Old 08-04-2011, 12:45 PM   #1
vutony
vutony's Avatar
Trader Rating: (145)
vutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfectionvutony is close to perfection
Feedback Score: 145 reviews
Arrow *** 400RWHP SR20 Build *** Parting every SINGLE part !!!!
Check out my Feedback or Trader Rating
Located in Garden Grove, CA. 92843.
Email - [email protected]
AIM -
audiovideocentra
My other threads:
Price does NOT include shipping and shipping is not free. Please add 3% for PayPal or send as gift. NO trades b/c CASH is KING.
* For instant respond, reply to this thread since it will forward to my cell.
Here are the last of my 240 parts I have left. The majority of the performance parts were purchased new from either phase2motortrend.com or frsport.com. Some parts looks dirty but still in great shape with minimal miles on them. I will clean them prior to shipping. This is a rough draft of my for sale thread. I will update this ad frequently and will be adding more parts. Now onto the parts...
* saved for the heart
i have engine hoist for rent
i do SR wiring
vutony is offline   Reply With Quote
Old 08-04-2011, 12:47 PM   #2
vutony
vutony's Avatar
I have 4 S13 SR20DET transmission available. Three of them are in great shape and 100% functional. NO leaks or noise/grind. $250 each
The far left trans sold as parts, lmk what you need from it....shifter plate, bell housing, sensors, etc. Sorry I sold all the speed sensors.
S13/S14 SR20DET Toda Flywheel - $300 ($525 @ Phase2motortrend.com)
- Used only for about 3,000 miles
- In good shape and work perfectly (made 350ish HP)
- 4 flywheel bolts hole area was slightly shaved off to removed stripped bolts
- I had no problem with it installed (drifted and dyno'd with)
- I also have flywheel bolts for $30
S13/S14 SR20DET RPS Max Street Clutch - $300 ($415 @ Phase2motortrend.com)
- Used for about 10,000 miles
- Still has a lot of meat left on disc
- In good shape and 100% functional (made 350ish HP)
- Comes with pressure plate bolts
SR dust cover - $40
- Its cut at the top (12 o'clock) b/c I didnt want to remove the flywheel which does not affect anything.
i do SR wiring
Old 08-04-2011, 12:50 PM   #3
vutony
vutony's Avatar
Full Race Pro Stock Manifold - $850 ($1000 @ fullrace.com but now discontinued so RARE piece now)
- The best bottom mount turbo for SR
- Used but in great shape w/ about 5,000 miles
- Its thermal coated at Olympics coating in San Diego (cost $140)
S13 SR20DET Tomei 3" elbow - $150
- Its thermal coated at Olympics coating in San Diego (cost $60)
OEM S13/S14/S15 SR20DET O2 Sensor - $60 (FAT type)
For S13 models, there's 2 type of O2 sensor. FAT (Blacktop) and SKINNY (Redtop) type, both of which are 3 wire O2 sensor. To be safe, please look at your O2 sensor to determine which type you have and order accordingly.
S13 SR20DET Pro Fab Design Intake Manifold Gasket - $25 ($50 @ Phase2motortrend.com)
S13/S14 SR20DET 7 Layers Metal Exhaust Manifold Gasket - SOLD
i do SR wiring
Old 08-04-2011, 12:52 PM   #4
vutony
vutony's Avatar
Tomei/N15 TB 70mm throttle body - $450 ($575 @ Phase2motortrend.com)
- Used but in great shape w/ about 3,000 miles
- Comes with Tomei adapter, N15 TB and hardware
- S14 TPS not included, $70 extra
- Also have matching 3" custom one piece cold pipe, $100 extra
S14 SR20DET TPS - $70 ($95 @ Phase2motortrend.com)
- Used only for about 1,500 miles
- Perfect fitment compared to S13 TPS
Nismo/Tomei 740cc Fuel Injectors - $550 ($685-765 @ FRsport.com)
- They are in excellent shape
- Comes with 0-rings
Nismo Fuel Pressure Regulator Type-B - $100
OEM S13 SR20DET Fuel Rail - $50
- Comes with fitting for universal FPR
i do SR wiring
Old 08-04-2011, 12:53 PM   #5
vutony
vutony's Avatar
S13/14/15 ARC Oversize Oil Pan - $300
- Used but in excellent shape w/ about 3,000 miles
S13 SR20DET coil pack harness - SOLD
S13 SR20DET coil packs - $30 each (2 of 4 sold)
- 100% functional, no timing issue
- NO cracks around the coils body
- I switched back to stock since Splitfire kept cutting out at high RPMs
S13 SR20DET alternator - $SOLD
S13 SR20DET alternator bracket and hardware - $40
S13 SR20DET CAS - $110
- Used but 100% functional
S13 SR20DET dipstick w/ tube - $30
S13 SR20DET water inlet and outlet - $20 each
SR20DET coolant sensors - $20
S13 SR20DET stock oil sandwich block - $60
S13 SR20DET hard coolant pipes/lines - $30
S13 stock motor mounts - $30
- Used, did the job w/ my setup
- They have polyurethane filled in
SOLD
S13 SR20DET knock sensor w harness
S13 SR20DET motor mount brackets
S13 SR20DET Megan Racing Pulley Set
S13 SR20DET starter
Garrett GT2871R Ball Bearing Turbo w/ HKS actuator
S13 SR20DET TAKA Turbo Lines
S13 SR20DET AAC Valve
S13 SR20DET PS pump
S13 SR20DET PS bracket and hardware
S13 SR20DET Greddy Intake Manifold
i do SR wiring
Old 08-04-2011, 08:03 PM   #6
Rukus1025
Rukus1025's Avatar
Rukus1025 is an unknown quantity at this point
Dangggg Sick Stuff for sale PM'D On Clutch Kit
Rukus1025 is offline   Reply With Quote
Old 08-04-2011, 08:12 PM   #7
bikrman2
bikrman2's Avatar
bikrman2 is an unknown quantity at this point
Send a message via AIM to bikrman2
PM'ing you now on a couple things
Originally Posted by wangan_cruiser View Post
if you dont have any valuable information GTFO.
