Old 12-22-2012, 07:25 PM   #1
lscustoms
lscustoms's Avatar
lscustoms is an unknown quantity at this point
Angry Ka24e no start, has fuel, spark, and still nothing help before i give up.... =(
OK so to start I have Experience with SOHC but this is one is making me pull my hair out... and im dont know what to do....
BACKGROUND
My friend bought a shell and has me helping him with it
Its a 1990 hatch came stock from factory with twin cam,
it was a shell so no engine or trans
He bought a SOHC cause we got a good deal from one of our friends on here, the engine had a new chain tensioners and HEADGASKET.
when we installed the engine, we where getting no injector pulse or spark. Asked around and got mix answers some said ecu, dizzy, and oddly enough if its true or not idk, but some one said the the brown and grey plug that goes from engine to body harness is diffrent and would need re-routing
SOOO. we tested the ecu on a running car tested good tested dizzy on a running car also tested good so we replaced the body harness.
THIS IS WHERE WE ARE AT NOW
#CRANKS
#HAS FUEL, PUMP PRIMES, AND INJECTORS HAS GROUND PULSE (TESTED)
#ENGINE HAS SPARK,
AND TIMING HAS BEEN SET MECHANICALLY
AND JUST CRANKS BUT WONT EVEN TURN ON FOR A SECOND
GOT THIS MOTOR FROM SOMEONE ON ZILVIA AND
SAID IT CAME FROM A RUNNING CAR.
ATTACHED IS A VIDEO
kjhgfhjk - YouTube
PLEASE HELP ME IM OUT OF IDEAS AND MY FRIEND IS JUST THINK OF SELLING IT
lscustoms is offline   Reply With Quote
Old 12-22-2012, 07:26 PM   #2
lscustoms
lscustoms's Avatar
Also what are the chances of the crank and cam not being lined up? Silver link does line up when set in tdc tho... So plz help...
Old 12-22-2012, 08:34 PM   #3
rcdad123
rcdad123's Avatar
rcdad123 is an unknown quantity at this point
the ignition timing has to be off. remove the valve cover and make sure #1 cylinder is on top dead center on compression stroke. now remove the distributor cap and make sure rotor is pointing on number one spark plug wire. remove and re install distributor if rotor does not line up with number one spark plug wire. once everything is lined up, turn the crank counter clock wise a quarter turn then clock wise till the first timing mark (20 degrees advance) lines up with the timing pointer. now turn the distributor till rotor lines up with number one spark plug. re install valve cover. if you have fuel, spark, and compression, engine should start. good luck.
rcdad123 is offline   Reply With Quote
Old 12-22-2012, 09:02 PM   #4
lscustoms
lscustoms's Avatar
Have any one ever heard of the distributors not being interchangeable, from what i heard may be an issue is that the hitachi and mitsubishi dizzy wont work interchange with certain ecus ive never heard this?? Have you guys>>
Old 12-22-2012, 09:38 PM   #5
hassanbakar123
hassanbakar123 is an unknown quantity at this point
check compression. take the rail off and see if you are actually getting fuel.
hassanbakar123 is offline   Reply With Quote
Old 12-22-2012, 09:47 PM   #6
lscustoms
lscustoms's Avatar
Yes i took the rail off and yes im getting sprays when the injector clicks
Old 12-22-2012, 10:35 PM   #7
lscustoms
lscustoms's Avatar
Any way to check that the cam and crank are synced right without removing the front timing cover???
Old 12-23-2012, 02:20 AM   #8
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
As far as I have seen your down to taking the whole front of the engine off and retiming it. Only way to be 100% sure is to do it yourself and be methodical about it. Fuel, spark and air with proper timing and you should get it to start and stay running, and you have to have all three sides of this triangle to get a fire in the first place.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 12-23-2012, 08:42 AM   #9
squigy
squigy is an unknown quantity at this point
@ your dizzy question
I had a twin cam KA boosted with a standalone.
Long story short i had taken out the plug to the coil for safety measures, and i didnt put it back on, went to fire it up and i burn out a 300$ 4-way igniter for my standalone. so i swapped out the dizzy that was on there thinking it was the problem and it wouldnt fire up.
