Old 03-30-2011, 05:41 PM   #1
95se
95se's Avatar
95se is an unknown quantity at this point
SPL TC rods gone bad
My SPL TC rods V.2 have rusted out around the bearings after about 3yrs of use. SPL replied saying I could replace the bearings for $20 or upgrade to V.3 rods for $121. What is my best option? Or should I go with another brand? The rods could have rust around the area of where the bearing is so even it the bearings are replaced that might not solve the problem. The new ones might not be that much better either. There is no guarantee that they will last longer than these. I thought these had sealed bearings so they were some of the better ones on the market but 3 years is disappointing.
z32 front brakes, spl tc rods
95se is offline   Reply With Quote
Old 03-30-2011, 08:26 PM   #2
Om1kron
Om1kron's Avatar
upgrade. SPL pretty much is the best out there. Going any other route is going to cost you more money one way or another unless you downgrade to isis or similar.
Wayne Edwards
https://om1kron.blogspot.com
Old 03-30-2011, 08:41 PM   #3
s13silvia123
s13silvia123's Avatar
s13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfections13silvia123 is close to perfection
no shit its going to rust if you don't lube it even if it's self-lube because it eventually slowly runs out of teflon lube. as long as you take care of it, it wont rust. i still have my version 1's and they havent rust out yet and i make sure its well taken care of.
18g and 20g turbo users click on me
http://zilvia.net/f/tech-talk/261219-18g-20g-turbo-users.html
s13silvia123 is offline   Reply With Quote
Old 03-30-2011, 08:55 PM   #4
PoorMans180SX
PoorMans180SX's Avatar
If you replace the bearings you replace the whole end of the tension rod. it's not like you put a new bushing in the rod end. So that fixes your problem.
Just shoot them with a little WD40 when you think of it and they'll last a lot longer.
Also, 3 years is a long time. Everything wears out.
Old 03-30-2011, 09:08 PM   #5
Xplat
Xplat is an unknown quantity at this point
Bearings are a wear item. Replace em and be done with it.
Xplat is offline   Reply With Quote
Old 03-30-2011, 09:40 PM   #6
Def
Wear item, but I've got to wonder what you're doing with your car in TX to rust the rod ends badly.
DEFSPORT
Old 03-30-2011, 09:48 PM   #7
Hoffman5982
Hoffman5982's Avatar
Trader Rating: (25)
Hoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really niceHoffman5982 is just really nice
Feedback Score: 25 reviews
I would think that such high quality parts would last a lot longer than three years, but hell, for 21 bucks just replace them and be done
Hoffman5982 is offline   Reply With Quote
Old 03-30-2011, 10:10 PM   #8
chiboy002
This. I've read other companies bearings rusting out within 1 year
street dancer.
GLEAM
Old 03-30-2011, 11:31 PM   #9
singlecamslam
singlecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymoresinglecamslam is not welcome here anymore
Good bearings have a life of 2-4 years, 4 is really pushing it. Whats a good way to keep them going? WD40?
singlecamslam is offline   Reply With Quote
Old 03-30-2011, 11:40 PM   #10
T chop
T chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enoughT chop will become famous soon enough
From what I heard WD40 isn't very good because it will make dirt/debris stick.
T chop is offline   Reply With Quote
Old 03-30-2011, 11:47 PM   #11
chris_240sx
chris_240sx is an unknown quantity at this point
Can anyone elaborate on proper care for their arms? I haven't heard anything about it before.
chris_240sx is offline   Reply With Quote
Old 03-30-2011, 11:48 PM   #12
matts13vert
matts13vert's Avatar
Trader Rating: (31)
matts13vert is an unknown quantity at this point
Feedback Score: 31 reviews
^^ And it evaporates rather quickly. Its best to use grease.
What i do to maintain my heims
every 6 months i remove all my arms, and manually grease all the heims with bearing grease by packing the bearing groove with grease using my finger, after its packed i wipe off any excess to prevent dirt and contaminants from sticking to the joint.
matts13vert is offline   Reply With Quote
Old 03-31-2011, 10:31 PM   #13
nisco
nisco's Avatar
nisco is an unknown quantity at this point
Lithium Grease
nisco is offline   Reply With Quote
Old 03-31-2011, 10:59 PM   #14
towlie
Lol, WD40? Use special lithium grease. Like that^^^
Old 03-31-2011, 11:57 PM   #15
nisco
nisco's Avatar
It's also a wise decision to take apart new adjustable arms and spray the threads before installing them on the car.
