Old 04-29-2009, 07:41 PM   #1
khilgers
khilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond reputekhilgers has a reputation beyond repute
How To: Repair cracked lips, bumpers, etc.
So I had a bit of an incident at USAIR last fall and unfortunately my front lip was the victim. It is a trust gracer front lip and the material is a very brittle, almost PVC like plastic. It doesn't really flex much before it breaks. Well since I had some experience doing plastic repair when I fixed my side skirts, I figured I could fix the lip in a similar manner.
The method below can be used for bumpers, lips, side skirts, etc. I'm no expert on this, but it has worked for me in the past and I was happy with how everything turned out.
This is the part I started with, which was originally 6 pieces.
Step 1
Pick up some plastic weld epoxy. This can be found at most auto parts stores. I got mine from NAPA for about $6. It is a 2 part epoxy that once mixed will form a bond with incredible strength. For my application I used about 7 tubes of this.
Step 2
Prep each joint by filing down the edge to about a 45 degree angle. This will help with speading out the epoxy and getting the most surface area for the repair to bond to. I chose to use a 12" flat file, it worked really well and rather quickly. Also sand around each joint about 2" so that you are bonding plastic to plastic. I chose to use 80 grit to start with and I also sand the back of each joint. If you have a crack that you are fixing, I like to drill a small 1/8" hole at the end of the crack to help minimize the chance of the crack spreading after the repair has been made.
Step 3
When joining 2 pieces I chose to use a couple zipties to temporarily hold the part in place while I apply the epoxy. Squeeze out the plastic epoxy onto some cardboard or something similar. Mix the 2 parts together and you will have about 2 minutes to work with until it starts setting up. Once you get the initial epoxy put on, let it setup, then you can remove the zipties and finish filling the joint.
Step 4
Make sure to also epoxy the back of the part. I chose to lay it on pretty heavy where I can. Most of the front lip doesn't actually touch the bumper so I was lucky there.
Step 5
In spots where the repair WILL NOT be noticed I like to drill some holes, run zipties through it, then epoxy right over it. This adds a good amount of strength and it won't really be seen.
Step 6
This is pretty much where it really sucks. Now all the extra epoxy needs to be sanded smooth and blended in. I like to start out with 80 grit to get the majority of the extra epoxy. The first sanding you just want to get it smooth again, and you will be doing several small skim coats to get it perfectly smooth. I used a flexible 6" body filler spatula thing and it worked out great. Once you have it all smooth you can step up to the 120 grit. Sand the entire part smooth, filling in any imperfections with more skim coats of the epoxy. Eventually you will go up to 220 grit, then eventually to 400 grit wet sand. Once that's all done, you will have something like this. Keep in mind that just these 2 joints took me about 5 hours to fix. Throw some primer on it and it's ready to go.
This took me about 15 hours to fix and it will be painted on sunday, thanks to my sponsor Underground Paintwerks.
khilgers is offline   Reply With Quote
Old 04-29-2009, 07:49 PM   #2
s13dan
s13dan's Avatar
s13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enoughs13dan will become famous soon enough
you can feather your edges out a lot more. And i dont think leaving the zipties in is a good idea. Its also not a bad idea to identify the plastic and maby get a repair kit for the particular type of plastic. Im glad we have a write up on this, just make sure its right.
89 240sx hatch #933-the hot rod
91 240sx coupe #131,603-the daily
s13dan is offline   Reply With Quote
Old 04-29-2009, 07:51 PM   #3
DreamN
DreamN's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Not bad, good write up.
Friend and I swear by JB Weld for small cracks that require a quick repair.
- Jimmy
Wanted:
TBD
For Sale:
TBD
Old 04-29-2009, 07:57 PM   #4
sked707
sked707's Avatar
sked707 is an unknown quantity at this point
Nice writeup! might just pick up some of that epoxy to fix my broke bumper
sked707 is offline   Reply With Quote
Old 04-29-2009, 08:02 PM   #5
khilgers
I'm by no means an autobody expert this just worked for me and I figured it was worth sharing. The lip is made out of urethane and my side skirts were ABS plastic. This method worked great on both types of plastic. As for feathing out the edges I used no filler on this. I thought that filler would crack when I hit something, which is gonna happen again sometime. All of the repair was made with the epoxy and sanded smooth.
