Old 12-05-2013, 10:02 PM   #1
worangejuice
worangejuice's Avatar
worangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond reputeworangejuice has a reputation beyond repute
Failed SMOG again in CA...High NOX count....
failed SMOG in CA. 180,000 miles, original everything i think, new spark plugs, stock intake, custom 2.5 piping fart can exhaust, seafoamed 2 years ago..........My NOXX readings are off the charts... Im gonna look at EGR and seafoam it, besides tune-up (distributor, wires,cap, CAT(hope not))can anybody suggest anything else???
*UPDATE*
So my readings are significantly better. SMOG tech said its my BPT Valve. Because its not recirculating emissions back into EGR.
Vaccuum tested BPT also and no pressure at all. I watched him test, he was pretty cool. He said if it was a bad CAT then all the readings would be fairly high across board (all would be effected)
I guess id need to clean the intake runners as well?
I had car running hot also (drove around for hours)
I am down to half a tank and that "guaranteed pass" bottle stated to run tank empty and then put gas in then SMOG test. But Ive been driving all over town and just need to SMOG to sell to a buyer like 4 days ago........F'ng A MAN
http://i13.photobucket.com/albums/a253/worangejuice/sig-3.jpg
worangejuice is offline   Reply With Quote
Old 12-05-2013, 10:07 PM   #2
mechanicalmoron
Seafoam it, directly before taking it for a long highway drive, like 100 miles. And don't be afraid to open 'er up. Get the whole motor, and the cat, really hot.
After you make sure your pair valve isn't crudded up, egr works, etc.
Old 12-05-2013, 10:11 PM   #3
worangejuice
Thanks, yeah that sounds good, first is first to check that GODDAMN EGR............
Old 12-05-2013, 10:34 PM   #4
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
when it doubt, Replace your cat.
ZenkiKid is offline   Reply With Quote
Old 12-06-2013, 01:28 AM   #5
zerodameaon
zerodameaon's Avatar
zerodameaon is an unknown quantity at this point
Obviously fix your timing and your vacuum lines, that will cause issues, you would not have passed even if your numbers were perfect. Seafoam it, and replace your cat, its 20yo with 180k and it needs to go regardless. They are cheap if you buy the magnaflow that is CA approved for our cars. Also if you figure out how to secure the cat shield back on there they won't even bother to check.
Originally Posted by MrMigs View Post
That's a one-way trip to understeer land...
Originally Posted by BKdaMoRoN View Post
Maybe you should petition the retards who are paying 5k for an S13.
Need to adjust your idle?
http://zilvia.net/f/s-chassis/395413...-pictures.html
zerodameaon is offline   Reply With Quote
Old 12-06-2013, 02:12 AM   #6
DALAZ_68
not giving a fuck
DALAZ_68's Avatar
Trader Rating: (104)
Feedback Score: 104 reviews
Run some garuntee passed from Autozone...blue packaging...
PSN
& XBL GT : Wh0pp3r68
CLUB LEXUS : Wh0pp3r
Old 12-06-2013, 10:19 AM   #7
KevinEdgar
KevinEdgar's Avatar
KevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to allKevinEdgar is a name known to all
Guarantee pass is bs. Fix the real problems, I had the same high nox problem with mine a few years ago.
Order of most effective :
1 buy brand new magnaflow cat
2 timing must be on point
3 fresh 02 sensor
4 clean out egr
5 put some denatured alcohol in gas tank
6 run car hard before smog and do not turn vehicle off
Good luck dude.
http://milktea-man.com
KevinEdgar is offline   Reply With Quote
Old 12-06-2013, 10:25 AM   #8
g35gabby
g35gabby's Avatar
Trader Rating: (26)
g35gabby is an unknown quantity at this point
Feedback Score: 26 reviews
"gross polluter" is the funniest thing I have seen in a while.
