Old 08-22-2012, 12:33 PM   #421
240sxfan6882
240sxfan6882's Avatar
240sxfan6882 is an unknown quantity at this point
Still no updates on this I'm anxious too!
I'll add something to this thread too.
I have a KA24DET and Im converting to bottom mount with stock SR mani converted to KA24DE.
I ordered a GTX2867r with .82AR with the ATP T25 Plus external gate 2.5" V-band housing. It should be here next week I hope! The conversion should only take a few days at most (i hope).
Ill keep ya'll posted!
Thanks a ton to shiftdrift (a member on here) for building this up for me.
240sxfan6882 is offline   Reply With Quote
Old 08-22-2012, 07:50 PM   #422
huffandpuff00
huffandpuff00's Avatar
huffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura abouthuffandpuff00 has a spectacular aura about
any reason you chose the .82 over the .64 w/ the t25 plus housing?
seem too large for a t28 turbo, but you have .4 liters more displacement so maybe not
huffandpuff00 is offline   Reply With Quote
Old 08-22-2012, 08:27 PM   #423
240sxfan6882
Yes there is: it was almost free lol. The 82 tends to work better with the ka.. specially since I have a .5 litter more than an Sr, and port and polished heads and 9:1 compression. Move quite a bit of air. I'll let u know
Old 08-31-2012, 05:02 PM   #424
240sxfan6882
I got mine in today! .82 T 25 Plus housing with 2.5" V-Band on a converted to KA - SR manifold. I hope to test fit it to the car next weekend I hope! It took 2 weeks for me to get it.
Pics:
SR to KA Manifold Finished:
Package:
Front Cover:
Rear housing:
Rear V-Band shot:
Test Fit:
Its got lots of clearance with the stock turbo:
Cant wait to get that puppy going!
Old 09-08-2012, 09:33 PM   #425
ka-turbo
ka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-knownka-turbo is making his/her stupidity well-known
sweet!!!!!!!! cant wait to see a fellow KA results on the same turbo...and hopefully you have results!!!!.....wth is going on with ppls results on this turbo!?!?!?!?!?!?!!?
ka-turbo is offline   Reply With Quote
Old 10-07-2012, 12:36 PM   #426
Synergy
Synergy is an unknown quantity at this point
@ cody ace.
You are the t28 frame guru so I will see what you think. I have been back and forth between many different turbos and Ill outline my goals and see what you guys think.
My current SR setup consists of:
s14
tomei 260s
VTC working
CP pistons 8.5 comp
eagle rods
acl bearings
Apexi intake manifold.
Greddy type LS intercooler
tomei expreme exhaust manifold t2 IWG
dbb t28
Im adding 820cc injectors a aero 340 lph and a cobra MAF is needed.
I have 3 turbos in my hands.
A dbb t28 from a s15
a gt2871r .64 AR t2 Internal gate
a gt3071r t2 external gate
I want to convert to a GTX t2, t3 external setup.
Im looking to try to push the gtx2867r to the limit. Im going to be spraying 50/50 water/meth
My goals are as responsive to just over 400whp. Ive looked into twinscroll hx35s twinscroll gtx3071rs and they just dont seem worth switching my setup for these. I can mod the current mani for t2 t3 or EWG thats not an issue.
Now are there any ADDITIONAL things I can do to the gtx2867r to give me slightly more top end? Im going to use a dremel on it and try to make it AS smooth as possible.
Im trying to get as much power as possible out of the t28 frame and just wondering where the limit is? I dont want to convert to a top mount setup. Like you said any top mount setup making less than 500whp is IMO a waste of time.
Alot of the non nissan community around here seems to think t28 turbos max out at 300whp. Which is perfect for me.
Synergy is offline   Reply With Quote
Old 10-11-2012, 12:19 PM   #427
240sxfan6882
Originally Posted by Synergy View Post
@ cody ace.
s14
tomei 260s
VTC working
CP pistons 8.5 comp
eagle rods
acl bearings
dbb t28
Cody is the master of this and hopefully can answer your question soon.
What he will probably suggest is getting the manifold extrude-honed (High Performance, High Output Racing - GetHoned) to smooth out the air flow in the manifold and increase the volume slightly for more CFM. I was considering doing that to the manifold but its $500!!!
The reason I wanted a stock SR manifold is because of the strength of it, the fact that you can attach a stock heat shield to it, and the pulse pairing. But... with an external WG setup like I did mine the pairing is pretty much destroyed.
Ill be mounting mine soon, just ironing out some minor stuff on my KA
Old 10-25-2012, 06:53 PM   #428
eflove
eflove is an unknown quantity at this point
Just adding my info for others.
My set up is
s15 motor
GTX2867 .63ar internal gate
JWT s3 cams
Greddy intake mani, (stock small ass TB)
Tomei EX mani
Moonface full down pipe, 3in ex with cat
Haltech PNP
removed stock fan
stock head gasket and studs.
