Old 07-14-2009, 02:11 PM   #1
rains14
rains14's Avatar
rains14 is just really nicerains14 is just really nicerains14 is just really nicerains14 is just really nicerains14 is just really nicerains14 is just really nicerains14 is just really nicerains14 is just really nicerains14 is just really nice
how do I make a jdm s13 gauge cluster work
Hi I have 1990 s13 that has a sr20det in it ,it has a single cam gauge cluster in it right that does not reed the rev or speed so I'm going to pick up a jdm s13 gauge cluster will it just go in or is there more parts/ work that need's to be done to make it work thx guys for the help
rains14 is offline   Reply With Quote
Old 07-14-2009, 02:13 PM   #2
bardabe
bardabe's Avatar
bardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfectionbardabe is close to perfection
Send a message via AIM to bardabe
it's plug and play dude. just make sure to get the same kind of cluster you have, if you have HUD or Analog get the same style.
reference
analog
HUD
Review Thread
bardabe is offline   Reply With Quote
Old 07-14-2009, 02:33 PM   #3
rains14
rains14's Avatar
cool thx I have a Analog and I'm getting a Analog jdm
Old 07-27-2009, 06:42 PM   #4
rains14
rains14's Avatar
ok I just put in the jdm Analog cluster and it did not work, works the same as the k24e gas and temp are good but no rev or speed there's power going to it and all that but it's just not working , could it be cuz the car was a auto be4 plz help thx what sould I look 4
Old 07-28-2009, 07:54 AM   #5
rains14
rains14's Avatar
do I need to take parts from one cluster and put it on the other? plz help
Old 07-28-2009, 08:12 AM   #6
burnsauto
burnsauto's Avatar
what speed sensor are you using?
Old 07-28-2009, 09:25 AM   #7
FRoSt415
FRoSt415's Avatar
FRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura aboutFRoSt415 has a spectacular aura about
Send a message via AIM to FRoSt415
well u stated u have a sr20det, u need to change ur speed sensor so u can read the speed and tach. i would recommend that u just get a cluster from a junkyard. If it is from a dual cam u shall have to change out the speed sensor to a dual cam speed sensor. either way u need to change the speed sensor if u want to keep ur jdm cluster or just get dual cam cluster and still change ur speed sensor. Basically Get a speed sensor either froma junkyard or shop online and get one. Also dont geta jdm speed sensor just because u have a jdm engine a usdm dual cam cluster probablly would have been cheaper and easyer to get then the jdm FYI
FRoSt415 is offline   Reply With Quote
Old 07-28-2009, 09:47 AM   #8
rains14
rains14's Avatar
well I got the jdm from a friend for $40 but what I care the most for is the rev to work how can I make that happen ? there power going to it and all that but it's not working
Old 07-28-2009, 10:39 AM   #9
Slip&Sliden 240
Slip&Sliden 240's Avatar
Slip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfectionSlip&Sliden 240 is close to perfection
speed sensor will not affect the tach working. I think the wiring was not done right when the SR swap was done. Under the dash by the ECU there is a white plug that leads from the ecu, and plugs into the dash harness. Has that been converted? Is it pluged in? Are the Yellow/red stripe(tach signal) Yellow/green stripe (speed signal) connected?
PS. The JDM and USDM speed sensors are the same no need to swap them
Slip&Sliden 240 is offline   Reply With Quote
Old 07-28-2009, 08:51 PM   #10
rains14
rains14's Avatar
I do have the Yellow/red stripe(tach signal) hook up and I may sure there was a power from the ecu to the dash harness and to the Analog cluster and still no rev where did I fu"" up is it ok to use the k24e dash harness or do I need the k24de dash harness or do I need to do something ? thx
Old 07-29-2009, 02:05 AM   #11
kevmeistah21
kevmeistah21's Avatar
Trader Rating: (68)
kevmeistah21 is an unknown quantity at this point
Feedback Score: 68 reviews
Send a message via AIM to kevmeistah21
here's alittle example just incase you need it.
http://zilvia.net/f/s-chassis/248941...r-cluster.html
Late Night Crew... #02 <3
Bought anything from me? Please leave me a review!
http://zilvia.net/f/private-sellers/...meistah21.html
kevmeistah21 is offline   Reply With Quote
Old 07-29-2009, 08:31 AM   #12
rains14
rains14's Avatar
thx but what I would love to know is how to get my revs to work
Old 07-29-2009, 08:44 AM   #13
teamsprock
teamsprock's Avatar
teamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the roughteamsprock is a jewel in the rough
go to frsport.com (they have a tech section on the left hand side of the page, scroll down a bit) and verify that your wiring is correct and that all your plugs are connected properly. If that doesn't work, get the FSM and a test light or mulimeter and start checking for voltages.
teamsprock is offline   Reply With Quote
Old 11-15-2009, 04:50 PM   #14
SilviaAura
SilviaAura's Avatar
SilviaAura is an unknown quantity at this point
i have the same problem...but everything works fine on my boost controller...but i will defenatly try all of this wen i get a chance...i tried to convert the harness but i guess i did it wrong so i will try all this again...=]
SilviaAura is offline   Reply With Quote