Old 04-29-2009, 08:04 PM   #6
khilgers
I fixed a friends spare integra bumper this way. I'm also gonna fix my friends elantra bumper.
Old 04-29-2009, 08:40 PM   #7
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
you should start with 180 grit sand paper instead of using 80. 80 is a bit too rough it still leaves scratches. and then move to 220 after that and so on.
plastic welds are the shiit i've used them that alot but there are better plastic epoxy welds and they are better than ones at the auto stores. industrial plastic epoxy welds are better and are stronger than the ones you've used.
since youre local you can holla at me on d-town. when youre not busy give a holla i'll give some tips and tricks of what i've learn over the years.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 04-29-2009, 08:49 PM   #8
karl wasabi
karl wasabi's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
holly hell. good shit. I'll have to try this instead of just using zipties as the only fix. haha.
karl wasabi is offline   Reply With Quote
Old 04-30-2009, 12:13 AM   #9
artdrifter
artdrifter is an unknown quantity at this point
I wish i wouldave known about this
artdrifter is offline   Reply With Quote
Old 04-30-2009, 07:22 AM   #10
aznpoopy
aznpoopy's Avatar
i did this with a zenki gracer lip as well. the epoxy ripped away from the cracked lip after about two weeks of scraping it on stuff. the big old mass of epoxy was still intact, including a ton of smeared epoxy holding it together on the backside, similar to how you have yours.
second time around, i ditched the epoxy and used 3m window weld. i used a whole tube of it and even caked in the area on the backside of the lip. it has held up very well. i believe its ability to flex makes it superior to epoxy for something like a lip.
imo, epoxy is better suited for stuff that doesnt get dragged on the ground or need much flex. i used it to repair greddy sideskirts that were cracking down the middle. stop drilled the crack with a small drill bit and filled the hole, the crack and smeared the backside with alot of epoxy for strength. it has held up perfectly.
Old 04-30-2009, 12:19 PM   #11
sub9lulu
sub9lulu's Avatar
sub9lulu is making his/her stupidity well-knownsub9lulu is making his/her stupidity well-knownsub9lulu is making his/her stupidity well-knownsub9lulu is making his/her stupidity well-known
JB weld has been treating me pretty good
sub9lulu is offline   Reply With Quote
Old 04-30-2009, 12:29 PM   #12
ixfxi
Guest
Posts: n/a
dude, you guys are wasting time with that off the shelf cheap shit...
google "lord fusor" they make some pretty good adhesives THAT ARE SPECIFIC for the types of materials you are bonding to. many body shops use this stuff, or 3m products.
off the shelf stuff is WEAK
Old 04-30-2009, 03:11 PM   #13
origin_s135
origin_s135's Avatar
origin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfectionorigin_s135 is close to perfection
can i use this method with fiberglass?
-robo
origin_s135 is offline   Reply With Quote
Old 04-30-2009, 03:15 PM   #14
khilgers
not sure, I've never worked with fiberglass
Old 04-30-2009, 04:48 PM   #15
xdumbxguyx
xdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to beholdxdumbxguyx is a splendid one to behold
i just fixed my friends abs plastic lip last night using a sodering iron.
made some stitches first then spread the plastic evenly feels solid again
needs some prep work before paint
lip was broken into 2 pieces and now back into 1 piece
xdumbxguyx is offline   Reply With Quote
Old 04-30-2009, 05:06 PM   #16
s13dan
s13dan's Avatar
180 grit is the recommended grit. I Feather edge pretty far, so that i can rebuild the area with the plastic fillers(3M EZ-Sand i like the most)... I then use an adhesion promoter, and let dry for about 10 minutes.I also like to apply a mesh or plastic sheet along with the filler on the back side for strength. The I apply filler and sand up to the desired finish. But good to see ppl repairing those old lips instead of tossing em out. my
Old 04-30-2009, 05:09 PM   #17
kalypso123
(ノಠ益ಠ)ノ彡
nice work, thank you
Old 05-01-2009, 11:09 AM   #18
KoukiMonsta
KoukiMonsta's Avatar
KoukiMonsta is a well-known jackass
looks good thanks for the info
KoukiMonsta is offline   Reply With Quote
Old 05-01-2009, 11:47 AM   #19
Mr. Bean
Mr. Bean's Avatar
Mr. Bean is an unknown quantity at this point
pretty sweet, nice write up
Mr. Bean is offline   Reply With Quote
Old 05-01-2009, 01:46 PM   #20
dondochaka
Banned from the Marketplace
dondochaka is an unknown quantity at this point
You can go to HF and get one of those plastic welders.