So if you have the original dizzy put it back on there, also if you have a twin cam ECU , put the single cam back on there.
squigy is offline   Reply With Quote
Old 12-23-2012, 01:20 PM   #10
lscustoms
lscustoms's Avatar
its a original sohc dizzy and ecu just don't know of they are interchangeable from Mitsubishi and Hitachi
Old 12-23-2012, 08:32 PM   #11
ronny.jpn
ronny.jpn's Avatar
ronny.jpn is an unknown quantity at this point
I have this exact problem right now and today I discovered it's the fuel tank so yours might be too. I have sweet tea colored gas (rusty tank) so its keeping the car from completely starting up, though, it'll try. So, pull your fuel line, stick it in a bottle and check and see what its looking like.
ronny.jpn is offline   Reply With Quote
Old 12-23-2012, 08:34 PM   #12
ronny.jpn
ronny.jpn's Avatar
sorry for the double post: but, after you try to crank the car up those links and dots wont line up. The cam and crank turn at different speeds. Turn it over by hand a few times and watch, they'll line up again.
Hopefully your mechanical timing isn't off. That = bent valves possibly.
Old 12-23-2012, 11:17 PM   #13
goqr25
goqr25 is an unknown quantity at this point
I didnt see the maf sensor in your video. To my understanding, it has to be connected for the car to start. Good luck.
goqr25 is offline   Reply With Quote
Old 12-24-2012, 03:17 AM   #14
lscustoms
lscustoms's Avatar
i took the rail off and yes im getting fuel...
Old 12-24-2012, 06:38 AM   #15
ronny.jpn
ronny.jpn's Avatar
No you don't...
Sent from my SAMSUNG-SGH-I897 using Tapatalk 2
Old 12-24-2012, 09:52 AM   #16
goqr25
Originally Posted by sloazz40 View Post
No you don't...
How so? There is no way any car that has a maf sensor will run if it aint connected. It would fire but instantly die!
Old 12-24-2012, 10:08 AM   #17
ronny.jpn
ronny.jpn's Avatar
Lol I assure you its not needed for a car to run. I put my buddies KA in the other day and drove it just fine without it. Ofcourse, I will put it on, but it ran, and ran pretty dang good without it. I shall send you a PM with a link to a video soon.
Old 12-24-2012, 10:23 AM   #18
Ponda
Ponda is an unknown quantity at this point
It will run with no MAF...just won't rev past 3k.
OP - sounds like you have a timing issue. Here's a quick way to check.
Remove your valve cover and rotate the engine to top dead center. The tooth should point to 0 degrees on the crank pulley. Once you are for certain at TDC...look at your cam gear. The cam notch (little square thing) should point at 12 o' clock. The cam dimple (little circle on the gear) should point to 3 o' clock. See picture:
If that's all lining up properly - check your dizzy. When you remove the cap the rotor should point to your #1 cylinder plug wire.
Ponda is offline   Reply With Quote
Old 12-24-2012, 11:42 AM   #19
goqr25
I think your confussed with another sensor like maybe the o2 sensor. But if not, thats pretty crazy! Have to check out that vid.
Old 12-24-2012, 04:55 PM   #20
zerodameaon
They will start and idle without it, but they sure as hell won't drive worth a damn. The ECU has no way of knowing how much air the engine is taking in. The TPS is only part of that equation. Unless your buddy did not tell you he was running a MAP setup I doubt it ran good.
Old 12-24-2012, 05:39 PM   #21
ronny.jpn
ronny.jpn's Avatar
Ill get it. Drove it perfectly fine. I definitely know the difference between an o2 and a MAF. He didn't have an O2 either lol.
Old 12-24-2012, 08:08 PM   #22
PureRush
PureRush is an unknown quantity at this point
No MAF and the car will run but in limp mode. OP you should do a compression and leakdown test. Thats the easiest way to check your cam timing wihtout ripping shit apart. If it actually has fuel and spark then thats the next step. Trust me on this one
PureRush is offline   Reply With Quote
Old 12-25-2012, 09:52 AM   #23
ronny.jpn
ronny.jpn's Avatar
I'm telling you check your tank. I didn't and had the same issue as you and When I checked my tank I found this "gas" and piles of rust.