Old 04-01-2011, 01:14 AM   #16
matts13vert
Trader Rating: (31)
i wouldnt unless its only on non-exposed part of the thread. ^^
Old 04-01-2011, 06:59 AM   #17
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
Upgrade, SPL is one of the best on the market, and you can't beat that price for the trade up
zombiewolf513 is offline   Reply With Quote
Old 04-01-2011, 07:13 AM   #18
bbturbo87
bbturbo87 is an unknown quantity at this point
the best?
my friend had spl parts, one day pulling out of his parking spot the spl outter tie rod broke, we threw them away and said screw this. how many versions of tie rods do they have? seems to me like they just throw shit out there, guessing, not enough engineering behind it if they have 20 gens of tie rods by now. gen 3 of arms? why not just making it top notch from the start?
bbturbo87 is offline   Reply With Quote
Old 04-01-2011, 07:37 AM   #19
dudermagee
dudermagee's Avatar
dudermagee is an unknown quantity at this point
Originally Posted by bbturbo87 View Post
the best?
So you're saying they should have gotten it right the first time? right....
anyways, who uses these boots and seals for their SPL arms??
Rod End Seals, Weld In Adapters, Spacers And Reducers Rubber Boots Lock nut jam nuts
like in this thread
http://zilvia.net/f/archive-faqs/161...llow-ball.html
FYI I called SPL directly and he said don't bother, just when you are under your car (about every other oil change IIRC) you should clean them with WD40.
Originally Posted by DC Dan MAX USA View Post
Don't wuss out on me.
dudermagee is offline   Reply With Quote
Old 04-01-2011, 08:05 AM   #20
wh0aitznic0
wh0aitznic0's Avatar
wh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enoughwh0aitznic0 will become famous soon enough
the best?
Well, pretty much ALL aftermarket tie rod ends that aren't OEM style have had counts of them fucking up. That's why I went with OEM with mine and TEIN on my last car. Never had a problem.
Also, to the OP, I've had my SPL V1 ruca's for like 4 years or some shit and now have the rest of SPL's arms. As long as you clean them out every couple of oil changes, you're good.
SPLparts.com * PoweredByMax.net
Originally Posted by hailandkill View Post
wh0aitznic0 -- has or had a shocker sticker on his car at one point, is asian with a gooey white center
<3
Nothing says, 'I'm broke and still trying', like aftermarket steelies.
wh0aitznic0 is offline   Reply With Quote
Old 04-01-2011, 09:03 AM   #21
Darren
Darren's Avatar
Darren is an unknown quantity at this point
the best?
Most products are engineered "top notch" from the start, but in the real world, problems arise, and a good, responsible company will recognize the design flaw and put out a revision to the product to take care of the flaw.
This is just good engineering.
Darren is offline   Reply With Quote
Old 04-01-2011, 09:57 AM   #22
CrimsonRockett
The Architect.
CrimsonRockett's Avatar
Trader Rating: (392)
Feedback Score: 392 reviews
Buddy of mine recommended to grease all spherical arms and cover them with a bag (or wrap them in plastic). Pretty much protecting the bearings from the elements. While it may not look pretty, I can see why.
SPL parts are some of the best out there hands down.
-Jspec-
Instagram/CrimsonRockett
Old 04-01-2011, 09:59 AM   #23
ixfxi
Guest
Posts: n/a
teflon is not a lubricant, its a powder. i believe teflon is used as the seal to keep shit out, and thats it. from what ive read over the years, companies touting the word teflon tend to use it because of marketing. i mean they coat pots, pans and wire with teflon because of its slippery characteristics and high temp capabilities. but when it comes to things like wax or self-lubricating ball joints, i think its all marketing.. smoke and mirrors.
WD40 isnt designed for that purpose. its good for cleaning, working bolts loose and coating things with a thin protective barrier against humidity, but thats it. if you want to be smart about it, coat them with thick grease such as bearing grease. i put anti-seize on mine and various other parts of the car (axles, lugs bolts). i just like how anti-seize resists water and tends to adhere real well.
this is what people dont understand. i personally chose to go with nismo bushings on almost all my car because of the OE durability. i believe that SPL, along with various other companies (ie cusco) offer a damn good adjustable solution for being aftermarket. but after doing my research, cars that do come stock with helm joints and bearings specifically state in the service manual that these parts are SERVICE PARTS that need need replacement every 10,000 miles. to me, thats a real high maintenance item.