I don't know much about Cali emissions, but I do have my factory exhaust+cat here sitting around if you need it lmk. shipping the exhaust would be difficult, but the cat should be simple enough.
g35gabby is offline   Reply With Quote
Old 12-06-2013, 10:40 AM   #9
KevinEdgar
KevinEdgar's Avatar
^x2 I also have stock exhaust + used magnaflow cat laying around you can use. Idk where Weeehooo is though.
Old 12-06-2013, 03:15 PM   #10
Rich260z
Rich260z is an unknown quantity at this point
I'm guessing it's west hollywood.
Rich260z is offline   Reply With Quote
Old 12-06-2013, 03:58 PM   #11
koukikat180sx
koukikat180sx's Avatar
koukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfectionkoukikat180sx is close to perfection
Send a message via AIM to koukikat180sx
Seeing the gross polluter was pretty entertaining... I'm trying not to laugh too hard because karma comes around.
I dropped close to $1k at Gushi auto a couple of months ago just to get my car to pass smog properly. (Mine was not as bad as yours though...) I needed the o rings replaced on my injectors, new spark plugs, changed the spark plug wires, distributor cap and rotor, new CA magnaflow cat, knock sensor... I feel like I'm forgetting something, but yeah... Expensive stuff, but my car is super clean now! Good luck.
koukikat180sx is offline   Reply With Quote
Old 12-06-2013, 04:30 PM   #12
mechanicalmoron
No offence, but a lot of that is just paranoia and placebo.
You probably changed one or two things that actually did something. Cap and rotor can't hurt, cat if the last was bad, etc. If your motor was even drivable, the injector o-rings where fine, plug wires probably fine (you can check their resistance with a multimeter, it's .37 ohms.... or uhh, some multiple of ten by that.
OP, seriously, just first clean pair and egr, and then get it really hot, seafoam it, and get it even hotter, for a long time. Go on a weekend drive on a fun twisty highway, or something. Burn the living fuck out of all the deposits in it. Run it wide open. Then, if you still so desire, do plugs and cap/rotor. The italian tune-up.
If that fails, get a cat. But I doubt you need one if you just burn it out.
Old 12-06-2013, 06:49 PM   #13
milto0n
milto0n's Avatar
milto0n is an unknown quantity at this point
Look at your EGR first. IDK why everyone is suggesting for you to buy new things yet when you haven't even began a comprehensive review of your emissions equipment. Before spending any money look behind your engine block and use common sense. Does anything not look normal? Are there cracked/ripped vaccum lines? When you rev the engine, does your EGR valve lift? Me and california Emissions are mortal enemies and I've had my share of experiences failing unfortunately.
I'd say inspect motor first. Look for exhaust leaks (particularly pre cat). Test for vaccum leaks (blow into the IACV port and listen for whistling if you want to do it free lol). If any of those vaccum lines behind the engine block are ripped, you will hear the leak. Run seafoam. Do a tune up (really cheap to do yourself anyways.) Replace o2 sensor. CHECK YOUR TIMING!!! Replace cat as a later resort (and save it for next inspection!)
milto0n is offline   Reply With Quote
Old 12-07-2013, 01:37 AM   #14
zerodameaon
You are spot on for what you said above this, but wrong when you say cat last. The fucking thing is 20yo and has 180k mi on it. Yes high NOX is no always a indicator of a bad cat but the damn thing is old and it needs to be replaced regardless.
One thing that affects NOX a lot is timing and yours is way wrong, last time I had a smog I had to have +-3*. Also vac leaks maybe causing your car to lean out could raise your temps causing nox.
Seafoam, change your oil, change your plugs, change your cat, fix what you failed on visual, then go again. Do not rely on denatured alcohol as I have given that a try twice with worse results then before, its not always a fix all.
Old 12-07-2013, 03:56 AM   #15
JF_OverBoosted
JF_OverBoosted's Avatar
JF_OverBoosted is an unknown quantity at this point
lol DAM. My dad had the exact problem with his '96 GST Eclipse.
