Old 05-24-2010, 01:31 AM   #1
moses
moses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-knownmoses is making his/her stupidity well-known
s13 FML... I'm done for now with sr's and maybe 240's
This is the second time I rebuild an sr and the third time it shit out on me. I don't even know if I want to rebuild another sr. I was suppose to drive half way across America with this motor and it made it a quarter mile. For those who don't remember my first rebuild was after my turbo FODed out so I did headgasket and cams. Then I killed my #1 cylinder with detonation as shown in the pic.
I found out that my fuel pump did not have enough voltage at full boost after thing else checked good so I hard wired it. Then after fully rebuilding it, I broke it in 500 soft miles and ran it at 15lbs (stock boost for actuator) after and everything went good and checked good the night before. I warm up the car for a 2000 mile drive the next day and down the road it shuts off.
I find
then
that little bump is the piston pin! Yeah destroyed! I don't want to fix it right now, I just want to know how it happened? I think spun bearing but I really don't know what that involves. It's not detonation like the first time because it's not melted, it's just in a bunch of big pieces. Y?
Thats what I said
moses is offline   Reply With Quote
Old 05-24-2010, 02:05 AM   #2
sectorjeff
sectorjeff's Avatar
sectorjeff is an unknown quantity at this point
Damn dude that sucks. At least drop a bone stock ka just for your dd
sectorjeff is offline   Reply With Quote
Old 05-24-2010, 02:06 AM   #3
Ceepo
Ceepo's Avatar
Ceepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enoughCeepo will become famous soon enough
yeah, throw a ka in there and redo the sr slowly
Ceepo is offline   Reply With Quote
Old 05-24-2010, 02:08 AM   #4
shiftdrift
shiftdrift's Avatar
Trader Rating: (42)
shiftdrift is an unknown quantity at this point
Feedback Score: 42 reviews
or build a ka-t....just saying.
shiftdrift is offline   Reply With Quote
Old 05-24-2010, 02:13 AM   #5
mmdb
mmdb's Avatar
mmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymoremmdb is not welcome here anymore
wouldn't have that problem with a LSx v8 :B Keep at it and learn from what happened. It'll serve you a lot in the future. Good luck.
.25 till 3
mmdb is offline   Reply With Quote
Old 05-24-2010, 03:00 AM   #6
Slammed Assassin
Slammed Assassin's Avatar
Trader Rating: (34)
Slammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud ofSlammed Assassin has much to be proud of
Feedback Score: 34 reviews
Send a message via AIM to Slammed Assassin
that sucks bro.. just keep on going and dont give up..try a different route.
Slammed Assassin is offline   Reply With Quote
Old 05-24-2010, 03:11 AM   #7
spools420a
spools420a's Avatar
spools420a is a well-known jackass
dude what makes you think that the second time wasnt detonation?or even pre ignition
1. you have a sark plug thats near disinigrated
2. you have a hole in your piston with a broken wrist pin
3. last rebuild you melted a piston
um whats your setup?I bet this could have been prevented with a wideband and a cheap $300 water/meth injection but again whats your setup you do have some serious heat issues.(detonation/pre ignition is my bet)
spools420a is offline   Reply With Quote
Old 05-24-2010, 08:56 AM   #8
moses
I don't think it was detonation because the spark plug is not melted off like the other time. I don't know if you can see it but the part that curves out on the plug is smashed in and the ring is black from running rich. There is also pieces chuncked off in the cylinder and I can not seem to move the motor at all. I'll pop the head off later to see what really happened but it looks like the piston slamed into the spark plug and valves but I don't know how or why that happens.
Old 05-24-2010, 11:05 AM   #9
fcdrifter20
fcdrifter20's Avatar
Trader Rating: (44)
fcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to beholdfcdrifter20 is a splendid one to behold
Feedback Score: 44 reviews
did you change those wrist pins out when you rebuilt it?
fcdrifter20 is offline   Reply With Quote
Old 05-24-2010, 11:43 AM   #10
jspaeth
jspaeth's Avatar
I did a ton of research these weekend on spark plugs.
I know A LOT of people run the BKR7E....but that plug is ISO spec, meaning the distance from the seating surface to the tip of the top is about 4 mm or so shorter than a JIS spec plug, which our cars are SUPPOSED to run. Some people have experienced poor contact with the coilpacks due to this....
I am not sure (I doubt it) if this conributed, but next time go with a JIS spec plug.
The relevant part number is
BCPR7ES-11 (Stock number 1095)....they come gapped at 0.044 so you have to close that down a bit.
Also, the BKR7E is a v-power tip.
As far as I know, ALL of the V-power tip NGK plugs are ISO length....sucks....
Daily driven
Old 05-24-2010, 02:04 PM   #11
moses
Of course I changed those pins.
And coil packs not hitting the spark plug would cause the opposite of detonation and exploding piston. Good info tho. You should make sure that's in sr FAQ
Old 05-24-2010, 02:26 PM   #12
S14DB
AFC #1
S14DB's Avatar
AFR doesn't cause detonation. Timing Does.
It doesn't matter that you were running pig rich. If you like that spark off to early that's more fuel that is burning as that cylinder is flying up.
You aren't melting shit, you're blowing shit up.
Old 05-24-2010, 02:33 PM   #13
slider2828
slider2828's Avatar
Interesting, but I never had a problem..... How about Iridiums? EIX plugs? I just checked mine these weekend and they were perfect...
AND S14DB Speaks the TROOF!!!
Turn and Burn!
