Old 07-31-2011, 03:04 PM   #1
SLiDe_WaYz
SLiDe_WaYz's Avatar
SLiDe_WaYz is an unknown quantity at this point
s13 rear trans seal
How the hell do you get this thing out. If tried screwdriver, scizzor trying to pry them. I dont want to mess anything up either. Cant find a How To on here. Its really starting to aggravate me.
Its a S13 SR.
SLiDe_WaYz is offline   Reply With Quote
Old 07-31-2011, 03:23 PM   #2
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Just replaced mine. I took a tiny flat-head oiled it up and tapped it with the hammer in between the seal and housing, then pried it up a bit to loosen it up. Took a needle-nose pliers and just yanked it out.
Old 07-31-2011, 03:25 PM   #3
SLiDe_WaYz
SLiDe_WaYz's Avatar
Did you use a big socket to tap the new one in ?
Old 07-31-2011, 03:30 PM   #4
KiLLeR2001
Trader Rating: (46)
That would be ideal. It's not what I did though. I just oiled it up good, put it on there straight and applied pressure evenly with my fingers little by little as far as it would go. Drove it around for a good 15 - 30 minutes, no leaks whatsoever.
Old 07-31-2011, 03:32 PM   #5
SLiDe_WaYz
SLiDe_WaYz's Avatar
I'll oil up a screw driver and try it out in a bit. I knew there was a simple way and I'm just over looking it.
Old 07-31-2011, 03:39 PM   #6
KiLLeR2001
Trader Rating: (46)
Just be careful not to score the housing with the screwdriver, cause then it will leak. Once you get a good grasp on it with the pliers just yank it out with all your might... You may need to pry it in multiple spots to break the seal. GL.
Old 07-31-2011, 04:34 PM   #7
mad-ass
mad-ass's Avatar
with a Seal remover tool.
OR...bend a flat head screw driver's edge 90 degrees[one that's got a messed up tip preferred] and use that as a remover tool by yanking on it.
Old 07-31-2011, 05:59 PM   #8
SLiDe_WaYz
SLiDe_WaYz's Avatar
Got it with some oil and a tiny flat head screw driver, tapping the screwdriver with a rubber mallet. Only took a few min. Thanks for the reply's and tips guys.
Old 07-31-2011, 07:44 PM   #9
s14unimog
s14unimog's Avatar
Trader Rating: (22)
s14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond reputes14unimog has a reputation beyond repute
Feedback Score: 22 reviews
Send a message via AIM to s14unimog
X2, I was surprised this wasn't the first response. Once you've pulled a seal with one, you'll never mess with any other method. Not to mention, a seal puller is a convenient tool to keep around any garage.
Fu*king ginger bread man stole my wallet...
SHIFTlock_slide to side
d3m3rs0n: if i have a baby im naming it Brandons Fault Emerson
s14unimog is offline   Reply With Quote
Old 08-31-2011, 10:30 AM   #10
vw203
vw203's Avatar
vw203 is an unknown quantity at this point
Send a message via AIM to vw203
Doing this this weekend thanks for the input everyone!
vw203 is offline   Reply With Quote
Old 08-31-2011, 11:31 AM   #11
nismo 240sx
nismo 240sx's Avatar
nismo 240sx has a little shameless behavior in the past
i just changed mine..flat head screw driver some balls and out it goes.
nismo 240sx is offline   Reply With Quote