Only problem was his ECU (other ECU was tuned)
Good luck though dude. I spend about $300 total to pass my S13 vert LEGALLY.
JF_OverBoosted is offline   Reply With Quote
Old 12-08-2013, 12:55 AM   #16
andisan
andisan's Avatar
andisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymoreandisan is not welcome here anymore
My issue was all dirty emission components, so before you start buying new parts, take all your emission parts and clean them real good, take them apart and clean them, I learned the hard way
andisan is offline   Reply With Quote
Old 12-09-2013, 07:37 PM   #17
yetijeff
yetijeff's Avatar
yetijeff is an unknown quantity at this point
Pop the Allen caps on top of ur intake mani runners. They're clean outs for ur egr ports. 90% of these cars have never been cleaned and are packed solid with carbon not allowing egr gasses to pass through.
yetijeff is offline   Reply With Quote
Old 12-10-2013, 05:20 AM   #18
zerodameaon
Home Depot sells a really good bush for this project, also spray the caps down with PB Blaster for a day or two and then get a good pipe and you should be able to get them off with no effort at all. Then use the seafoam intake spray and some carb cleaner along with the brush. Let it air out a bit then seal it up and start the car, it will stumble and have issues idling for a bit. Then do the other passages if you can get to them and repeat the process after which you should do the main one again. Then its a good idea to do your seafoam after this because you already should change your plugs and oil after spraying all that shit into your cylinders.
Old 12-10-2013, 10:32 AM   #19
zooopreme
Trader Rating: (38)
Feedback Score: 38 reviews
^That
This
And this
These posts should be the first things you should try before taking your car back for a smog check. Chances are these parts are backed up and dirty as hell.
Then proceed with the cheaper things on the list and work your way to the more expensive parts if you're still not passing. If you wanted to pass smog with flying colors, you're going to have to do a lot more.
But if that's something you don't want to do, since smog is such a headache when the car runs fine and is relatively stock, get the car to where it barely passes and then proceed to replace/fix.
For Sale #1 | For Sale #2
zooopreme is offline   Reply With Quote
Old 12-10-2013, 03:16 PM   #20
worangejuice
Originally Posted by zooopreme View Post
^That
This
And this
prob try this next, just need to sell the damn thing, its been months of registtering, and smog is the last headache, i have buyer ready.......
1.replaced plugs
2.cleaned out egr intake,behind allen bolt above throttle body
3.used that 'guarantee to pass' stuff (1/2 tank now)
4.seafoamed it
took to a korean shop and guy spoke no english
i fixed alot of stuff and took to a english speaking shop.
said visual inspection fail. one hose was off and EGR doesnt have all hoses hooked up. so I have to hook hoses up. guy i got car from said EGR hooked up fucked car up, so imgonna hook it up properly and go back, Car runs amazinly strong!!! but CA emmisions are the devil..........dreading buying a cat, prob go the illegal route at that point......fucking CA
Oh and im in koreatown
Old 12-10-2013, 04:52 PM   #21
mechanicalmoron
1.replaced plugs
4.seafoamed it
.....what do you mean, the illegal route... the only route to pass is legal, as far as the cat goes.
OF COURSE not having the egr hooked up, which the guy TOLD YOU ABOUT, would make you fail.... hurrdurr.
Drive it hard for a while, and run it at a high idle as you wait your turn. Like, 2k+.
Old 12-10-2013, 06:08 PM   #22
zerodameaon
What so he can waste gas? Sitting in line revving your engine does not help and only calls attention to yourself.
Also unless your best friend will hook you up buying a cat is cheaper and well, not illegal.
Old 12-10-2013, 07:01 PM   #23
mechanicalmoron
No, just let it chill at a fast idle, if it's possible and not obvious.. Don't be all fast and the furious.
Nothing to do with wasting gas. If you don't understand why a hot motor is considerably more likely to have good numbers, there's no helping you.... but I'll try.
