Subframe bushing removel
so how did you remove stock bushings?
ive seen fire used has anyone taked them off differently.
you better cut, weld, and paste that sh!t http://zilvia.net/f/sale-items/24340...kets-more.html |
![]() Join Date: Mar 2003
burn it out as much as you can, then cut through the remaining metal collar with a sawzall. be careful not to notch the subframe.
once the metal collar has been cut through, wedge something into the cut to peel the first edge away from the surface. then jam a screw driver (and eventually a pry bar) in there, and go around and pry until you have a good portion of it loose. then hit it with a hammer and it should pop out. |
![]() Join Date: Nov 2007
Trader Rating: (18)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 18 reviews
torch the bushing till its nice and hot.
remove the center sleeve with vice-grips. ![]() CAREFULLY hacksaw the casing. be sure not to cut into the subframe itself. ![]() then use a flat head and a hammer to pound/pry out the bushing. once the casing is cut, it will collapse and the bushing will pop right out. it can be done in an hour or two, if you know what you're doing. BUT expect to spend about half an hour on the first one if you've never removed bushings before. you can use a press, but you can easily deform the subframe. BTW, did you buy some PSM solid sf risers? they are AWESOMETOWN. you will feel your diff in your ass |
![]() Join Date: Jun 2003
Trader Rating: (130)
i "taked" them off with fire. then an air chisel for the outer.
fire plus some cutting tool seems to work best im actully doing it right now, torch saw long flat tip as the pry bar it seems to be going well.
ima going to install cuirct sports alum spacers any feed back on them while we r on the subject?
![]() Join Date: Sep 2006
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 2 reviews
I did it just like the first two guys who replied did. Took a while but they all came out after a while. I used a delrin subframing bushing that I'm having a hard time finding right now, I think they were around $60 for all four. I love them, after replacing those, all the rest of the bushings with a prothane kit, and having new inner/outer tie rods and front lover ball joints the car handles better than what I would expect from the factory.
the bushings where bad so i was just going to put new bushings in along with the spacers or should i just put in solid ones
![]() Join Date: Dec 2003
daaamnn epileptic much? paint looks clean but thats a damn fuzzy pic. kinda makes me wanna repaint mine tho
![]() **CoUpe LOve** Member #00 |
#14 |
Where you get the solid bushings?
OP failed, do not get spacers, even with new OEM because the spacers will just rip the new ones to shreds. Easy way to remove OEM bushings is heat up area around bushing, along with torching the fcuk out the the rubber, take a nice long hard candle and shove it in and around the metal casing area to penetrate, to further lube the removal of the casings. If the OEM bushings are still intact, and youve broken the bond with the subframe, you can use a monster cock hammer and a massive socket and pound it out. Use enough lube i.e pbblaster+candle wax and you should beble to pipe that bitch down hard enough to slide the bushing right out. |
#16 |
Burn the bushings out and cut like everyone says. It works pretty well, and is relatively painless.
I had mine sand blasted and powder coated lime green. Link to pics in my sig. |
#17 | |
Trader Rating: (18)
LOL my bad, i was actually falling while i took that pic. hah OP:::hope this was of help. what kind of bushings did you buy to replace the old ones? iirc, the sf spacers only work with oe bushings right? i got the solid subframe risers from POWEREDBYMAX. they actually push up your subframe and help correct suspension geometry. RUSTOLEUM FTW lol |
#18 |
![]() Join Date: Jun 2004
Man, replacing the subframe bushings is such a mess, you can do it quick but it really is allot of labor.
and I hate loosing goose rear ends too...
[email protected] |
#19 |
I just did this and i removed the stock ones using a torch, but i didn't melt the shit out, you heat up the outside of the subframe so you make the metal hot enough you can loosen the bond between the rubber bushing and metal.
it does take time and patience, but yeah, of course it's gonna take time if you want to do it right and feel accomplished. too me 7 hours. ![]() ![]() so just get a regular torch from home depot. drop the subframe. just heat up the outside as good as you can with the torch to loosen the bond. just jimmy a screw driver in there and pick it out, again each one takes around an hour. then get a drill and a wire wheel to buff the inside to remove all the rubber that is still stuck. LET ME MAKE THIS VERY CLEAR, IF YOU USE THE ENERGY SUSPENSION POLY BUSHING REPLACEMENTS (NOT INSERTS) YOU MUST NOT DAMAGE THE OUTER SHELL OF THE BUSHING IF YOU HAVE AN S13. I REPEAT, DO NOT BE A DOOSH AND DAMAGE THE OUTER SHELL OF THE ORIGINAL BUSHING IF YOU HAVE AN S13. ![]() if anyone has a question about this please feel free to PM me, i went through the process recently and it was actually very painless because i had the proper tools and patience. oh yeah, my rear is friggin TIGHT now. |
#20 |
Torch the bitches.
dont use spacers and new bushings. If you want a stiff ride get aluminum bushings ftw.
"Im a god mother fucker and its judgement day!" |
#21 |
7 Hours!
Holy hell, thats a long time..
[email protected] |
#24 | |
![]() Join Date: Dec 2002
#26 |
![]() Join Date: Nov 2006
![]() ![]() Feedback Score: 9 reviews
If i do use a solid subframe spacer (pdm), what's the outcome? I already have solid subframe spacers, and my bushings are shot, you guys suggest i just slide the solid spacers in or do the bushings?
www.tm-spl.com Kouki's & some apple juice. |
#27 |
Super Moderator
![]() Join Date: Jul 2007
Trader Rating: (29)
![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() ![]() Feedback Score: 29 reviews
does it includes parts and labor? i got a quote for about 300 for labor only. then again, i'm pretty sure he was just messing with me and if i do actually do it, it'll be more lol.
#29 |
#30 |
oh shit i gotta get one of those haha.
yeah i mean i'm talking 7 hours start to finish meaning start the clock at jacking the car up, stop the clock at getting the car on all 4 wheels. i was by myself so it's hard to fenagle the subframe back up there. yeah i don't know why these poly bushings don't have more popularity. i mean yeah, aluminum ones are awesome, but these are fantastic too. |
