Old 11-01-2010, 11:32 PM   #1
revolutionz_s13
revolutionz_s13 will become famous soon enoughrevolutionz_s13 will become famous soon enoughrevolutionz_s13 will become famous soon enoughrevolutionz_s13 will become famous soon enoughrevolutionz_s13 will become famous soon enough
revolutionz_s13 coupe build (update 1-16)
Well, I finally started ordering parts for my car again. Its been sitting in storage for about the last 2 years, due to being broke and in school. I'm going for at least 450whp on e85, would like to see 500whp, but that might be a stretch. I still need a whole grip of parts (and money) , but I think I have a pretty good start on it. On to the parts list/pics....
Powertrain
Wiseco Pistons, 9.0 comp
Eagle Rods
ACL bearings
ARP Main Studs
ARP head studs
JWT s1 camshafts
Koyo Radiator
Garrett GT3076R turbo, .82 a/r
Tanabe Concept G catback
Nismo motor mounts and trans mount
centerforce dual friction clutch
nismo 2way lsd
c's short shifter
dual 10" electric fans
Walbro fuel pump
JWT Cam Gears
Xcessive Windage Tray w/ crank scraper
ATI super damper crank pulley
Xcessive Intake Mani w/q45 flange and SS throttle cable bracket
Xcessive lowering motor mount brackets
Cometic Head Gasket
JGS turbo mani and oil lines
AEM Fuel Rail
BC springs and retainers
supertech valve seals
BC SS Valves, Std size
Suspension:
JIC flt-a2 coilovers
cusco front tie bar
Suspension Tech. F&R sway bars
spl tension rods w/ brake cooling air deflectors
spl ruca
sentra se-r brembo calipers
r32 skyline rear calipers (might sell and get ksports front and rear instead)
JIC front and rear strut bars
autopower race roll bar
tein tie rods
TechnoToyTuning subframe collars
Energy suspension poly bushings in the rest of the arms
Exterior
SSR Professor MS1 wheels 17x9,17x10 +24, 1/4" spacers on fronts
(Yes, they are 4 lug!)
front 255/40, rear 275/40
ARP wheel studs
Bomex front lip
silvia sideskirts
What I started with, about 5 years ago:
Pulling old motor, tearing it down to send the block off, sanding it down for paint:
Block back from machine shop, car back from first attempt at paint, put on suspension parts, test fit wheels:
Bunch of the parts I have sitting in my bedroom, waiting to be bolted to something...(no longer have the emanage, sold it to get aem ems)
Parts I'm planning on collecting over the winter:
Vibrant intercooler
Synapse Synchronic WG and BOV
oil cooler
One piece steel driveshaft
ID 1000cc injectors
Spec aluminum flywheel
Spec Stage 3+ clutch
Circuit sports clutch pivot
AEM Coilpacks
AEM twinfire
AEM FPR
AEM EMS
AEM Wideband
Aeroquip -6 Fuel lines
Bosch 044 inline fuel pump (fed by in-tank walbro)
Apexi boost controller
Ksport 13" front and rear brakes
I also have some work to do in the interior, and plan on stitch welding most of the car and possibly doing tubs in the front.
Shooting to get it tuned next summer, and completely finished by next fall. Still needs alot of work, but I'll be starting on the money sucking piece of metal this week, and I'll post updates as I make progress on this current monstrosity.
revolutionz_s13 is offline   Reply With Quote
Old 11-02-2010, 12:29 AM   #2
Sergio180sx
Sergio180sx's Avatar
Trader Rating: (24)
Sergio180sx is on the path to ruinSergio180sx is on the path to ruin
Feedback Score: 24 reviews
cool build man if your gonna build a ka build it the right way like your doing
S13.4 Rb25 Neo vert
07 g35 coupe
[/B]
Originally Posted by DriftOutlaw View Post
No not at the moment but an easy fix. just swap the motor I have in and take the old one out.
Sergio180sx is offline   Reply With Quote
Old 11-02-2010, 12:40 AM   #3
MitchellBade
MitchellBade's Avatar
MitchellBade is an unknown quantity at this point
Interesting KA build.
MitchellBade is offline   Reply With Quote
Old 11-02-2010, 07:29 AM   #4
HPKMotorsports3
HPKMotorsports3's Avatar
HPKMotorsports3 is an unknown quantity at this point
im loving those rims... sweet build man +1
Originally Posted by shiftdrift View Post
you running on hopes and dreams?
HPKMotorsports3 is offline   Reply With Quote
Old 11-02-2010, 07:58 AM   #5
revolutionz_s13
Yeah, Im hoping that if I go a little overboard, that I will only break something every other week instead of every other day ahaha
thanks, they took a while to get, but now I dont need to spend money on 5 lug hubs.
Old 11-02-2010, 07:32 PM   #6
HPKMotorsports3
amen to that brother im thinking bout gettin a set of the sentra ser rims i think they look real good on coupes
Old 11-08-2010, 06:33 PM   #7
revolutionz_s13
Little update, did some work on the head over the weekend, took it all apart and smoothed out the intake runners and ports on the head a bit...didnt want to go too crazy since I dont have much experience, just wanted to smooth out the flashing from casting and take the roughness down a notch. Waiting on a some valve seals and it will all go back together hopefully towards the end of this week.
