Old 07-17-2017, 08:07 PM   #1
Laujpha
Laujpha is an unknown quantity at this point
Help! R32 caliper
Can someone help!!!!!!I recently bought a set of front caliper to do a big brake conversion on my s13. The caliper i got was from a r32...the caliper are aluminium and i need to buy some rotor but sure if the caliper are 26mm or 30mm.. i did a measure of the gap where the rotor sit in it and it's like 1 3/8 about 2inch off from being 1 1/2. The guy that i bought it from say that 300zx rotor fit but i just want to verify before i buy the rotor.
Laujpha is offline   Reply With Quote
Old 07-17-2017, 08:32 PM   #2
marveluz
marveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enoughmarveluz will become famous soon enough
1 3/8th of an inch is just shy of 35mm. So I'm not sure what you're asking. Use the search function, there's a lot of info about OEM brake upgrades.
marveluz is offline   Reply With Quote
Old 07-17-2017, 09:17 PM   #3
Laujpha
I did alot of research and all point to 30mm calipers but the guy sold it to me said it was 26mm calipers and they all use the same rotor as z32.
Old 07-17-2017, 09:38 PM   #4
3NDLESS
3NDLESS's Avatar
3NDLESS is an unknown quantity at this point
Look again
Originally Posted by drift into a curb View Post
There is a difference between the GT-ST and GT-R brakes if you want to be specific. The GT-R uses a brembo. 300zx uses a 280x30mm rotor size.
Upon searching, here's some better size info:
350Z standard brakes:
Rotor size 296mm x 24mm
Nissan 2 pot calipers, same pads as 91-02 Maxima
300ZX (Z32) brakes:
Rotor size 280mm x 30mm
Nissan/Sumitomo 4 pot calipers
R32 GT-R brakes (sold through Nismo USA as "Skyline" brakes):
Rotor size 296mm x 32mm
Nissan/Sumitomo 4 pot calipers, same pads as Z32
350Z track model brakes:
Rotor size 324mm x 30mm
Brembo 4 pot calipers, same pads as R33/R34 GT-R, BMW 850
I searched "r32 calipers on z32 rotors" Now it said theres a dif between GT-ST and GT-R brakes but it doesn't say, so yeah. But I'm just gonna put this information out there.
Heres from another forum.
______________
Front
S13 CA18det = 256mm x 22mm 1-Pot (88-91)
S13 CA18det = 280mm x 22mm 1-Pot (91-94)
theres no S13 with 4 pot even not the Type-X so far i know
S14 SR20det = 280mm x 28mm 4-Pot
Z32 TT VG30dett = 280mm 28mm 4-Pot
BNR32 RB26dett = 296mm x 32mm 4-Pot
ECR33 RB25det = 296mm x 30mm 4-Pot
BCNR33 RB26dett = 324mm x 32mm 4-Pot
ER34 RB25det = 310mm x 30mm 4-Pot
BNR34 RB26dett = 324mm x 32mm 4-Pot
____________________________
So I gave you all the information you need that you could've found maybe within minutes if you reword or worded differently. Now this is all the info you need 99.9%.
3NDLESS is offline   Reply With Quote
Old 07-18-2017, 04:22 PM   #5
marveluz
I doubt the OP has r32 GTRs.
Post a pic and we can help you identify the calipers.
It sounds like you have R32 GTS brakes which use a 280mm rotor similar to Z32TT and S14SRs as listed.
Old 07-18-2017, 04:50 PM   #6
Jefro240
Jefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enoughJefro240 will become famous soon enough
R32
GTS-4 280x26mm ?
GTST 280x30mm 297x18mm
GTR 296x32mm 297x18mm
GTR V-Spec 324x30mm 300x22mm
| 92 S13 Hatch | 92 S13 Coupe | 95 S14.5 |
Jefro240 is offline   Reply With Quote
Old 07-18-2017, 09:20 PM   #7
Laujpha
I try to post pictures but i cant..how do i post up pictures
Old 07-18-2017, 10:13 PM   #8
3NDLESS
3NDLESS's Avatar
http://zilvia.net/f/showthread.php?t=169695
Go ^ and upload your pictures to something like imgur or imageshack. Avoid photobucket because its a pos now.
Old 07-19-2017, 08:52 AM   #9
ixfxi
Guest
Posts: n/a
you just need z32 rotors. not the 26mm thickness, but the 30mm thickness.
you can special order gtr rotors for that extra thickness if you indeed have gtr calipers, but its not worth the wait. no one states-side will stock them, or very few will.
Old 07-19-2017, 09:26 AM   #10
Sileighty_85
Sileighty_85's Avatar
All R32 GTS-t's use 30mm rotors
This a BNR32 Caliper
this is R23/Z32 aluminum Caliper 26 and 30mm look identical
後輪駆動車1番
1989 Built SR GT2871R -363whp
1986 SR86 - 200ish
1990 R32 GTR - 320hp
Old 07-19-2017, 11:49 AM   #11
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
R32 GTR calipers use specific rotors, 30mm Z rotors will not work. To the best of my knowledge the GTS-T's did use 30mm rotors, but the diameter is larger (29x mm vs 28x mm). You need to know for sure what calipers you have so you can get the right rotors, which will not be cheap or easy to find. As shown in the post above the GTR calipers have no fins on them...
Old 07-19-2017, 12:33 PM   #12
OutlawLui
OutlawLui's Avatar
OutlawLui is a well-known jackass
Sell them and get z32
Done and done
OutlawLui is offline   Reply With Quote
Old 07-20-2017, 12:00 AM   #13
ixfxi
Guest
Posts: n/a
Done and done
thats shit advice
i am posting a screengrab from the older DBA catalog. if you cant figure out what you need from this, then you need to stop modifying cars.
you can get rotors from stillen if you want to be bent over, or try ebay UK
Old 07-20-2017, 12:22 AM   #14
KiLLeR2001
Trader Rating: (46)
Feedback Score: 46 reviews
Get that trash out of here, where is the LFA caliper spec sheet.
Old 07-20-2017, 08:37 AM   #15
Laujpha
Thanks for all the help and advice..the caliper i have look like the gold caliper on the pix above.it does have fins and it seen to be a gts-t 30mm aluminum caliper.
Old 08-01-2017, 01:46 AM   #16
jumboflan
jumboflan's Avatar
jumboflan has a little shameless behavior in the past
And people used to think 26mm and 30mm z32 calipers were the diameter of the physical pistons . Some people Mis represent facts. It's indeed the size or thickness of rotors each type will accommodate.
Im immune to bullshit....so put your shovel away.
jumboflan is offline   Reply With Quote
