm.
I took off the cable from the TB thinking its just adj, but still idles @ 1500.
I also took off the TPS off of the TB itself but it still holds @ 1500.
What could be wrong??...
SOB!!!!!
DDDsquad_s13panda is offline   Reply With Quote
Old 02-28-2009, 03:50 PM   #2
kevtrinh
kevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond reputekevtrinh has a reputation beyond repute
adjust your throttle body butterfly valve
Team Pterodactyl
kevtrinh is offline   Reply With Quote
Old 02-28-2009, 03:55 PM   #3
DDDsquad_s13panda
What do u mean? that lil stopper screw? Because i took the cable off of the TB thinking it wasnt letting it close all the way. But it does or so i think so.
Old 02-28-2009, 04:00 PM   #4
irritatedmax
irritatedmax's Avatar
irritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enoughirritatedmax will become famous soon enough
check your timing? you might have adjusted the tps without realizing it.
this is procedure for ka's not sure if the sr differs.
KA-T.org - The Home of 1000+ whp/7 sec Turbo KA's
irritatedmax is offline   Reply With Quote
Old 02-28-2009, 04:24 PM   #5
DDDsquad_s13panda
That be so easy if my stupid ass timing gun is working, but i broke it =[. Fucking aye.
Thanks for that info though.
Old 02-28-2009, 04:31 PM   #6
opponheimer
opponheimer's Avatar
opponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond reputeopponheimer has a reputation beyond repute
adjust your IACV idle set screw. can't believe all these dumbass posts. you need to unplug your tps before you adjust it.
opponheimer is offline   Reply With Quote
Old 02-28-2009, 04:37 PM   #7
DDDsquad_s13panda
Most reasonable answer. Thanks. Ima try that out right now!
Old 02-28-2009, 06:46 PM   #8
DDDsquad_s13panda
Dang, iono how im suppose to do that but it still holds @ 1500rpm, i pretty much tightened it up all day, because when i was loosen it, the RPM was getting higher.
ill try and search for another method tomorrow.
Old 02-28-2009, 07:00 PM   #9
mxexux
mxexux's Avatar
mxexux is an unknown quantity at this point
I think he means to check the throttle timing which is what nissan calls it when you adjust where the TPS sensor reads WOT and closed throttle. The manual has the procedure to follow.
mxexux is offline   Reply With Quote
Old 02-28-2009, 08:01 PM   #10
opponheimer
this should be your FSM, look for mxexux's procedure he speaks of
http://www.nicoclub.com/FSM/240sx/180SX_SR20DET.pdf
sorry but its all in japanese
Old 02-28-2009, 11:30 PM   #11
DDDsquad_s13panda
=/ oh man.
Old 03-01-2009, 02:21 PM   #12
DDDsquad_s13panda
no more other inputs on these?
Old 03-01-2009, 04:25 PM   #13
ESone3
ESone3's Avatar
ESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of lightESone3 is a glorious beacon of light
sounds like vacume leak or TPS adjustment, or it might be broken.
www.illgarage.com
ESone3 is offline   Reply With Quote
Old 03-01-2009, 04:38 PM   #14
DDDsquad_s13panda
vacuum leak?. wont the car shut down with a vacuum leak?
Old 03-01-2009, 05:17 PM   #15
ESone3
ESone3's Avatar
nope
check all your vacume lines and all ports on the intake manifold
www.illgarage.com
Old 03-01-2009, 08:23 PM   #16
DDDsquad_s13panda
??? hmm damn. oright ill give it a look thanks.