When your motor is cold (idle is quite cold, even if it's "warmed up") the combustion is not as complete - this is why we have all these systems that kick in at idle to help with emissions. Oil burns and makes gummy stuff that will burn when you do have to get rpms up for the tests - this is why a car that burns oil will sit and idle and not smoke, but when you touch the throttle it makes clouds - hopefully his car's not that bad obviously, but even a perfect engine MUST burn oil, by design, because it's what lubricates the rings. But the gas as well, and everything sitting around moving slowly in the egr passages and such - if the cat's not so good, you don't want it getting cold, that's why we have a pair valve - to keep it "cooking". You want to go in there with a blisteringly hot engine that's had all the crud burnt out of it right up until the last moment, and a cat that's super hot so it's actually converting like it should be.
Basically your motor slowly fills with coal when it runs cold. Coal is dirty. Dirty fails tests. When it's hot it can keep up with it's own waste production, as well as simply producing less of it. This is also what seafoam helps dissolve, so it can be burnt the rest of the way and blasted out.
Now, I'm half expecting something about how that's what valve seals and piston rings take care of, and they should be replaced.... But if you're not volunteering to pay for his oem rebuild, that's irrelevant. This is an old motor that's probably out of tolerances in many ways. We wouldn't be discussing this at all if it was a perfect situation with a car that had no trouble with this test.
Old 12-10-2013, 07:19 PM   #24
worangejuice
*UPDATE*
NOt "Gross Polluter" on one now, progress? just a 'fail' now ugh.....
INput greatly appreciated........
Old 12-10-2013, 08:39 PM   #25
mechanicalmoron
*UPDATE*
Honestly I don't know what a bpt is, but if it's the egr, take whatever you need to off, and clean it by hand.
The test pass stuff, like seafoam, can't really reach the egr, because it's already burnt by that time. Don't waste your time and gas driving through the rest of the tank.
It still says tampered....?
Old 12-10-2013, 08:53 PM   #26
worangejuice
yeah, Im not sure why, these jerks in koreatown are creepin in deep! lights by the firewall. Caught, 1 of 4 tiny hoses under throttle body disconnected and were like "HOLY CRAP". so maybe i should go elsewhere later. the Egr is directly connected to the BPT *EGR backpressure transducer*
guy vaccuum tested and said it should have pressure/vaccuum, no vaccuum, no EGR working to pull emissions(evaporated gases) back through the system=high nox is what im getting.
EGR is cleanable i read, but the BPT is one of those 'replace only' POS!
so,if I get a new BPT its about $60,im going to be at $170 ;after three failed smog,resmog,smog sessions.
I couldve got a 'hookup' instapass smog for $200ish.,....but i
Old 12-10-2013, 09:03 PM   #27
zerodameaon
Check your EGR, with the car running you can hit the throttle with your hand up under the big round part of the EGR. The diaphragm should move up and down as you hit throttle and let up, if it is moving more then a few mm its working. Also doubt you did this but if you put any flashy vac lines on there they can be dicks and flag that as modified.
Old 12-10-2013, 09:08 PM   #28
worangejuice
perhaps the O2 sensor????
I seafoamed and just havent replaced that...........this is tiring, just trying to sell this thing........runs AMAZING........just not for CA emissions....
Old 12-10-2013, 09:10 PM   #29
worangejuice
cool, Ill check that,I squeezed the egr and it kills engine, but didnt do the 'reverse' action to feel it pull up. Yeah the stupid 4 RED hoses on their from the old owner, sprayed them black, but all this junk has been on for 10 years......
Old 12-10-2013, 09:10 PM   #30
mechanicalmoron
You can test the o2 sensor with the CEL.
Turn the diagnostic screw on the ecu like you would to pop the codes, and start the car (maybe you leave it turned, I forget). It blinks to show that it's either rich or lean, and there's a certain number of times per minute it's supposed to fluctuate for a good sensor, at a certain rpm.
Google it, or it's somewhere in the fsm.