Intake mani runners before:
Intake port before:
Exhaust port before:
Intake mani runners after:
Intake port after:
exhaust port after:
cylinder side of ports after:
Old 11-08-2010, 06:47 PM   #8
chetacheese
chetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of lightchetacheese is a glorious beacon of light
Send a message via AIM to chetacheese
+1 to the ka-t!
chetacheese is offline   Reply With Quote
Old 11-09-2010, 07:39 AM   #9
JonGu
JonGu's Avatar
JonGu is an unknown quantity at this point
Quality parts, im sure you'll make the power you're looking for. I see you have an eManage ultimate, is that what you'll be using to tune?
JonGu is offline   Reply With Quote
Old 11-09-2010, 08:42 AM   #10
revolutionz_s13
No, I actually sold that now and decided to use and aem ems....the ultimate is nice, but I am pretty sure that it wont be able to correct for injectors that big....and with running e85, I think it would be beneficial to use a full standalone.
Old 11-09-2010, 09:38 AM   #11
fender-startocaster
fender-startocaster's Avatar
fender-startocaster is an unknown quantity at this point
I used to live in North Dakota! Dickinson tobe specific. I never did see any 240s out there. It should be getting pretty cold soon right?
fender-startocaster is offline   Reply With Quote
Old 11-09-2010, 09:59 AM   #12
JonGu
JonGu's Avatar
Yea, the ultimate is limited and I was going to point you in another direction but you're one step ahead. Good luck with the build, I sometimes regret not going KA-T
Old 12-28-2010, 08:19 PM   #13
revolutionz_s13
Small bit of progress here. Got some more parts, a Skullworks oil block adapter, some AEM pencil coils, an Aeromotive A1000 FPR, and a set of Supertech cam followers (lifters). I sent the head to the machine shop for a 3angle valve job, and then proceed to assemble the head. I also put the oil block adapter on and installed the Xcessive windage tray/crank scraper, and had to do only a slight amount of clearancing for the crankshaft. Im waiting for a couple more things, hopefully the longblock will be completely assembled in the next couple weeks.
Pics!
Oil block adapter:
Xcessive windage tray (pre trimming for clearance):
Just back from the machine shop, fresh ground valve seats:
Assembling the head:
Old 12-28-2010, 08:59 PM   #14
93nismo
93nismo's Avatar
93nismo is an unknown quantity at this point
i just bought a ka i plan on rebuilding and possibly boosting. im not sure if ill be able to go as in depth as you though. ill definitely be watching this
WTB: 1/24 scale chuki s13 model.
93nismo is offline   Reply With Quote
Old 12-30-2010, 06:03 PM   #15
whitefedorafilms
whitefedorafilms's Avatar
whitefedorafilms is an unknown quantity at this point
+1 for doing it so thorough. i have been working on my car for over a year now. it's like i have become accustomed to sitting on parts. and doing a KA is really awesome. Good luck. the engine is pretty easy to build in stock form, but when you get to this extent i really hope it all works the first time. keep us posted. cant wait to see it finished.
whitefedorafilms is offline   Reply With Quote
Old 01-16-2011, 12:42 AM   #16
revolutionz_s13
So finally had some time over the last couple weeks to get some more done again. Started cleaning out the engine bay and taking out stuff I dont need anymore. I cut out the battery tray too, that sucked ass. Also pulled the engine bay harness out so I can go through it and check all the wires to make sure they are good, and to add wires I need, and take out ones I dont. I also got everything to start getting the motor more assembled. I was like a 2nd christmas over the last week, a bunch of parts came 8) I ran into a snag tonight, I need to get longer spacers made for the fuel rail, the ID1000 injectors + xcessive mani ends up with a much larger gap than what the spacers came with for the oem fuel rail. Pics!
Parts!
Cleanin a mess
Battery tray removed
A days carnage
Puttin the motor together little by little
Its gettin there slowly but surely, needs lots more time and money tho :? Feels good to be making progress again after a couple years of it sitting though. Comments, suggestions, and flames welcome
Old 01-16-2011, 12:54 AM   #17
97240TB
97240TB's Avatar
97240TB is an unknown quantity at this point
Just wanted to let you know, I personally ran a spec stage 3 clutch when I had my KA and I hated it. I know a few guys who are against ever buying them as well a close buddy who's a nissan tech and he swears against them as well, Personally I hated the pedal feel plus it was never consistent. Just some food for thought, I figure since you haven't gotten that far down the drivetrain you can probably snag up something better before you put that in your car. Either way Good luck with the rest of the build.
97' 240SX, VQHR swap Combplete.
97240TB is offline   Reply With Quote
Old 01-16-2011, 09:02 AM   #18
punxva
punxva's Avatar
Trader Rating: (31)
Feedback Score: 31 reviews
looks good i have the xcessive manifold, on my ka-t as well, get rid of that fitting that comes off of the water neck, its a pita to get that hose to run to the back of the thermostat housing, i've been working with xcessive on a new design based on my suggestions, and that was one of them. You will notice when you put the rest of your front cover together that you have absolutely no room in between that fitting and the heater hose return. I am running my hose from the back of the thermostat housing to a tee fitting in the heater hose line that comes off of the block with no problems. That's how Rich from xcessive recommended to run it.
Just a heads up, but other than that your build looks on point
Slip Gypsies Blog
not sure if you realize this
Old 01-16-2011, 10:40 AM   #19
revolutionz_s13
awesome, thanks for the head up man. So did you just get a 3/4npt plug for that hole then? do you happen to have a pic of how you ran your coolant lines?
Old 01-16-2011, 06:07 PM   #20
punxva
punxva's Avatar
Trader Rating: (31)
yeah i'll take one in the morning, i actually just did it on mine a few minutes ago, and its a 3/8th plug. Then i got a 3/4 t fitting from lowes and tee'd it off of the heater hose that comes off of the block
Slip Gypsies Blog