^ words of wisdom
the best?
thats nonsense. you're the type of customer who is very narrow minded. you believe a company makes a product, and have faith that the company name is the end-all say-all when it comes to reliability. this is why i dont bother reading car magazines, its always "brand this, part this" .. its practically a fucking shop cart for people to copy and apply to their "builds." no innovation or customization.
what people like you need to understand is, that a product is a product - and its as good as its limitations. you can take the best diff, and it can fail because you used the wrong oil or lack of it. you can take a great suspension piece, and fuck it up because you dont install it or maintain it properly.
i've seen a myriad of people do shit like this, installing parts incorrectly and then upset that they fail. maybe your friend did nothing but subject them to the elements and never maintain them. i dont know and cant answer for your friend. but the bottom line is, SPL is a proven company (states-side) that has a good reputation. while i chose not to rock their stuff, i wouldnt hesitate to run their stuff i wanted a product like theirs.
i mean, besides stock what else can you suggest? i dont want to hear ISIS or circuit sports, because i'll bitch slap you.
Old 04-01-2011, 10:25 AM   #24
hellion240sx
hellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enoughhellion240sx will become famous soon enough
Lol. So many pitures came to mind.
Spl. can't go wrong. Too bad I couldn't afford all their pieces when I was getting my s13 parts :/
R.I.P. KAIN. YOU'LL ALWAYS BE BY MY SIDE!
240 addict miata addict
hellion240sx is offline   Reply With Quote
Old 04-01-2011, 11:13 AM   #25
red240
red240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the roughred240 is a jewel in the rough
3 years on SPL tie rod ends driving everyday, no problems at all and customer service second to none!
red240 is offline   Reply With Quote
Old 04-01-2011, 01:05 PM   #26
zombiewolf513
the best?
SPL can't be held responsible for your friends inability to correctly install and adjust parts.
I installed my v5 ends myself, then immediately after had a shop properly adjust them. I drove over 1600 miles nonstop to another state, drifted and abused the hell out of them with no problems and that was about 9 months ago. I clean off the excess black crap that builds up every time I'm under the car. They work just fine.
You obviously have no idea how the engineering of parts works. Especially aftermarket parts. They don't magically pop out of a factory all perfect. It takes testing, thousands of miles of regerous real world proving. SPL does the research and they provide parts as durable as you are going to get when it comes to aftermarket. They aren't OEM Nissan factory parts.
You should upgrade to V3 for the $120, if you cant align them yourself, install them and have a shop do it. There's a sheet of instructions on how to adjust the ends properly in the box.
Old 04-01-2011, 02:31 PM   #27
Chrischeezer
Chrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the roughChrischeezer is a jewel in the rough
How risky would it be to Drill and install your own grease fitting in a heim joint?
probably inexpensive and will definitely prolong the life of your joints.
Chrischeezer is offline   Reply With Quote
Old 04-01-2011, 02:46 PM   #28
dudermagee
dudermagee's Avatar
just use the Lithium Grease spray every other oil change and you'll be good it seems, and if they do fail after 3 years or more then just buy new heims for like 20 a pop. Fuck you'd spend that much replacing the oem shit anyways.
Old 04-01-2011, 05:47 PM   #29
ixfxi
Guest
Posts: n/a
I dont understand it. Why is SPL considered expensive? Expensive compared to what, e-bay parts? SPL is reasonably priced for what it is. Try to make any of the parts on their site and see how much it costs you. Take stock arms, buy nismo and have them pressed in and tell me how much it costs.
Without doing much thought and engineering, it appears that this is something manufacturers SHOULD look into doing. Unfortunately, it eats away at the modern mentality of shit not being serviceable and instead, replaceable. Very unfortunate.
Any manufacturer could and should be held responsible for the parts they offer. Thats not the point though. The point here is, doing the due diligence here and determining the reason for how and why an product failed.
Old 04-01-2011, 06:23 PM   #30
zombiewolf513
Because SPL parts are expensive. Expensive compared to many of the common brands offering the same kinds of parts. Granted the prices are reasonable given that SPL goes to hell and back to offer the best parts possible.
They should look into this. But in the meantime, $20 to replace joints is incredibly affordable.
I'm not saying they aren't responsible for the quality of their part, because they are. I'm saying that SPL can't be held responsible for improper installation causing failure due to stresses that it wasn't designed to handle.
Although I can't be 100% sure the part was installed wrong, I can only assume it was installed wrong because of SPL's outstanding track record, precision manufacturing processes, & quality assurance and quality control standards.
SPL is second to none in those regards, period.
