Old 12-18-2010, 12:27 PM   #31
JohnnyDrfiter22
JohnnyDrfiter22's Avatar
JohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura aboutJohnnyDrfiter22 has a spectacular aura about
what is the purpose of a S14 waterneck?
JohnnyDrfiter22 is offline   Reply With Quote
Old 12-19-2010, 02:27 PM   #32
flossyrobinson
flossyrobinson is an unknown quantity at this point
the purpose of s14 waterneck that is the turbo coolant line hooks up there, making it easier to remove/install when needed. and easier is better right?
i would also look at midmount intercooler instead of front mount i hate how low mine sits... im always worried about it when pulling into parking lot. If you can afford to get a new wiring harness(around $200) do it! it will eliminate alot of guess work when troubleshooting if things dont go as expected.
Get an oil pressure gauge and make sure you prime the engine before you run it, should help you to not spin bearings
flossyrobinson is offline   Reply With Quote
Old 12-19-2010, 03:22 PM   #33
Def
No need for an S14 waterneck, just drill and tap your S13 one and put an NPT to AN fitting in it.
DEFSPORT
