Old 12-24-2011, 03:13 AM   #1
Jesterjones13
Jesterjones13's Avatar
Jesterjones13 is an unknown quantity at this point
5 Speed trans wiring
Alright so i need some help wiring up my trans, i recently did the auto to 5 speed swap and i need to wire everything. Can someone explain to me or direct me to where there is a thread about it?
Thanks!
Jesterjones13 is offline   Reply With Quote
Old 12-25-2011, 11:27 AM   #2
godrifttoday
godrifttoday's Avatar
Trader Rating: (82)
godrifttoday is an unknown quantity at this point
Feedback Score: 82 reviews
I think it would be easier if u just buy a 5 speed tranny garness
NEED Bolt kits for your car?
http://i48.tinypic.com/6gx5e0.jpg
godrifttoday is offline   Reply With Quote
Old 12-25-2011, 11:31 AM   #3
zombiewolf513
zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513 zombiewolf513
The only thing that shouldn't work is the reverse light switch, IIRC. An ex-friend of mine did that swap and I think he just had to cut off the connectors and hardwire the switch on the transmission to the auto harness.
zombiewolf513 is offline   Reply With Quote
Old 12-25-2011, 11:33 AM   #4
Almosttt
Almosttt is an unknown quantity at this point
S14 5-speed Transmission Swap - Electrical Connections
Almosttt is offline   Reply With Quote
Old 12-25-2011, 11:36 AM   #5
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
this... I did my swap and after driving around without reverse lights for 2 weeks I got tired of it and found which wires in the auto harness made them light up and wired them straight to the switch on the manual trans. (its the furthest one to the front)
pacotaco345 is offline   Reply With Quote
Old 12-25-2011, 08:14 PM   #6
projectRDM
projectRDM's Avatar
Pointless.
The chassis isn't wired for the required switches so plugging a manual harness into an automatic chassis yields nothing. They MUST be hardwired.
FORMERLY R240NA
Old 12-25-2011, 08:45 PM   #7
zombiewolf513
well I shouldn't say it has to be hard wired. You could go this route:
Amazon.com: ACCEL DFI 74812 Weatherproof Electrical 2 Pin Connector: Automotive
Most auto parts stores sell some kind of variant.
That's what I would do; a nice, clean, disconnect-able wire up.
Old 12-25-2011, 08:53 PM   #8
herbieS13
herbieS13's Avatar
herbieS13 is an unknown quantity at this point
Send a message via AIM to herbieS13
i like this
herbieS13 is offline   Reply With Quote
Old 12-26-2011, 10:59 AM   #9
Jesterjones13
Thank you guys for the help!
I think im going to have a buddy wire everything up for me using those plugs you have posted!
Old 12-26-2011, 11:22 AM   #10
Ilya
Ilya's Avatar
Ilya is an unknown quantity at this point
How To: 5 Speed Swap in Convertibles (and other S13s) : 240SX Convertible Forum - Page 17
Ilya is offline   Reply With Quote
Old 12-27-2011, 06:59 PM   #11
projectRDM
projectRDM's Avatar
Hardwired as in you can't plug in a harness and have it work. There's more involved. Obviously no one would make it so it couldn't be disconnected.
FORMERLY R240NA
Old 12-27-2011, 07:49 PM   #12
zombiewolf513
ha, obviously you don't know most people.
Old 12-27-2011, 08:18 PM   #13
Agamemnon
Agamemnon's Avatar
Originally Posted by projectRDM View Post
Pointless.
Russ, is it possible swap an engine bay/dash/lower harness from a 5speed into an auto chassis and not have to slice and dice a bunch of wires?
Old 12-28-2011, 07:52 PM   #14
projectRDM
projectRDM's Avatar
Yes. Essentially you're replacing everything forward of the front seats (S14) or the entire car's harness (S13). That's a lot of work and you have to make sure you get the correct harness (power locks, cruise, amplified stereo, etc, etc). A mismatch would lead to more problems. In an S13 it's easier since the only major changes are base and SE and ABS/HICAS equipped. S14s vary per year and trim levels.
Way easier to hardwire the reverse lights if that's your only concern (5th gear switch isn't needed).
FORMERLY R240NA
Old 12-30-2011, 02:57 AM   #15
Howie Felter Snatch
Howie Felter Snatch's Avatar
Howie Felter Snatch is an unknown quantity at this point
Yep projectRDM is 110% correct.. Just cannibalize the inhibitor connector from your AUTO lower harness (8 pin looking thingy) and just wire the two wires from the reverse sensor in the manual trans to the reverse light pins on the inhibitor connector and bam your done! No need for 5th or 4th gear position sensors or the neutral position sensor for that matter. Other than that, the manual and auto S13's are identical. Its also fully disconnectable if necessary.
Howie Felter Snatch is offline   Reply With Quote
