Old 08-07-2006, 05:57 PM   #1
Citystars
Citystars has made poor choicesCitystars has made poor choicesCitystars has made poor choicesCitystars has made poor choicesCitystars has made poor choicesCitystars has made poor choicesCitystars has made poor choices
HELP! Short Shifter Instal
Hey, im installing a shortshifter, have a few questions.. I have it almost off except for the 2 bolts at the front, one of them is completly loose, but there isnt enough room inbetween the tranny and the body to remove it...
1)How the fuck do you get the bolts off that are that the front(closest to the motor) They are underneath everything, how do you get them off?
2)Do I need to drop the tranny to remove/install the shifter plate(I think thats the name of it)
3)If I could, should I saw the bolts off? Or is it a must that I reinstall those bolts so shit doesnt get into my tranny or whatever.
Hopefully someone can give me help ASAP because I am in the middle of doing this right now hehe
Citystars is offline   Reply With Quote
Old 08-07-2006, 08:30 PM   #2
Slidin240Wayz
Slidin240Wayz's Avatar
C-stars- you can use clean language to express yourself. Just because you don't know something doesn't mean you need to use vulgarity.
As for those bolts, chase them down with a wrench. If you can't, then use an extended wrench. If you saw them off, how are you going to take them out afterwards?
Old 08-07-2006, 08:34 PM   #3
NIK90s13
NIK90s13's Avatar
NIK90s13 is making a name for him/her selfNIK90s13 is making a name for him/her self
Lower the tranny, don't cut the bolts. With the tranny lowered you will have room to get to the bolts. Remove the shifter from the plate, slide the plate in from the bottom, install bolts, then raise tranny, install shifter, then enjoy your new hotness. good luck.
NIK90s13 is offline   Reply With Quote
Old 08-07-2006, 08:42 PM   #4
ramblux
ramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of lightramblux is a glorious beacon of light
Ghetto way is to get a pry bar and pry the metal away enough from the tranny to get the bolt on. Then hammer it back. haha
ramblux is offline   Reply With Quote
Old 08-08-2006, 02:09 AM   #5
miucus
miucus's Avatar
miucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond reputemiucus has a reputation beyond repute
get the flexible head wrench with gears like http://www.sears.com/sr/javasr/produ...seBVCookie=Yes
i used it then returned it after i installed it
miucus is offline   Reply With Quote
Old 08-08-2006, 02:50 AM   #6
Munch
Munch's Avatar
Munch is an unknown quantity at this point
I got to em using a pretty ghetto/crappy method...i just drilled holes in the floorpan right above where the 2 bolts are and stuck a ratchet down there. crappy idea, i know, but it worked.
Munch is offline   Reply With Quote
Old 08-08-2006, 08:41 AM   #7
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
hmmm... why just not pull out the shifter leaving the plate on? It's not a big deal.
Old 08-08-2006, 10:05 AM   #8
bshotts
bshotts's Avatar
bshotts is making a name for him/her selfbshotts is making a name for him/her self
Send a message via AIM to bshotts
If you pull out the shifter which is attached to the plate, the plate will be left on.
When I installed my B&M, like someone mentioned before I used a hole saw to cut perfect holes in the transmission housing metal directly above the two front bolts and used a socket to remove. However, to prevent rust and avoid a sloppy look, I sanded, primed, and painted the surrounding holes and area. I then installed two capped rubber grommets around the holes...done. This is all to avoid dropping the transmission if you dont have much room to work with.
bshotts is offline   Reply With Quote
Old 08-08-2006, 11:22 AM   #9
Citystars
hmm.. I actually got it right after I posted. Good things when your best friends dad is a parts technician. Put a jack under the tranny, unbolt the crossmember, lowered it about an inch, got them out.
Now my only problem is that the gasket inbetween the tranny and the shifter plate was ripped, can I just get something like this at any parts store? or Do I need to make gaskets...
