![]() I have some parts that I would like to clear out of my garage and in the process get more funds to buy other upgrades. All prices are before shipping, add 3% if using paypal. Local Socal people can arrange a pickup if needed and some I might be able to deliver for.
Snow Performance Methanol Injection Kit (stage 2): $450 for everything with all the extras/upgrades - Upgraded 220psi Pump (150psi is the regular one) - Upgraded solenoid (new, never installed, Cost $50) PN# 40060 - 375mL nozzles (x2) - Variable injection controller (gradually increases injection from 8psi all the way up to 25psi) - Safety Injection Module (in case you run out of fluid or for some reason have an interruption in methanol injection it will lower your boost or retard your timing to save your motor) - Cost $159 - Hardpipes with bungs welded on (you need couplers and clamps) - No tank, the windshield washer fluid tank was used utilizing the low level indicator light - All manuals, everything needed to install ![]() ![]() ![]() Stock Tail Lights (all three pieces) in excellent condition. I have some leftover sealant, but you will probably need more. Sorry for the dust: $100 ![]() ![]() ![]() I have 2 of these leftover rolls of the weather sealant ![]() OEM 1990TT Rear Traction Rods: $15 each ![]() STILLEN Front Crossdrilled rotors (11"x30mm): SOLD ![]() ![]() STILLEN Front Tension Rods (adjusts Caster). I had an alignment shop say they could not get one of them loose to adjust it, so I got a new set. If you can get it loose they will work fine, or just leave them in the current position which should be okay: SOLD ![]() 1990TT OEM front 30mm calipers with Stillen metal matrix pads with some life left in the pads: SOLD ![]() AMS 3” Expansion Down pipes (5 bolt) with O2 bungs (new, never installed): $300 ![]() AMS TT Exhaust Manifolds (new, never installed): $450 ![]() OEM TT Precats/downpipes: $60 ![]() OEM Rear suspension dampening adjusters: $10/pair ![]() OEM shift knob: SOLD ![]() SS Braided brake lines: SOLD Sway bar end links (front OEM, rear Stillen): $30 ![]() CX Racing FMIC 3” Core with couplers, piping, and T-Clamps (prefer local pickup or I can deliver for some people), new, never installed: $300 ![]() OEM TT SMICs - $60/pair ![]() ![]() OEM TT HICAS Actuator - $50 OEM TT HICAS Rack - $60 ![]() Tokico HP shocks with Eibach Prokit Springs (approx. 25k miles) - $250 One of the mounting studs on the rear is a little larger, you will either need a 14mm nut or swap in a 12mm stud/nut like the rest of them. I am assuming the installer snapped a stud and used what he had laying around. Dust boots are shot from being in a really hot/dry climate. No problems with them, just upgraded to coilovers. ![]() ![]() ![]() Prefer PM or email [email protected] Located in Palm Desert, CA. But I make trips to the Long Beach area almost every week if you need delivery. Kevin Last edited by KevinZtwin; 05-17-2010 at 10:15 PM.. |
Z32TT: Front Calipers: SOLD
Stillen Tension Rods: SOLD Stillen Brake Rotors: SOLD Shift Knob: SOLD Everything else: Available Last edited by KevinZtwin; 05-17-2010 at 12:08 AM.. |
#7 | |
460
brakes, eibach, fmic, meth, z32 |
