Old 12-14-2005, 09:58 PM   #31
RBS14
RBS14's Avatar
RBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura aboutRBS14 has a spectacular aura about
Idle is actually rock solid when it's cold without an idle control solenoid. Not talking like 30 below, but everything I've run into in cali has been fine. There is a coolant temp correction map in the Haltech. For each degrees below operating temp, it increases fuel X amount. This is actually a seperate map, and is definable and tunable by the user. A relatively rich mixture during warmup somewhat suffices as an idle control solenoid. I just set idle to 1krpms when fully warmed up, with an AFR of about 16:1. At startup it's at about 900 and an AFR of about 13:1. I have tuned it so both idle speed and afr creep up until it's warmed up.
Brandon: sure thing!
RBS14 is offline   Reply With Quote
Old 12-14-2005, 11:08 PM   #32
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
sick Scott just plain sick!! Keep up the good work man.
New Video
Buy my mounts!
Old 12-14-2005, 11:49 PM   #33
NemeGuero
No more nissan.
NemeGuero's Avatar
Ya missed my post about your fuse box n stuff..
Old 12-15-2005, 09:24 AM   #34
RBS14
RBS14's Avatar
Oh sorry. I tore apart the fuse box. I pulled all the fusible links and fuses that I didn't need and was left with like 10 wires, 2 fusible links, and 2 fuses. So I cut off all the extra plastic that the other fuses were stuck in. Then I cut out a bunch of the wires I didn't need, shortened a bunch of the ones I was still using, and wrapped it all back up. I ended up putting the few fuses that were left just behind the core support behind the passenger headlight. I'll post up pics this afternoon. I chose to put it there instead of lengthening the wires to put it back in the cab somewhere. The less the resistance, the better. Then I took the wires that ran from the battery to the starter and fuse box, and put them in a distribution block behind the passenger shock tower, and put the battery in the back of the car. Worked out pretty well.
Old 12-15-2005, 12:29 PM   #35
infinitexsound
infinitexsound's Avatar
infinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond reputeinfinitexsound has a reputation beyond repute
uppin to a haltech good shiet scott, guess that megasquirt wasnt really cuttin it for yah... they finally got it, the SCCA finally got the SIR worked out for the ka24de its at 35mm... LOL
S14 TrackSlut coming to a raceway near you...
510 TimeAttack on its way...
infinitexsound is offline   Reply With Quote
Old 12-15-2005, 12:34 PM   #36
NemeGuero
No more nissan.
NemeGuero's Avatar
Wow, that's awesome.. I'd love to do that. Except I probably need most of the stuff I have... Yah, pics'd be cool. And if you're feeling extra generous (or bored) a list of things you aren't using.
Old 12-15-2005, 01:51 PM   #37
Gnnr
Gnnr's Avatar
Gnnr is offline   Reply With Quote
Old 12-16-2005, 08:19 AM   #38
honduh
honduh is an unknown quantity at this point
Send a message via AIM to honduh
That is one awesome setup! I was amazed when I read the DIY for the ITB's and can't wait to see the dyno. I just wish I could hear it in person
honduh is offline   Reply With Quote
Old 12-16-2005, 08:58 AM   #39
The Riot Hero
Banned from the Marketplace
The Riot Hero is on a distinguished road
Send a message via AIM to The Riot Hero Send a message via Yahoo to The Riot Hero
damn scott, bout damn time you got some degrease ron your motor! looks good dude. hit me up on AIM
The Riot Hero is offline   Reply With Quote
Old 12-16-2005, 10:35 AM   #40
tastyratz
tastyratz's Avatar
tastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to beholdtastyratz is a splendid one to behold
Send a message via AIM to tastyratz
thats awesome dude. i love your car :-) actually for dohc cams you might wanna check out colt cams. hes got a new cam called the tri-flow for the dohc which is supposed to blow the pants off his already successful grinds he sells. I havent talked to him in awhile but last I heard pdm is the only company that sells them and he wasnt selling the grinds himself. you would have to call and specifically ask for the triflow grind had alot of good results ive heard in canukland but its still new and not on the site. that would be killer on your itbs man!
tastyratz is offline   Reply With Quote
Old 12-16-2005, 11:19 AM   #41
RBS14
RBS14's Avatar
Here's a pic of my fuse block now.
What am I not using anymore?... hmmm. Well everything you don't need to run an engine or turn on your headlights. No A/C, radio, heater, etc... I'll eventually do a painless wiring harness, so I can scrap the stock harness alltogether.
Old 12-16-2005, 08:03 PM   #42
ootranceformeroo
ootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to beholdootranceformeroo is a splendid one to behold
Send a message via AIM to ootranceformeroo
bitch! ahah makin me want to build up my KA before i think about turbo first. or at least rebuild and build my ka. thats awesome dude. hows the other one commin along?
Gorgeous Garage
Touge Friends
CrabDrifting.com
Drift Unit
ootranceformeroo is offline   Reply With Quote
Old 12-17-2005, 11:47 PM   #43
outerheaven2k4
outerheaven2k4 is an unknown quantity at this point
Awesome dude
I've been following your work on the ITB KA, and its even insipired me to even try it on my car (only difference is that I have a 89 KA24E and wanna throw a DE head on it so I have to use the intake mani anyway ^_^). Was wondering how much the haltech setup cost ya?
outerheaven2k4 is offline   Reply With Quote
Old 12-18-2005, 11:40 AM   #44
Hitawall
Hitawall's Avatar
Hitawall is an unknown quantity at this point
what ever you did is hot man , i am feelin the intake side of the set up if looks could kill you would be a killa big props
Hitawall is offline   Reply With Quote
Old 12-18-2005, 12:00 PM   #45
SoSideways
SoSideways's Avatar
What?
You do know that he did the ITBs for performance gains, and not for looks right?
Kinda like his car is super slammed because it serves a purpose, and not just because "it looks kirra".
