Go Back   Zilvia.net Forums | Nissan 240SX (Silvia) and Z (Fairlady) Car Forum > Marketplace > Advertiser Specials and Sales > Advertiser Announcements and Feedback
Advertiser Announcements and Feedback This is where vendors can make announcements about upcoming promotions, events, items, etc. Vendors may also create threads here for the purpose of market research or other customer feedback.
Old 02-01-2012, 09:47 AM   #1
Z33@S-MAX
Z33@S-MAX is an unknown quantity at this point
FuelTech FT 400
FT 400 STAND ALONE
Fully Programmable Fuel Injection with distributor type or distributorless Ignition control. 4.3" TFT Dashboard
This is IT. The unit you see is a complete standalone no other boxes, programmers, or displays needed. You do not even need a laptop you can tune from the Color Touch screen.
Link to the Site FuelTech
Complete CAN communication: firmware update, FuelTech CAN network connection and FuelTech Computer Software - ECU Manager, to ECU configuration and tuning
FuelTech Fuel Automapping (requires external WB-o2 Conditioner)
Closed Loop Lambda Control (requires external WB-o2 Conditioner)
A link to Buy Fuel Tech | FT400 EFI
Resources:
Maximum RPM: 16000rpm
Built-in MAP sensor for naturally aspirated or blown engines (6bar - 87psi)
1 to 12 cylinders engine management
Real Time programmable
4.3” touch screen TFT
Sensors Input:
Engine coolant temperature (oil or water)
Intake air temperature
Oil pressure
Fuel pressure
Oxygen Sensor (narrow or wide band)
Air Conditioning Control
Configurable Auxiliary Outputs:
Progressive Nitrous Injection with fuel and ignition compensation (activated by TPS)
Electronic boost control through 3 way PWM solenoid valve (activated by RPM and TPS)
Fuel pump control
Variable camshaft control (VTEC)
Powerglide transmission shift (2 speed)
Electric fan by coolant temperature
Idle speed valve/stepper motor control
External shift light control
Ignition Control:
Compatible with hall effect distributor or crank trigger wheels: 60-2, 36-1, 12-1, 3, 4 or 8 tooth wheels and more.
Distributor, wasted spark coils or coil on plug
5 ignition outputs
Hall or magnetic trigger input
Time Based Rev Limiter (Traction Control)
Two-Step rev limiter with timing retard and fuel enrichment
Ignition and/or Fuel Rev Limiter
Ignition Coil Dwell time control
Ignition outputs to MSD, FuelTech SparkPRO, Integrated HEI Coils and built-in ignitor coils
Total Fuel Injection Control:
Normally aspirated engines by TPS, MAP+TPS or MAP only
Turbocharged, supercharged or blown engines by integrated MAP
Up to 2 injectors banks with individual maps
Up to 12 high impedance injectors or unlimited with FuelTech Peak and Hold Driver
Fuel Injection Automapping and Closed Loop Lambda Control:
Fuel maps automapping using wideband oxygen sensor.
Closed Loop Lambda Control.
Advanced Idle Speed control:
Target idle speed control by engine temperature
Air and ignition timing advanced algorithm control
PWM valve solenoid output
Stepper Motor output
Drive-by-wire control – Electronic Throttle Body:
Idle speed control
Throttle speed mode adjustment (slow, normal and fast modes)
Complete and easy tuning:
Overall trim function for Fuel Maps (individual by bank) and Ignition Maps
Interpolated Ignition Maps per RPM, with individual compensation maps: vacuum, boost, TPS, intake air temperature and coolant temperature.
Interpolated Fuel Injection Maps per TPS or MAP, with compensation maps by: RPM, intake air temperature, coolant temperature and battery voltage.
Anti-Lag Systems
Deceleration Fuel cut-off
Adjustable engine start fuel injection time by engine temperature and ignition timing
Security and user resources:
User protection password
Tuner protection password
Injectors dead time configuration to real fuel injection time processing
Check Control Warnings: exceeded boost pressure, RPM, coolant temperature, fuel injectors opening %, oil pressure, fuel pressure.
Adjustable LCD Display brightness
Customizable start screen message
Up to 5 memories to save different maps adjustments
Complete TFT Dashboard with real time ECU information
Z33@S-MAX is offline   Reply With Quote
Old 02-01-2012, 03:45 PM   #2
Hywarp161
Hywarp161's Avatar
Hywarp161 is an unknown quantity at this point
Wow this is pretty sick.