E85 17-falling to 15 psi
looking to turn up the wick in a few weeks.
eflove is offline   Reply With Quote
Old 10-25-2012, 07:06 PM   #429
unijabnx2000
unijabnx2000's Avatar
unijabnx2000 is an unknown quantity at this point
You should of gotten the .86 ar housing IMO
unijabnx2000 is offline   Reply With Quote
Old 10-25-2012, 07:20 PM   #430
eflove
Not worth it IMO.
Old 10-26-2012, 09:19 AM   #431
240sxfan6882
eflove: Nice power for being at only 17-15psi. So your falling to 15psi at around 6k rpm? It starts to pull like a mother at 2.5kRPM! Im about to start converting mine sometime next month
Old 10-26-2012, 09:32 AM   #432
Z33dori
Z33dori's Avatar
My set up is
s15 motor
JWT s3 cams
Tomei EX mani
Haltech PNP
removed stock fan
this, this is like
Old 10-26-2012, 09:33 AM   #433
hoggie
hoggie is an unknown quantity at this point
very nice power!!
i have tomei arms 7960 turbo kit on my red top SR
my engine is stock,
it made 347whp 372whtq at 16.5-17psi on a dyno dynamics
just tossing it out there for comparison for people shopping around.
S13 SILVIA CONVERTIBLE SR20DET TOMEI ARMS 7960 - YouTube
hoggie is offline   Reply With Quote
Old 10-26-2012, 09:35 AM   #434
e1_griego
e1_griego's Avatar
Trader Rating: (24)
Feedback Score: 24 reviews
Here's my gtx2867 .64 dyno:
Redtop s13
Stock hg, stock pistons
HKS 264 Step 1
Power FC L-jet
Tomei 740s
codyace modded stock ex. manifold with Tial MVR
stock intake manifold
PBM cobra dp
15psi
This mustang dyno generally doesn't read as high as the dynojet I had my car on before (where it did 340/300 on a gt2876 @14ish psi).
I much much much prefer this turbo. What the dyno doesn't show is that this turbo makes some boost every time you put your foot down. Full boost is still ~3800, but some boost all the time. It gets going much quicker than my gt2876, that's for sure.
e1_griego is offline   Reply With Quote
Old 10-26-2012, 09:48 AM   #435
Z33dori
Z33dori's Avatar
Originally Posted by hoggie View Post
very nice power!!
my engine is stock,
any pics of the chart?
Old 10-26-2012, 10:00 AM   #436
hoggie
Engine Mods:
Nismo Rocker Arm Stopper
Bing's Large FMIC Kit
Custom Intercooler Sprayer Kit
Turbo Smart BOV
Bosch Top Feed 700CC Injectors
Custom Top Feed Rail
Braided Fuel lines
Aero Automotive FPR
Power FC (MAP) w/commander, Datalogit, FC Edit
Circuit Sport Direct Ignition System
AVC-R
Innovate LC-1 Wide Band
Tomei M7960 Turbo Kit
Walbro 255 pump
3Inch Megan Turbo Back
Circuit sport Coolant Tank
Yonaka Aluminum rad w/ slim Fan.
Drift Freaq's engine mounts
Nismo Transmission Mounts
Spec Stage 3 Clutch
Spec 16LB Flywheel
Stainless steel braided Clutch Lines
Rear tires and rims spec on dyno is RPF1 17x10 +17 w/ 275/40 Fuzion ZRi
Old 10-26-2012, 11:14 AM   #437
eflove
240sxfan-It feel like a 400hp car bc of the TQ everwhere. I just drop the car off with my tuner. I don't have the data logs so I'm not sure when it's dropping.
Z33dori- thanks man. I spent a little extra time and had everything powder coated this time.
Old 10-26-2012, 01:10 PM   #438
steve shadows
steve shadows's Avatar
Sick, Sexy Turbo. End of Story. I got to talk to a lead Garrett tech about it for a few hours again recently too. Garrett is still the ish guys. Good/Great stuff!
Like Me on FaceBook !
Old 10-26-2012, 01:11 PM   #439
steve shadows
Engine Mods:
Turbo Smart BOV
Braided Fuel lines
Aero Automotive FPR
AVC-R
Walbro 255 pump
Spec Stage 3 Clutch
Spec 16LB Flywheel
Excellent! And you even used a real dyno! haha Dyno Dynamics!
Great numbers. Exactly where you should be. PS what octane were you running?