bikrman2 is offline   Reply With Quote
Old 08-06-2011, 11:56 AM   #8
reds13se
reds13se's Avatar
reds13se is an unknown quantity at this point
interested in the starter shipped to 28303 pm me
reds13se is offline   Reply With Quote
Old 08-08-2011, 02:43 PM   #9
vutony
vutony's Avatar
Replied, sorry i missed our aim'd
Replied, lmk on the gaskets
Sure, lmk
i do SR wiring
Old 08-16-2011, 06:02 PM   #10
vutony
vutony's Avatar
bumpin it here
i do SR wiring
Old 09-04-2011, 08:41 PM   #11
vutony
vutony's Avatar
SOLD
S13 SR20DET starter
i do SR wiring
Old 09-19-2011, 02:53 AM   #12
driftage240
driftage240's Avatar
driftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfectiondriftage240 is close to perfection
Send a message via AIM to driftage240
350 for tb n adapters? 800 for turbo lmk
Misty blu is coming 4 you!
driftage240 is offline   Reply With Quote
Old 09-19-2011, 03:04 AM   #13
idahotuner
idahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond reputeidahotuner has a reputation beyond repute
Send a message via AIM to idahotuner Send a message via MSN to idahotuner
How much for the braided SS line from the crank case to valve cover.
idahotuner is offline   Reply With Quote
Old 09-20-2011, 03:45 PM   #14
idahotuner
crankcase breather ss line sold to me
Old 09-21-2011, 10:34 AM   #15
97nismo
97nismo's Avatar
Trader Rating: (53)
97nismo is an unknown quantity at this point
Feedback Score: 53 reviews
what can u do on the ps pump shipped, paypaled etc. to 29630
Feedback:
http://zilvia.net/f/itrader.php?u=78978
97nismo is offline   Reply With Quote
Old 09-21-2011, 10:06 PM   #16
ns89racer
ns89racer's Avatar
ns89racer is an unknown quantity at this point
do you have a good sr bottom end? pm me
GIRLS THINK STOCK KA'S ARE FAST
ns89racer is offline   Reply With Quote
Old 09-21-2011, 11:32 PM   #17
Spencer dougherty
Trader Rating: (65)
Feedback Score: 65 reviews
i remember that flywheel... lol.. ballER parts.. buy his shit now!!!!!!!!!!!!!!!!!
Old 09-22-2011, 02:34 AM   #18
doridorihappy
doridorihappy is an unknown quantity at this point
think you can part just the sr ps pump tensioner bracket? shipped to 98023
doridorihappy is offline   Reply With Quote
Old 09-22-2011, 12:00 PM   #19
nissanfreak317
nissanfreak317's Avatar
Trader Rating: (18)
nissanfreak317 is an unknown quantity at this point
Feedback Score: 18 reviews
I will buy the knock sensor without the harness. free bump
nissanfreak317 is offline   Reply With Quote
Old 09-22-2011, 03:57 PM   #20
cnick20
cnick20 is an unknown quantity at this point
pulley set
Ill take the megan pulley set. Hows 80 shipped with paypal sound? lmk
cnick20 is offline   Reply With Quote
Old 09-22-2011, 04:02 PM   #21
murffy
murffy's Avatar
Trader Rating: (44)
murffy is an unknown quantity at this point
Feedback Score: 44 reviews
legit seller give u 230 for the oil pan lmk
murffy is offline   Reply With Quote
Old 09-26-2011, 10:25 AM   #22
vutony
vutony's Avatar
PM'd
Done deal.
PM'd
I have a built long block I used with all these goodies. PM me if interested.
Hahahah, good times.
Ok, price is the same.
Sorry, its sold.
Sure, done deal.
i do SR wiring
Old 09-26-2011, 01:27 PM   #23
Paper_Tiger240
Paper_Tiger240's Avatar
Paper_Tiger240 is an unknown quantity at this point
I need that starter, pm me with the goods i need to know to pick this up
free bump
Paper_Tiger240 is offline   Reply With Quote
Old 09-29-2011, 12:19 AM   #24
Tkwjh07
Tkwjh07 is an unknown quantity at this point
i just need the fittings for the fuel rail
Tkwjh07 is offline   Reply With Quote
Old 09-29-2011, 09:51 AM   #25
vutony
vutony's Avatar
free bump
Done deal, thanks again.
I rather not part so price is the same
i do SR wiring
Old 10-10-2011, 08:33 PM   #26
vutony
vutony's Avatar
final bump here before new thread
i do SR wiring
Old 10-23-2011, 12:24 PM   #27
skilvia
skilvia is an unknown quantity at this point
whats the spec of the long block?
skilvia is offline   Reply With Quote
Old 10-24-2011, 12:08 PM   #28
Stacy
Stacy's Avatar
Stacy is an unknown quantity at this point
Greddy Manifold and Q45 Throttle Body Sold
Stacy is offline   Reply With Quote
Old 10-26-2011, 10:04 PM   #29
Lostinthegame
Lostinthegame is an unknown quantity at this point
do you still have the full race manifold.
Lostinthegame is offline   Reply With Quote
Old 10-30-2011, 01:11 PM   #30
vutony
vutony's Avatar
PM sent
Yes and shipped earlier in the week
yes
i do SR wiring
