#811 | |
#812 | |
![]() Join Date: Sep 2005
#813 | |
![]() Join Date: Feb 2006
Ive changed my setup around this turbo 4 times and have not been satisfied. I was the biggest advocate of this turbo but it is letting me down. 28 pages and I havn't seen a number to justify a .86 over a .64... that makes no sense to me... Im giving it one more shot. Soon as Im out of paint Im throwing 22psi at it. |
#814 |
![]() Join Date: Oct 2004
Personally I have seen why a .86 over a .64.....
For my setup a stock intake and exhaust manifolds, and 264 step 1 cams, to have 320HP and 270ft.lbs of torque at 16.5 psi on a dyno dynamics... I highly doubt a .64 can reach it with the same setup. Yes bla bla bla do this and that and boost up on the .64 and yeah it can do it.... But that is apples to oranges.... You have to create the same scenario with two different turbo's on the same boost level, otherwise like I said its apples to oranges. At 4800RPM I made Peak Torque and 5200 Made peak HP.... Like I said I doubt a .64 will do that on the same setup.... Keep in mind I track this car and is conservatively tuned by steve shadows..... Whatever that maybe, you can't start changing a billion things and just compare the turbos, that just isn't good statistics.
#815 | |
![]() Join Date: Dec 2006
Or a .64 wont break 320whp? Im making 363whp and 332ft lbs tq @ 21 psi on a .64 with stock cams and intake manifold on a Mustang Dyno
#818 |
The point I was making was that the power the .86 makes or can make doesn't justify (for me at least) the tradeoff in response.
Im seeing 30r's with more power and similar response to the .86. There is a thread comparing the two. It sucks because I DO NOT want to go top mount. I have a feeling this would be a great turbo on a motor with more displacement, but im not about to stroke. |
#819 |
Obee, have you considered a GT3071/3076 turbo in a bottom mount configuration? I'm sure you'll have to make some slight modifications to fit, but it might be your only option if you are not wanting to change your entire setup completely.
#820 |
Obee.... chances are these turbo's are just similar... they aren't like huge differences or anything... .64's having better response than a .86 is more closer to a myth I think .... With the right tune .86's are really good.... You aren't losing much at the bottom end but you have a very strong top end. Its all in the tune.
Why don't you have SteveShadows tune your car? I was a skeptic at first truthfully, but he is VERY good....
#821 | |
![]() Join Date: Jul 2003
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
a myth? These numbers aren't just random values assigned to the product. It is a representation of a turbine's physical dimensioning. Specifically it is the ratio of the inlet inner diameter and the center point of the inlet to the level of the radius of the turbine wheel.
HouseBuyers365.com Quote:
#822 |
I think its more than a myth, i have a friend with the same setup as i everything the same, except he has an S13 and I an S14 SR20. He is running the .86 and the spool is considerably later.
#823 |
What is considerable? Certain mods have greater affect on the turbo's spool characteristics, especially non stock intake and exhaust..... But with Stock intake and stock exhaust... its close....
#824 |
There is def a difference in spool
I've drifted a .64 and my .86. If I let my rpms drop anywhere near 3 grand its a wrap. Granted the .64 car was on stock cams so I don't know how relevant that is. I have Smelly live ROM tuning me. He is pretty good. I would give Steve a shot but Im not paying to fly him out here or driving to Cali. I just got off the phone with my friend. I know this is a different motor but this is what he is running. 4G63-stock head and bottom Stock intake manifold Stock Exhaust manifold ported 280 cams 3076R He says he hits at 3800, carries all the way through 8200 and makes 427whp 386lb tq. @ 27psi and peak power is 7100rpm I havn't seen a 2871 do anything like that. I do think his PSI is kinda high though. But at 22psi my car felt days slower than his. |
#828 |
Hey guys with my setup how much boost can I do before my stock sr fpr is max. I heard 12-13psi and 18psi.
555cc injectors gt2871r z32 maf stock head/block fmic enthalpy ecu for my setup thanks
#829 | |
just get a Nismo FPR or better yet a SARD
#830 |
So what will my setup be capable of ? I want to know this so I know what im getting myself into. Im not doing this for a drag queen more for track/drift and daily.
#831 | |
Couple of things that make the biggest difference....
CAMS, and both Manifolds. Stock CAMS are going to spool earlier but lose top end and vice versa..... CAMS make a huge difference on response too. Greddy Manifold is going to have you lose low end for sure... Losing low end is also response time, which you complaining about. Equal length manifolds going to lose low end also leading to slow response... Tomei or Stock or Preferably a Swain and Honed Stock Cast. Boost controllers make a HUGE difference too.... Depending on gain settings, it changes everything.... Intercooler piping design. Blitz vs Greddy vs HKS vs Ebay.... Its a big difference.... Stock vs Lightened Flywheel Finally actually better clamps on pipes and couplers make a different too.... Thats just it.... Quote:
#832 |
Yes those facts are a given. But the bottom line is with comparable setups the .86 just doesn't preform how it should.
nissans13 your fpr will not be your limiting factor. Ive run 22psi on stock fpr and not run out of fuel. |
#833 |
Its not how it SHOULD perform hahaha, its how you want it to perform.....
Maybe try IHI turbines, or HKS GTRS, I think you will be more happier with performance and power.... Garretts are just blah.....
#837 |
Yeah you need a 6 cylinder.... Was tuning my friends 2JZ... its so smooth on a T78 compared to our 4 bangers that sound like rattling a tin can with a rock in it....
#838 |