I am still getting people around 300 WHP (with the regular old 2871R .64 housing) on Dyno Dynamics on 91 octane out here in shit gas country I am sure you have some better options which really helped up there as well. Thanks
Old 10-26-2012, 05:05 PM   #440
hoggie
I live in Toronto, Ontario, Canada, highest octane we have available here is 94.
that's probably the 20-30whp difference from octane ratings..lol
do you have a ignition system? like MSD, Splitfire, circuit sport dis
i got the circuit sport DIS sparks were so much better it probably made 10whp from that mod alone, and its cheap price wise compared to others...made for SR20DETs specifically too, should get one if you dont have one!
Old 10-26-2012, 05:28 PM   #441
steve shadows
I tune other peoples cars mostly now, by request or personal appointment when it comes up. But from my experience the octane difference does help a lot. Especially 94. But I think even with 94 we couldn't have gotten those numbers on that dyno down here with a reg ole' 2871R. Cheers to Garrett at the end of the day...oh and cheers to your tuner/you did a great job nice graph!
Oh and on the ignition thing. I typically consult people to just stick with stock. Unless you're up over 400 whp you're not really going to have real blow out issues if the plugs and grounds and everything is working right. If you just want better spark then there are some minor benefits but usually don't see more than 10-15 HP on the smaller turbo hp setups.
Just as an example for my last 240, we did over 450 WHP on the dyno dynamics with a gt3076R on 19 psi with 91-100 mix. Mostly 91 though. That was with stock ignition, stock fpr, STOCK PISTONS AND RODS, stock fuel rail modded for the greddy IM. The Q45 TB helps a lot though. Greatest upgrade you can do for the money for response with any turbo. When that thing is barley taped you're sucking in as much air as a stock TB and they are practically bullet proof and almost never break if the cable is anywhere near rigged up right. I would love to see what we could do with the new GTX3076R too...
Old 10-26-2012, 09:28 PM   #442
hoggie
^ nice! i'll have to look into the Q45 TB for my car...haha
i got the OEM intake manifold for my red top SR20, would this be bolt on or adaptors would be needed? or if it even fits at all?
im just superise to see that my tq is more than the hp...because its different from most charts i see on this thread....im not a tuner, so i wont know why it came out that way...but the tomei kit is made by garret...just a beefed up version of the 2871r. would you mind explaining why?
Old 10-26-2012, 10:22 PM   #443
BlackZenkiS14
BlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond reputeBlackZenkiS14 has a reputation beyond repute
Send a message via AIM to BlackZenkiS14
So is anyone running one of the gtx2867r's in a bolt-on setup with internal gate on stock manifold, and stock style turbo outlet?
I pretty much just want to replace my s15 turbo with one of the new ones and not have to change a Bunch of other parts in the process. I'll do some s3 cams eventually. I'm trying to decide which would be more effective to get first, cams or this new turbo.
My current setup is 740cc nismo injectors, z32 maf, jwt tune, Greddy intake man, and 50/50 watermeth injection on a 7gph nozzle. I just want to add this new garret turbo to this setup, and make 350whp, how possible does that sound?
-Kyle
BlackZenkiS14 is offline   Reply With Quote
Old 10-26-2012, 11:36 PM   #444
Synergy
Horsepower is a made up number based off of torque. It can be caused by many things in your case it looks like a slight overboost as you hit your target pressure caused a increase in power. HP is a function of torque and rpm.
Old 10-27-2012, 07:44 AM   #445
eflove
Just a heads up if you want a bolt in turbo you'll have to order from atp. garret doesnt offer the 2 bolt in 3 bolt out style cover but atp does. They bore them out to fit the GTX family.
Old 10-27-2012, 08:30 AM   #446
JFoxx
JFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choicesJFoxx has made poor choices
not real impressed with the #'s i was making better # with my hks gtrs and ive had that for years.......
JFoxx is offline   Reply With Quote
Old 10-27-2012, 10:08 AM   #447
usdm180sx
usdm180sx's Avatar
^Good to see. The gt-rs is the only turbo upgrade I've done for both of my 240's =) Can't deny the spool up, power and fun!
-Norm!
Old 10-27-2012, 04:32 PM   #448
BlackZenkiS14
That's what I was figuring. I don't mind ATP, a lil pricey, but good shop
-Kyle
Old 11-16-2012, 07:50 PM   #449
huffandpuff00
new ATP t25 plus .63 housing all welded up. Should be a considerable amount more of clearance for the WG given how low this flange is placed compared to my other ATP .72 housing. Also Alex from PSI, being the amazing welder he is, welded the inside of the flange to insure the weight of the WG wouldn't cause any problems down the road. Still deciding if i want to go 2863 or 67...
Old 11-16-2012, 08:11 PM   #450
huffandpuff00
@240sxfan6882
I don't know if you saw that atp makes a flange that fits on the t25 plus housing and excepts 3" exhaust pipe. Because we are still bottom mount i know theres not to much room between the turbo and firewall, so if the 2.5 to 3" flange adapter doesn't work out, check these out.
gt2871, gtx, gtx2867r
