Old 10-04-2013, 10:59 AM   #1
FourtyKid
FourtyKid's Avatar
FourtyKid is an unknown quantity at this point
Radiators for V8
I'm looking for a radiator that will mount in an s13 and cool a VH45. Most of the radiators I've seen for 240's have the intake hole on the top, drivers side. The coolant intake for the VH is on the passenger side. Anyone know of a radiator that'll fit in an s13 with the top intake hole on the passenger side and are sufficient enough to cool a V8? I think I could use a Koyo SR20 radiator with fans since they're pretty heavy duty. Intake hole is on the wrong side though. Lots of radiator hose stretching the radiator kind of looks silly.
@s13cole
FourtyKid is offline   Reply With Quote
Old 10-04-2013, 11:01 AM   #2
driftminds13
driftminds13 is an unknown quantity at this point
Get an aftermarket radiator for a Ka24de. I will be using a Mishimoto for my vh powered s13.
driftminds13 is offline   Reply With Quote
Old 10-04-2013, 11:06 AM   #3
japslapsilvia
japslapsilvia's Avatar
japslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the roughjapslapsilvia is a jewel in the rough
Custom Built Aluminum Radiators - Ron Davis Racing Products
Nothing is rare just expensive.
if you've ever been with multiple women, then even you can understand that not all girlfriends are created equal. some are capable of amazing oral talents, while others dont mind a lill back door action.
japslapsilvia is offline   Reply With Quote
Old 10-04-2013, 11:31 AM   #4
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
A VH45 shouldn't need a very big radiator. The engine isn't that big, doesn't make that much power, and has no turbos to get hot as fuck. A stock radiator with a good fan setup would probably work fine. If anything a larger KA aluminum radiator should be more than enough.
Old 10-05-2013, 07:37 PM   #5
Kingtal0n
Kingtal0n's Avatar
griffin makes almost every size/orientation
tinyurl.com/4l80er
Old 10-05-2013, 07:44 PM   #6
FourtyKid
FourtyKid's Avatar
Would this work? CXRacing is relatively well known, better than Godspeed anyway. They also have one with fans for $30 more.
http://pages.ebay.com/motors/link/?n...d=180690973907
@s13cole
Old 10-05-2013, 09:17 PM   #7
Scherz Daddy
Scherz Daddy is an unknown quantity at this point
Send a message via AIM to Scherz Daddy
I'm using a griffin with my ls1. No cooling issues so far.
Scherz Daddy is offline   Reply With Quote
Old 10-05-2013, 10:15 PM   #8
Chaluska
on my VH swap im running a Scirocco style dual pass tucked radiator. car never overheats, and im running 1 - 12" electric fan
Old 10-05-2013, 11:00 PM   #9
rbs14kouki
rbs14kouki's Avatar
rbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to allrbs14kouki is a name known to all
i had a becool on my s14/ls1 ... it was a universal model from jegs or summit i dont remember ... cheap to
ill be getting an other one for my sr swap soon
AV FABRICATION
Built thread sr20vet s14
http://zilvia.net/f/showthread.php?t=535574
rbs14kouki is offline   Reply With Quote
Old 10-07-2013, 09:55 AM   #10
niscur29
Location: Back IN FL, bring nice cars to the fail state!
niscur29 is an unknown quantity at this point
I ran a griffin, which has the inlet/outlet correct, on my vh which worked great and still use the same one on my lsq29 with custom hoses. Works like a champ with a Taurus fan on low speed only and a spam controller.
niscur29 is offline   Reply With Quote
Old 10-10-2013, 12:28 PM   #11
2muchboost
Trader Rating: (33)
2muchboost is an unknown quantity at this point
Feedback Score: 33 reviews
AFCO Dual Pass. Adding OEM Altima Fans once its all done.
http://www.summitracing.com/parts/afc-80101ndp
Know a few guys abusing these in the LS swapped cars with no issues. That exact dimension fits between the stock location of the S14 chassis (not inside of the rails like Chasebay though).
2muchboost is offline   Reply With Quote
