Old 03-31-2016, 03:13 PM   #1
running_sideways
running_sideways's Avatar
running_sideways is an unknown quantity at this point
Head gasket from apexi out of stock
Alright so I've been ordering parts like a mad man. Got up to the plate with the head gasket was going to hit a homer and get a apexi 86mm x 1.1mm...wrong so far I've struck out everywhere I've went to order one from. There's also no ETA on when there will be more in stock. So my question is who the hell else has basically a stock apexi gasket still in stock! Don't wanna mess with any of my compression ratios and don't want a pos gasket that will go out on me in 6 months to a year.
Thanks everyone for your comments and advice once again!
running_sideways is offline   Reply With Quote
Old 03-31-2016, 04:04 PM   #2
jlmillionaire
jlmillionaire's Avatar
jlmillionaire is an unknown quantity at this point
Je pro seal for the win!!!
jlmillionaire is offline   Reply With Quote
Old 03-31-2016, 04:13 PM   #3
running_sideways
You have a p/n and maybe a review?
Old 03-31-2016, 04:18 PM   #4
jlmillionaire
Honestly I didn't use one but I heard great things about them , I'm going to use one in my Sti and one in my Sr
Old 03-31-2016, 04:19 PM   #5
running_sideways
I'll have to do some digging and see what the survey says thanks much for your suggestion!
Old 03-31-2016, 05:04 PM   #6
dorkidori_s13
ITS LISA'S FAULT!!!
dorkidori_s13's Avatar
Trader Rating: (41)
Feedback Score: 41 reviews
HKS? Greddy/Trust? Cometic? Tomei? Cosworth?
Ever think of trying any of those?
Old 03-31-2016, 05:09 PM   #7
running_sideways
For some reason I can not find 86mm x 1.1mm and no offense but I've heard cometic is not so reliable...my second choice was cosworth but they only if I recall is 87mm X 1.7mm
Old 04-01-2016, 09:11 PM   #8
Tom N
Tom N is an unknown quantity at this point
Took me 47 seconds to come up with this http://www.frsport.com/Cosworth-2000...ck_p_8905.html
http://www.frsport.com/Tomei-1331870...mm_p_1946.html
98 240sx w/ S15 SR20DET, T2 20g, 11.22 @ 124.98
Tom N is offline   Reply With Quote
Old 04-01-2016, 09:38 PM   #9
derass
I'd go with Tomei for the value.
Old 04-01-2016, 09:40 PM   #10
running_sideways
Okay am I high or is a 86mm x 1.1 a stock gasket...that's more my dilemma
Old 04-01-2016, 10:40 PM   #11
Tom N
A stock gastet to my understanding is 1.1mm thick. Stock bore is 86mm. So a 87x1.1 is fine. Now if you have surfaced the head and/or block you might want a slightly thicker gasket to counter your now shorter deck night and as to not throw off your mechanical timing components.
Old 04-01-2016, 10:42 PM   #12
running_sideways
I understand a 1mm fuck up the lip of the head and the block...I may be stupid but it doesn't seem correct...my ocd really pisses me off but I like to be to the gnats ass when building shit
Old 04-01-2016, 10:44 PM   #13
running_sideways
Sorry...few Jim beams wouldn't 1mm fuck up the edges of the block and head
Old 04-01-2016, 10:44 PM   #14
Tom N
I don't understand what you are saying?
Old 04-01-2016, 10:45 PM   #15
Tom N
Are you asking if it's ok to use a 87mm gasket on a 86mm bore?
Old 04-01-2016, 10:46 PM   #16
running_sideways
Yes in a nut shell...
Old 04-01-2016, 10:46 PM   #17
running_sideways
I ant got a good brain...
Old 04-01-2016, 10:48 PM   #18
Tom N
I see that...
Old 04-01-2016, 10:49 PM   #19
running_sideways
Glad you can agree
Old 04-01-2016, 10:56 PM   #20
running_sideways
Sorry man. I've always gone by spec for everything I've ever worked on and I don't have a service manual for this engine that will show me what something is down to the thousands so if it's not correct I get worried and I ask to many questions...Sooo if the engine bore is a 86mm i should need a 86mm bore gasket if I didn't deck the head or block then "stock" gasket should be a 1.1mm well apexi has a 86mm X 1.1 mm gasket but it's not in stock or has an eta on when it will be
Old 04-01-2016, 11:12 PM   #21
Tom N
Most oem head gaskets run 1mm bigger than the factory bore. Using a 87mm gasket on a 86mm bore is fine and completely normal. It's only .5mm larger on each side of the bore. You just don't want one smaller then the bore.
Old 04-02-2016, 01:18 PM   #22
Kingtal0n
Kingtal0n's Avatar
I've never even seen an 86mm HG. IS it a myth? If you did order one, what if they sent you 85.97mm by manufacturing flaw? How long do you think the .03mm overhang will last in there? And do you think it will stop there at .03 burning off? Probably a little more will burn off than that, leaving you with 86.01+mm of headgasket anyways.
Better just to use no gasket at all. Seal it with duct tape and permatex. Or the zilvia special, weld that shit. Everybody here loves to weld their shit together. "gaskets are for chumps" they said. its just cause "they don't make a zip tie big enough for that"
Old 04-02-2016, 01:24 PM   #23
running_sideways
Serious as a heart attack man, apexi websites got them but not in stock. So when I go to order somethings for a std 86mm bore I figured hey what the hell 86mm must be correct but only stock is 87mm. Thickness I understand perfect as far as not getting the same size gasket as bore diameter just seemed fishy.
I'm thinking jb weld and fucking rtv mixture will be prime for race wars...
Old 04-02-2016, 01:37 PM   #24
Tom N
Seriously, if you don't understand why a 87mm gasket is good to go on your stock bore then please put the tools down for now...
I would just use a cardboard cutout of exactly 86mm ( good luck ) and slap some hylomar on it. You'll be all set...
Old 04-02-2016, 01:39 PM   #25
running_sideways
No dick I understand as long as it's not undersized it's fine I'll order a 76 and call it A day be good for life!
Old 04-02-2016, 01:40 PM   #26
Tom N
Use one of the ones I gave you a link to or order a apexi 8711 head gasket. Or 8708 if you want a little extra compression. and be done with it.
Old 04-02-2016, 01:41 PM   #27
running_sideways
Gotcha
Old 04-03-2016, 08:34 AM   #28
Javi802
Javi802's Avatar
Javi802 is an unknown quantity at this point
Also, wouldnt that 87mm gasket bore become smaller after being compressed with 80 foot pounds of torque? Bringing it closer to the bore size of the cylinders themselves?
Javi802 is offline   Reply With Quote
Old 04-04-2016, 11:41 AM   #29
pacotaco345
pacotaco345's Avatar
pacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond reputepacotaco345 has a reputation beyond repute
Holy shit you guys are overthinking this. Just buy a tomei 1.2mm thick, 87mm bore gasket. Its a piece of metal that goes between two other pieces of metal, not rocket science.
pacotaco345 is offline   Reply With Quote
Old 04-04-2016, 12:05 PM   #30
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
THIS. Meanwhile, can we reinvent the wheel?