Hywarp161 is offline   Reply With Quote
Old 02-01-2012, 10:03 PM   #3
hooligans661
hooligans661's Avatar
hooligans661 is an unknown quantity at this point
Oh mah godd!!! We hit the motherload o_o
hooligans661 is offline   Reply With Quote
Old 02-02-2012, 09:20 AM   #4
Z33@S-MAX
FT 400 and FT 300
WE have special pricing for the FT300 and FT400 this month. PM me for details
Old 02-02-2012, 02:46 PM   #5
1quk240
Banned from the Marketplace
1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough1quk240 will become famous soon enough
What would be the difference from this compared to a Pro EFI? I'm currently in the market for engine management.
1quk240 is offline   Reply With Quote
Old 02-03-2012, 07:40 AM   #6
Z33@S-MAX
The main difference is the Fueltech is a complete unit. NO additional screens or boxes, the unit in the picture is the ENTIRE computer. The Fueltech also comes with a harness and is much easier for the end user to make adjustments via the color touch screen.
BTW the manufacture is offering a crazy special install of the unit and dyno for only $600
Old 02-03-2012, 08:14 AM   #7
coupster
coupster's Avatar
coupster is an unknown quantity at this point
How much for a kit for a s13 sr, shipped to 32403?
coupster is offline   Reply With Quote
Old 02-03-2012, 11:08 AM   #8
Z33@S-MAX
FT300 is $1199.00
FT400 is $1799.00 Full color touch screen display
Both units come with a unterminated harness . All you need to do is use your existing connectors from you OEM harness.
Shipping is $30-40 due the the insurance.
Old 02-04-2012, 01:32 PM   #9
1quk240
So this can also run different fuel maps? (e85/91, ect.)
where is the installer located?
Old 02-06-2012, 07:18 AM   #10
Z33@S-MAX
Yes it can support 5 different on the fly changeable maps no laptop needed.
The install and Dyno is in the northern NJ.
Old 02-06-2012, 10:55 AM   #11
Flicktitty
Flicktitty's Avatar
Flicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to beholdFlicktitty is a splendid one to behold
Send a message via AIM to Flicktitty
So this runs some sort of flex fuel sensor?To go from E85 to 93 to C16 that will auto adjust when you put the fuel in?
Or do you need to get a TUNE for E85 / 93 / C16 then switch over via a switch.
Also does this have a traction control function? Can it control an automatic?
2JZ-GTE Swapped S13 Coupe - 1994 Supra Turbo
Flicktitty is offline   Reply With Quote
Old 02-06-2012, 11:30 AM   #12
Z33@S-MAX
No sensor.
NO labtop is needed. The handheld unit is the complete Standalone. Just a few buttons too press and you can flip between 5 different maps. Each fuel will need its own tuned map.
YES it has traction Control!
FuelTech
Old 02-10-2012, 05:36 PM   #13
FamilyDrift
FamilyDrift is an unknown quantity at this point
Send a message via AIM to FamilyDrift Send a message via MSN to FamilyDrift Send a message via Yahoo to FamilyDrift
I'm looking to purchase a standalone in the next week or so for my 2JZ VVTI in a S14 driftcar. I'm torn between the FT300 or 400, AEM V2, and a Haltech. Could you give me the benefits or similarities of the Fueltech over some of the other units mentioned? Would you recomend this unit over the others? If so why?
Thanks, Matt
FamilyDrift is offline   Reply With Quote
Old 02-14-2012, 07:38 AM   #14
Z33@S-MAX
Thanks, Matt
Give a call to the office and we can go over the major benefits of the FT units. 321-251-7126
Old 03-10-2012, 08:46 PM   #15
SPATURBODAVE
SPATURBODAVE's Avatar
SPATURBODAVE is an unknown quantity at this point
FuelTech Dyno Day
March 17th @ ProFab Chassis (Question & Answer Seminar)
All are welcome, complementary food and drinks
Learn about a new cutting edge standalone EMS from the manufacture
We’ll even do the install for you!!! Drop off your car BEFORE MARCH 14th and pick it up with your FuelTech EFI unit installed and dyno tuned on the 17th for only $600.00
You will need to purchase a FuelTech unit (FT200, FT300, FT400) on or before the install date of March 14th.
Link for purchase of Install and tune: (FuelTech :: FuelTech Manufacturer Install and Dyno Session March 13th - Speed Max Performance - Store)
Dyno and instructional secession will be held at ProFab Chassis on the 17th of March 10, 2012 @ 27 Ridge Road Whitehouse Station, NJ 08889 www.profabchassis.com
Contact us with any questions. 973-891-1755
Vehicle must be dyno ready.
SPATURBODAVE is offline   Reply With Quote