it's pretty simple to use and it comes with plastic rods that you fuse with what you're welding.
it worked good when i cracked my piggy lip before.
dondochaka is offline   Reply With Quote
Old 05-02-2009, 01:27 PM   #21
punk138
punk138's Avatar
punk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond reputepunk138 has a reputation beyond repute
^^^Harbor Freight?
how much?
yes we still roll fenders
punk138 is offline   Reply With Quote
Old 05-02-2009, 01:46 PM   #22
Jonnie Fraz
Jonnie Fraz's Avatar
Trader Rating: (29)
Jonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfectionJonnie Fraz is close to perfection
Feedback Score: 29 reviews
Send a message via AIM to Jonnie Fraz
Originally Posted by punk138 View Post
^^^Harbor Freight?
how much?
Like $29.00 0n sale.
- Harbor Freight Tools - Quality Tools at the Lowest Prices
I have thought about trying one of these to see if they work. What is one more type of welding?...lol
Stealth-Custom-Fab.com
Jonnie Fraz is offline   Reply With Quote
Old 05-21-2010, 08:38 AM   #23
1gr8bar10der
1gr8bar10der's Avatar
Trader Rating: (77)
Feedback Score: 77 reviews
Sorry for digging up a YO thread but does anyone know how to fill a missing chunk on a bumper? Or should I just bring it to a body shop?
Old 05-21-2010, 10:16 AM   #24
Jonnie Fraz
Trader Rating: (29)
On somthing like this, I would see if you could find a torn Silvia bumper and graph in the missing piece.
Old 05-21-2010, 10:29 AM   #25
sirfallsalot243
sirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enoughsirfallsalot243 will become famous soon enough
Id probably try to find another bumper to steal that peice from, but if thats not an option, Id lay fiberglass on the inside first covering the chunk missing, and work from that to replace the chunk. Fiberglass can be a mess to work with, but it would probably be stronger than cutting a peice off another bumper and epoxying it in.
sirfallsalot243 is offline   Reply With Quote
Old 05-21-2010, 10:49 AM   #26
1gr8bar10der
Trader Rating: (77)
OK thanks a lot for the input man. I also have a Q's bumper but it's too nice to cut it up lol.
Old 05-21-2010, 11:44 AM   #27
Jonnie Fraz
Trader Rating: (29)
Yeah...Just rock the Q bumper until you find a jacked one. To put it back together there is a product called Bumper repair by SEM. The part number is 68422. Here is a link...SEM bumper repair It works awesome! I had an aero bumper that was like in three pieces when I got it. Here it is when I got done fixing it.
Good luck
Old 05-22-2010, 12:33 AM   #28
Bigsyke
Bigsyke's Avatar
Bigsyke is an unknown quantity at this point
Khilgers come over and fix mine plz.
Bigsyke is offline   Reply With Quote
Old 05-24-2010, 11:36 AM   #29
TurboSE
TurboSE's Avatar
TurboSE is an unknown quantity at this point
I've always wanted a reason to buy one of those Harbor freight plastic welders....are they easy to use? Look like they'd be awesome for OEM aero and bike fairings...
WTB: PAIR 18x10 0 to -25, less than $1500 shipped please.
TurboSE is offline   Reply With Quote
Old 05-24-2010, 10:41 PM   #30
negrosx13
negrosx13's Avatar
negrosx13 is an unknown quantity at this point
Send a message via AIM to negrosx13
nice!!!!!!!! Now i can fix my pig lip!
MORE BACON STRIPS
negrosx13 is offline   Reply With Quote
