Old 01-25-2013, 03:43 PM   #1
kenny2jz
kenny2jz is an unknown quantity at this point
need help with r33 brake swap
i Have a s13. does 300zx rear rotors work with the swap and what size rims with correct offset should i use to fit with out using spacers. if any body has r33 skyline rims for sale ill like to buy them bec i know they will fit.
kenny2jz is offline   Reply With Quote
Old 01-25-2013, 03:56 PM   #2
Mikester
Mikester's Avatar
300ZX rear brakes & rotors are identical between R33, 300ZX (Z32) & R32.
As far as offset goes, you may need spacers, you may not... provided you have 16" rims or more. Not sure if they will fit on 15's.
There is an "offset 101" thread. Give it a read.
Old 01-25-2013, 04:10 PM   #3
kenny2jz
i been reading up on the swap im feeling 17 inch rims right now, that's what i have seen alot of people use but i do not want to use spacers that's for sure. and thanks ill check that link forr the offset for dummies.
Old 01-25-2013, 04:15 PM   #4
blueshark123
blueshark123's Avatar
Trader Rating: (55)
Feedback Score: 55 reviews
If u want stock 17" wheels that are cheap go for 350z rims i have a set for 400 with tires i can sell if ur interested text me 973 513 3613
Old 01-25-2013, 04:27 PM   #5
90240sx07
90240sx07 is an unknown quantity at this point
got a link or writeup for this swap
90240sx07 is offline   Reply With Quote
Old 01-25-2013, 04:45 PM   #6
godsmack
godsmack's Avatar
godsmack is an unknown quantity at this point
It's the same as doing the 300zx swap.
godsmack is offline   Reply With Quote
Old 01-25-2013, 09:51 PM   #7
Mikester
Mikester's Avatar
I don't know exactly why; but to me, 350Z wheels look VERY classy on S13 hatches.
Old 01-29-2013, 11:42 AM   #8
kenny2jz
Will hw Rims clear the caliber ? Bec if they don't need spacers ill buy them
Old 01-29-2013, 11:49 AM   #9
Ninjamasta04
Ninjamasta04 is an unknown quantity at this point
They are not cheap. Most on ebay sells for $200 a pop in good condition, some with caps some don't. Unless you know someone who is selling it or search the forums everyday for a good deal, I recommend MB weapons for $150 each.
Been using them for daily and drifting for 2 years now, and the best part is that I don't care if it got curb rash, or dented because I could always replace them.
If you want to cheap out get either a 300zx stock 16 inch or 240sx SE wheels. They both have the same off set of +40 and they clear the front brakes. As for the 240sx SE I have not tried them on the rear with z brakes, make sure you try them on first before buying.
Ninjamasta04 is offline   Reply With Quote
Old 01-29-2013, 12:05 PM   #10
rebornS14
rebornS14's Avatar
rebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of lightrebornS14 is a glorious beacon of light
Send a message via AIM to rebornS14
you can fit 16" wheels since the Z32 came with stock 16's. offsets should be lower than +36 i believe.
rebornS14 is offline   Reply With Quote
Old 01-29-2013, 02:02 PM   #11
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
Offset has nothing to do with brake clearance but with that said, stock S14 SE wheels will clear R32/R33 brakes all around.
CLICK HERE!!!
Old 01-31-2013, 03:50 PM   #12
kenny2jz
thank you
Thanks everybody
