Old 12-13-2010, 04:06 PM   #1
mikefc
mikefc is on a distinguished road
If you were to do it over again....(s13 Sr)
Alright,I have an SR in my possession and I wanna know stuff that you guys wish you would have done properly the first time,ect.
This is gonna be my daily/track car so I need it to be as a reliable as possible.
And with winter being here I have all winter to get shit I need for the motor.
Some plans are RAS,oversized waterpump pulley,change all turbo gaskets ect while motor is out,downpipe with flexpipe on it and other shit I dont feel like typing.
Oil cooler?
Aftermarket exhaust mani? they look awesome but worth it?
I want real deal info,not just speculations.
MOON LIGHTER
mikefc is offline   Reply With Quote
Old 12-13-2010, 04:40 PM   #2
Touge_drifter
Touge_drifter's Avatar
Touge_drifter is an unknown quantity at this point
Engine management that gets rid of the maf sensor, Tomei turbo manifold, sard 850cc injectors, rocker arm stoppers, metal headgasket, arp head studs, GT2876 turbo (.86a/r)
Spec stage 3+ clutch and 3inch exhaust. others are huge FMIC and Aluminum radiator, samco hose and lower thermostat! I'd do all that. At 12psi youll have 360whp and at 23psi looking at 442whp
No tune No life
Touge_drifter is offline   Reply With Quote
Old 12-13-2010, 05:45 PM   #3
chiboy002
rebuild kit? might as well do it since you're already doing work, i guess
street dancer.
GLEAM
Old 12-13-2010, 05:56 PM   #4
doomviillain
doomviillain's Avatar
doomviillain is an unknown quantity at this point
Send a message via Yahoo to doomviillain
it depends on your budget
You are seventeen.
Your argument is invalid.
doomviillain is offline   Reply With Quote
Old 12-13-2010, 06:47 PM   #5
nismoman
nismoman is an unknown quantity at this point
Put in braided stainless oil and coolant lines for the turbo. You'll be glad you did when you have to pull it with the engine in the car.
nismoman is offline   Reply With Quote
Old 12-13-2010, 06:59 PM   #6
whiterps13
whiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to beholdwhiterps13 is a splendid one to behold
Im guessing that Mike doesnt really need 350 horsepower at the moment.
I think the point of this thread is to find easily replaceable, cost effective mods to make the car more reliable. Obviously advice on upgrading the motor heavily isnt what he intended to gain out of this thread. Right?
Have you replaced the clutch?
whiterps13 is offline   Reply With Quote
Old 12-13-2010, 07:43 PM   #7
mikefc
^^Exactly.
Just bolt on shit or whatever.
350hp no thanks haha.
I do have a ACT 6puck sprung already.
MOON LIGHTER
Old 12-13-2010, 08:02 PM   #8
hardest240owner
hardest240owner's Avatar
Trader Rating: (29)
hardest240owner is an unknown quantity at this point
Feedback Score: 29 reviews
yeah definitely do an s14 sr waterneck and stainless braided turbo lines
hardest240owner is offline   Reply With Quote
Old 12-13-2010, 08:54 PM   #9
idamaster
idamaster's Avatar
idamaster is an unknown quantity at this point
Good clutch for the future, SS lines,Aluminum Rad., RAS, t28 or gt28 and manifold, Metal HG and Studs along with turbo outlet and exhaust...
idamaster is offline   Reply With Quote
Old 12-13-2010, 09:06 PM   #10
mikefc
This is the info I want!
Keep it coming guys
MOON LIGHTER
Old 12-13-2010, 09:09 PM   #11
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
front and rear main seals
new water pump and thermo
s14 sr oil pick up
good wiring job
Old 12-13-2010, 09:24 PM   #12
Red Dragon3
Red Dragon3's Avatar
Red Dragon3 is an unknown quantity at this point
Water pump (important), oil pump (important), timing chain (important), thermostat (important), coolant lines under the manifold (important), ss turbo lines, ras, replace all gaskets, engine mounts, oil filter relocation and cooler, power steering tank and lines, clutch, flywheel, spark plugs, apr head studs (oem are torque to yeild), fuel filter, fuel pump, down pipe, turbo outlet pipe, aluminum coolant tank, rubber fuel lines, radiator, rad hoses, intercooler and intercooler piping, air filter and replace any other rubber hoses and stock hose clamps cause it will save you the hassle and head ache. And a nice wire tuck!
08 Mitsubishi Evo X MR
89 Nissan 240SX
Red Dragon3 is offline   Reply With Quote
Old 12-13-2010, 10:19 PM   #13
mikefc
What gaskets would you suggest?
Also aftermarket oil pan?
I read that the more capacity/cooling for an SR the better
Once I get it running I plan on having a buddy do a nice wire tuck on it.
MOON LIGHTER
Old 12-13-2010, 10:40 PM   #14
chiboy002
dont confuse a wire tuck with a wire job.
Do painless or something, or just buy a ton of wire and fix what's needed. OEM wiring sucks, its also really thin shitty looking wires, so im sure resistance is a lot for what it is.
I'd go around fixing old plugs, cleaning grounds, insulating everything, cleaning up the excess wires. I plan on doing it on my ka, not fun
street dancer.
GLEAM
Old 12-13-2010, 11:13 PM   #15
doomviillain
id say replace the oil pump, water pump, front and rear main seals, OEM gaskets, belts, for some sort of reliability.
as far as bolt ons, cams, headers to fully 3" exhaust, FMIC, boost controller, koyo rad.
You are seventeen.