Old 05-24-2010, 02:39 PM   #14
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
A lean mixture can cause detonation or "pinging" just the same as timing can. Ever gotten some bad gas? It pings like shit... A lean mixture is almost certainly what happened to the first piston pictured. Timing can't do that. Lean = heat, heat = melted shit. I also seriously doubt that it was timing that caused his latest failure as well. I suspect either an oiling issue or incorrect clearences related to that piston caused it. The way the piston came apart it looks like it seized in the bore and the rod smashed it's way through it.
Old 05-24-2010, 03:12 PM   #15
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
in other words...he should have his engine built for him...not by him...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 05-24-2010, 03:14 PM   #16
S14DB
AFC #1
S14DB's Avatar
Lean mixture melting shit is different then detonation.
Bad gas you describe is low octane or resistance to detonation. Not the air:fuel ratio. Bad gas doesn't change the A:F ratio.
I am not saying his damage was caused by detonation or running lean or both. I am saying that his statement that you can't detonate while running rich is false.
Old 05-24-2010, 04:14 PM   #17
moses
Ok ok thanks for info. Learn something new every day. I ran about 100 miles with timing off but there was no boost. I fixed it and drove 400 miles. Can it be timing if it happen in one cylinder?
And I had a shop build the short block, I did the rest. It does sound like racepar1 is right about the piston getting stuck. How could it be oil tho if the piston got stuck?
Old 05-24-2010, 05:37 PM   #18
jspaeth
jspaeth's Avatar
Of course! One cylinder has to fail before the others...the odds of all 4 going out at once is like infinitely low
Daily driven
Old 05-24-2010, 07:04 PM   #19
jr_ss
If the piston got stuck, that should be a machine shop issue. Then again, you've driven on it for 500miles, so perhaps there is an oiling issue. Siezed shit usually means lack of lubrication.
Old 05-24-2010, 08:10 PM   #20
moses
I did not know that about timing. But if the piston got stuck in the cylinder then where would the oil not be getting thru? Would a spun bearing do it?
Old 05-24-2010, 08:17 PM   #21
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
sounds like you slapped this car together without understanding alot of things..... no wonder it is in the shape it is.
g35gabby is offline   Reply With Quote
Old 05-24-2010, 08:50 PM   #22
j20accord00
j20accord00's Avatar
j20accord00 is an unknown quantity at this point
Send a message via AIM to j20accord00
^ lmao this should get good
92 Coupe ka-t
j20accord00 is offline   Reply With Quote
Old 05-24-2010, 09:51 PM   #23
moses
Because I didn't know all the aspects of how a engine can break down I shouldn't have built a motor. Haha, I'm not going to get into it online.
Old 05-25-2010, 05:32 AM   #24
bb4_96
bb4_96 is an unknown quantity at this point
Have you pulled the bottom end apart yet. I'd kinda like to know what actually caused the problem.
bb4_96 is offline   Reply With Quote
Old 05-25-2010, 06:32 AM   #25
GripTerror
GripTerror is an unknown quantity at this point
or you could go ls1 and make as much power with stock reliability and easy plug and play power gainers.
GripTerror is offline   Reply With Quote
Old 05-25-2010, 06:51 AM   #26
rex2sx
rex2sx's Avatar
rex2sx is an unknown quantity at this point
well i have a 3 pistons from my SR20DET..so if you want 1..just let me know
The same thing happened to my friends BMW, we looked down and saw the wrist...but he over revved his motor so..
SR20DET RDTOP Cylinder Head FS
rex2sx is offline   Reply With Quote
Old 05-25-2010, 06:54 AM   #27
dreamin240sx
dreamin240sx's Avatar
dreamin240sx is an unknown quantity at this point
Send a message via AIM to dreamin240sx
sounds like u have a bad case of "i have no idea what i'm doing"
RB POWA!!!!!!!!
dreamin240sx is offline   Reply With Quote
Old 05-25-2010, 07:58 AM   #28
jspaeth
jspaeth's Avatar
Some people enjoy the process of building a quality motor that is efficient for it's displacement.
Others take the easy route and slap in a SHITTY, INEFFICIENT 6 or 7 liter motor that only produces 50 hp/L. :ghey:
Daily driven
Old 05-25-2010, 09:13 AM   #29
GripTerror
And some people are clueless idiots example above
400whp and 30mpg on the highway with no turbos and something called torque and a powerband = win
You COULD spend countless thousands on a small displacement motor and push it to its limits and blow it up over and over again spend countless thousands on tuning and so on.... just to reach 400whp... OR you could spend a lil extra to begin with on a nice reliable 400whp+ with TORQUE (aka power) and a power band that's not in the sky but that gets moving from the get go... and not have to blow shit up. Whatever floats your boat.
And your ignorant ass it's 5.7liter for a ls1, it's 6liter for an ls2 and 7liter for an ls7 which produces 500bhp~ that's actually not too shabby considering a 2liter sr requires a turbo to make close to 200bhp.
I rather have a newer fire breathing v8 than a junkyard japan sr motor. The SR is not the be all end all motor.
I rather have a 4G63 than an SR but unfrotunately it doesnt go in a 240.
Old 05-25-2010, 09:35 AM   #30
rex2sx
rex2sx's Avatar
I was going to say something about his statement but i let it go. The Ls1 weighs how more than an SR..about 100lbs IIRC, and it has twice the cylinders..i didnt want to turn this into another "XXX motor is better" thread.
So people make CRAZY assumptions. At any rate LS1 FTW
