Old 07-31-2013, 09:29 AM   #1
alexander240
alexander240's Avatar
alexander240 is an unknown quantity at this point
Subframe Nut stripped to kingdom come!
So I was trying to drop the subfram and both subframe Nuts the last two needed to be removed stripped so badly they're round!!! What on earth do i do!? I was thinking of getting a dremel and trying to slive them off but Im affried I might warp the bolts.
WTB: Dmax Coupe roof spoiler.
alexander240 is offline   Reply With Quote
Old 07-31-2013, 09:31 AM   #2
Drift_FX
Drift_FX's Avatar
Drift_FX is an unknown quantity at this point
vicegrips, weld somthing to them to break them loose or cut them off
(heat is you freind for removing stuck nuts....)
Drift_FX is offline   Reply With Quote
Old 07-31-2013, 09:40 AM   #3
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
Google keywords: stripped subframe bolts site:Zilvia.net
The results open up several pages full of threads just like yours.
zooopreme is offline   Reply With Quote
Old 07-31-2013, 09:52 AM   #4
alexander240
That didnt help at all ^ those are for bolts not for nuts.
Old 07-31-2013, 09:59 AM   #5
zooopreme
Trader Rating: (38)
Okay...? Replace the word "bolt" with "nut"...
Old 07-31-2013, 10:03 AM   #6
alexander240
I did nothing came up.
Old 07-31-2013, 10:06 AM   #7
Mikester
Mikester's Avatar
Click the facepalm...
Old 07-31-2013, 10:37 AM   #8
silviaks2nr
silviaks2nr's Avatar
Get a rounded nut remover set. The deep socket kind.
Old 07-31-2013, 11:24 AM   #9
joshchewuhh
joshchewuhh's Avatar
Trader Rating: (56)
joshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfectionjoshchewuhh is close to perfection
Feedback Score: 56 reviews
Send a message via AIM to joshchewuhh
Go to sears. They have a stripped bolt socket set. Does wonders. Use heat.
joshchewuhh is offline   Reply With Quote
Old 07-31-2013, 11:40 AM   #10
wanganKa24e
wanganKa24e's Avatar
wanganKa24e is making a name for him/her selfwanganKa24e is making a name for him/her self
Happen to my subframe, I had Blackwood motorsports do my subframe bushing replacement. They ended up cutting the top plate of the subframe. Welding a new nut and welding the plate back on.
WRONG WAY!
wanganKa24e is offline   Reply With Quote
Old 07-31-2013, 12:02 PM   #11
AZSCsideways
AZSCsideways's Avatar
AZSCsideways is an unknown quantity at this point
+1 these things do wonders, use a propane torch to evenly heat the nut and give it a go...has saved my ass more than once.
Craftsman Bolt-Out 6-Piece Damaged Bolt/Nut Remover Sets 952060 - Free Shipping on Orders Over $99 at PowerSports Place
this is the same set i got as a gift from an older friend, he promised me i would use them and let me tell yea i have alot
Admin- AZSupraCentral
AZSCsideways is offline   Reply With Quote
Old 07-31-2013, 12:14 PM   #12
Infamax
Infamax's Avatar
Infamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enoughInfamax will become famous soon enough
I've used the exact kit too.
For stubborn nuts, I heated the nut with out applying direct heat to the stud as best I could. Then i tapped on the extractor and used a breaker bar. You can also try hammering on a smaller socket.
I also soaked the nut with pb blaster through out the day, the day before.
Infamax is offline   Reply With Quote
Old 07-31-2013, 12:22 PM   #13
feito
feito's Avatar
feito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymorefeito is not welcome here anymore
use the next smaller socket forced in with a hammer. U will make a new square on that nut and the impacts will help break it loose a little. An impact wrench is of great help when doing this. gl
feito is offline   Reply With Quote
Old 08-02-2013, 05:47 PM   #14
ShakotanGazelle
ShakotanGazelle is an unknown quantity at this point
That's what i did when i stripped the 12mm nut on the struts, just got a 6 point 11mm socket and hammered it in. Worked perfect
ShakotanGazelle is offline   Reply With Quote
Old 08-02-2013, 06:30 PM   #15
SLYDEWAYS 96
SLYDEWAYS 96's Avatar
Trader Rating: (34)
SLYDEWAYS 96 is an unknown quantity at this point
Feedback Score: 34 reviews
This happened to me when I was in the process of dropping my subframe to change the bushings and diff bushings.
Only the driver side front nut wasn't coming off and then one more turn with the ratchet and the bolt snapped on me.
What I did was cut the remainder of the bolt off, and sand the surface till you wont notice there was a bolt there. Then measured the passenger front subframe bolt and made one with the same threading on a CNC machine at work, made out of grade 10 steel and hardened. Made a rectangular plate in similar size to the frame rail, welded the bolt to the plate. After all the bushings were in and it was ready to go up, I inserted the bolt in the bushing and lined up the subframe, then welded the rectangular plate to the frame rail and your done.
Hope this helps, its always good to have a friend who welds lol.
Grinding off the remainder of the bolt
New CNC machined bolt with rectangular plate
And the pretty subframe with new ES bushings
SLYDEWAYS 96 is offline   Reply With Quote
Old 08-02-2013, 06:35 PM   #16
lflkajfj12123
i would just dremel them off lol