Old 12-13-2010, 11:44 PM   #16
mikefc
FRSport has those whole engine gasket dealios.
Would yall suggest the OEM or Cometic verison?
MOON LIGHTER
Old 12-13-2010, 11:46 PM   #17
DJPimpFlex
DJPimpFlex's Avatar
Trader Rating: (115)
DJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond reputeDJPimpFlex has a reputation beyond repute
Feedback Score: 115 reviews
Send a message via AIM to DJPimpFlex Send a message via MSN to DJPimpFlex
Tubs while the motor is out. Coolant lines behind the motor. Those are the MAIN things that I wish I did while the motor was out.
DJPimpFlex is offline   Reply With Quote
Old 12-14-2010, 12:12 AM   #18
KOUKIboy
KOUKIboy's Avatar
KOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-knownKOUKIboy is making his/her stupidity well-known
It all depends on two thing; 1.) whats your budget, and 2.) what size turbo are you running, if your running the stock T25 turbo, you just need some bolts ons such as Intercooler, Radiator, Exhaust, and maybe upgrade your water pump just in case and also the MAF to a Z32 better air flow....And also paint your engine bay a pimp ass color while your engine is out lol I wish I woulda done it......
[SIGPIC][/SIGPIC] http://wheelflip.com/r/Wheelwhore87
KOUKIboy is offline   Reply With Quote
Old 12-14-2010, 12:47 AM   #19
mikefc
Just a stock t25 redtop.
I plan on having HKS wastegate actuator running around 10-12 psi.
Obviously I know all of the basic shit like FMIC exhaust blah blah
Thanks so far lads
MOON LIGHTER
Old 12-14-2010, 01:06 AM   #20
DJPimpFlex
DJPimpFlex's Avatar
^^ Highmount, not Front mount.
Old 12-14-2010, 07:06 AM   #21
nismoman
Thoroughly clean or replace that aggravating IACV! Hard to get to later
Old 12-14-2010, 08:40 AM   #22
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
re- ring the motor, hone the bores, replace bearings, (main and rod) new thrust washers, get a rebuild gasket set (FR sports has them). metal h/g arp head studs, oil pan, revised tensioner, blacktop oil pick up (or mod the red top one). new timing chain kit (frsports also has it) front and rear main seal, pilot bushing, new clutch depending on HP/turbo. Braided SS lines,s-14 water neck.
basically go to FR sport and get to shopping LOL!
this will essentionally give u a fresh motor.
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 12-14-2010, 08:52 AM   #23
JonGu
JonGu's Avatar
JonGu is an unknown quantity at this point
west covina nissan has good prices on OEM parts. either replace the oil pump or rebuild it for much cheaper.
JonGu is offline   Reply With Quote
Old 12-14-2010, 06:25 PM   #24
chiboy002
i'd say cometic for things like head gasket, OEM for everything else
But OEM does hold up to like 15 psi or something, iirc
street dancer.
GLEAM
Old 12-16-2010, 11:07 AM   #25
SR20Driftking4lyf
SR20Driftking4lyf's Avatar
SR20Driftking4lyf is an unknown quantity at this point
Wiring Wiring Wiring!!!! Pick through the harness for the bare minimum, or buy one! And....+1 on coolant lines behind the motor as well.
SR20Driftking4lyf is offline   Reply With Quote
Old 12-16-2010, 01:27 PM   #26
idamaster
idamaster's Avatar
Ive got a cosworth 1.5mm HG and I havent had any problems with it. Stock sr20 can handle a lot of power. A thicker HG will just give you a little more room to boost more.
Old 12-18-2010, 01:13 AM   #27
chiboy002
Cosworth is top notch from what i've read
Also, i read that OEM Head gasket is good for like 450hp... if so i think that's more than enough for you mike, unless you're shooting for something crazy lol
street dancer.
GLEAM
Old 12-18-2010, 01:26 AM   #28
KaminaSan
KaminaSan's Avatar
KaminaSan is an unknown quantity at this point
Everyone is telling you bulllllllshit.
On EVERY SINGLE SR, the most important thing you can and should ever do for your engine before you put it in. REPLACE YOUR ROD AND MAIN BEARINGS and POLISH YOUR CRANK
Then you can worry about the other shit that people are talking about. Look in the tech section, or online, you will see strings of "SPUN MY ROD BEARING" "There goes bearing number 3" "My engine is knocking".
SRs kill rod bearings, especially number three. It doesn't matter if you have low oil or not, you WILL kill your bearings, so you might as well put in fresh ones, so you don't have to pull your entire engine in a couple months.
someone in the car is screaming when that deadly t25 spools up!
KaminaSan is offline   Reply With Quote
Old 12-18-2010, 07:57 AM   #29
nismoman
im calling bullshit. I say the reason people spin the rod bearings is one of two things. Not priming the engine with oil before cranking it the first time, since alot of these engines have been sitting for a long time. Also early redtops have a bad oil pickup design that allows a slightly dented oil pan to starve the engine of oil. engines dont just spin bearings for no reason. Also people assume that the engines are in good condition when they buy them. So though i agree that inspecting the bearings is not a bas idea, saying that the bearings WILL SPIN is nonsense.
SO basically putting in new bearings while the engine is out is a great idea for the assurance of reliability. Just the reason you use for doing it is flawed.
BTW my SR ran flawlessly for 5 years daily driven, until I blew a turbo.
Old 12-18-2010, 08:24 AM   #30
srstan
srstan's Avatar
srstan is an unknown quantity at this point
That is a MUST! Change all gaskets, water pump, thermo, plugs, etc.
srstan is offline   Reply With Quote
