#32 |
FSM says 130-145 ft-lbs.
You've used all your free hand outs. Please get yourself a copy of the FSM before you approach any further.
*SoSideway's iTrader Rating!!* ***SoSideways' Review Thread!!*** http://sosideways.wordpress.com/ Last edited by SoSideways; 11-19-2008 at 09:01 AM.. Reason: Put up figures for the R200 and not R200V at first |
#33 |
What size shims did use guys use because i dont want mine to act like a welded diff really but i dont want it to be weak sauce either. I was considering using a one 1.25mm shim. Any insight is appreciated
91 Sil80-Sold, LS2 Powered 1997 240sx-Traded, 2005 350z-Sold, Whats next? |
#34 |
![]() Join Date: Feb 2005
you have to use the correct shims so the backlash is within stock spec.
edit, why not just buy a welded diff/get yours welded. this is ghetto and your old ass lsd is gonna break faster than normal.
#35 |
![]() Join Date: Oct 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 11 reviews
does it lock just like a welded diff? I rather do this and get a 1.5 type around town than a fully locked diff.
AIM SoarinStrong[B]STRONG 6iX[B] RB single turbo ///Work AMKREAD 180sx |
#36 |
I dont want a welded diff that shit is too brut for me right now I drive my car alot now and dont feel like dealing with that crap all the time.
#37 |
![]() Join Date: Dec 2007
![]() ![]() Feedback Score: 1 reviews
i say just add a 1.01 shim and you should be good even replacing the stock shim with a new one will not give you the lock up you want so just add a 1.01 and you should lock up pretty close to how a 1.5 locks up the only thing i dont know about this mod is how long you vlsd will last but from some of the people that have done this say the vlsd wont make any noises after breaking it in with a couple figure 8 patterns like some of the other members in this thread.
#39 |
![]() Join Date: Mar 2007
A buddy of mine did this... We had allot of noise when the clutches engaged.
We used some chevy lsd additive and it cleared it up Any1 else had a problem with this?
88 Rx7 Convertible - Low, Slow, Nice 89 GTUs - Track slut / Missile |
#40 | |
I didn't think there were CLUTCHES in a VLSD? |
#42 |
What?
Unless he has a multiplate clutch assembly, I don't see how there could be "CLUTCHES" on a car, unless he was talking about the LSD clutches, which an VLSD do not have. |
#43 |
![]() Join Date: Aug 2003
automatics have multiple clutches, though i am not sure if the nissan 240 automatic trans is that type..
it could also be a typo
Drives a BRZ and is building a V6 S12 coupe. |
#44 |
My mistake* To my understanding I thought a vlsd was a clutch type..
#45 | |
A VLSD is based on the viscous fluid dynamic to create a "drag" between the 2 halves inside the differential. When 1 wheel starts to spin, the guts of the VLSD, more importantly the viscous fluid, will start to drag the other half along with it, creating a "differential" type effect, where both wheels are spinning. A good example of this would be to take a glass of water, put some ice in it, and wet down the surface where the glass of water will sit on, and start spinning the glass. You should see the glass go first, then the ice will eventually start spinning along with the glass. That motion is the same type of motion that happens inside a VLSD. It has no clutch plates like the clutch type LSDs do. Helical LSDs also do not have clutch plates. Helical LSDs are all gear based, no clutch plates. |
#47 |
![]() Join Date: Oct 2006
wtf are you talking about??? read the thread mr 1 post new guy.
the shim goes between the diff head and the viscous coupler.
HREs on a S13 - check, 6262 - check, Girlfriend.... - nope |
#49 |
The diff came from the factory with ONE (1) shim, you either replace that one or stack on 2 littler ones to get a thicker effective height, what is so hard to understand about this?
#50 |
i understand it all. im not retarded. on another site the guy had the center section of the diff taken out where the spiders where showing..completely out. was just wondering..i get the fact that you dont have to
#51 | |
![]() Join Date: Jul 2007
paper gasket ftw ![]()
#52 |
Trader Rating: (106)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 106 reviews
What shim originally comes in the diff? I am thinking about doing this, but I only want to make a small difference. I figure if I replace the stock shim with one that is one or two sizes thicker it should do just what I want. Since my car is a trackday/autocross car I really don't want the diff to lock in an aggressive manner.
#53 | |
#54 | |
Banned from the Marketplace
Heres what I suggest: Being that they are only a couple dollars, order 1.01 and 1.25. Open your diff and compare the shim that is in there to the 2 you bought, and base that off which one you choose for your application, then just go return the one you didn't use. |
#56 |
![]() Join Date: May 2003
Me and motegi did it at the same time.
Its pretty awesome, I snapped my axle boots and have a lot of play. Don't forget to align the splines to the axles before you tighten down the phillips screws after putting in the shim, it keeps you from ahving to take everything apart. But yeah, shim size can vary, me and motegi's had different shims from the factory (we assume), I just plopped a random old one i had in a junk vlsd i had sitting around, no problems, no whines, no issues. I traded my welded out for that, and im a million times happier (although my welded had some backlash adjustment issues which annoyed me.)
Hookers and blow. |
#57 |
![]() Join Date: Feb 2007
Trader Rating: (40)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 40 reviews
AVAILABLE SIDE GEAR THRUST WASHERS
Type R200V Thrust washer Thickness mm (in) Part number 1.49 (0.0587) 38424 40F830.80 (0.0315) 38424 40F60 0.83 (0.0327) 38424 40F61 0.86 (0.0339) 38424 40F62 0.89 (0.0350) 38424 40F63 0.92 (0.0362) 38424 40F64 0.95 (0.0374) 38424 40F65 0.98 (0.0386) 38424 40F66 1.01 (0.0398) 38424 40F67 1.04 (0.0409) 38424 40F68 1.07 (0.0421) 38424 40F69 1.10 (0.0433) 38424 40F70 1.13 (0.0445) 38424 40F71 1.16 (0.0457) 38424 40F72 1.19 (0.0469) 38424 40F73 1.22 (0.0480) 38424 40F74 1.25 (0.0492) 38424 40F75 1.28 (0.0504) 38424 40F76 1.31 (0.0516) 38424 40F77 1.34 (0.0528) 38424 40F78 1.37 (0.0539) 38424 40F79 1.40 (0.0551) 38424 40F80 1.43 (0.0563) 38424 40F81 1.46 (0.0575) 38424 40F82 |
#58 |
Trader Rating: (40)
Just felt like adding some other pics I though would be nice to include on this thread:
2003 350z ![]() ![]() Last edited by UNISA JECS; 04-19-2009 at 12:27 PM.. |
#59 |
![]() I bought 38424-40F82 and 38424-40F83 I'm gonna go try the smaller one first for a while |
#60 |
Trader Rating: (40)
Does anyone here use a micrometer to measure the old shims to determine what size shim to go with when doing this mod or is everyone doing inni minni mini mo...???
