Old 04-06-2007, 05:15 PM   #91
twofortyrida1388
twofortyrida1388's Avatar
twofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura abouttwofortyrida1388 has a spectacular aura about
About that injector site. How long would that take for them to do what they do and then me getting them back. Basically roughly the time from which I send them out to when I get them back.
twofortyrida1388 is offline   Reply With Quote
Old 04-06-2007, 05:17 PM   #92
twofortyrida1388
I dont have a multi meter. ECU didnt show it either.
Old 04-06-2007, 05:43 PM   #93
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
MELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfectionMELLO*SOS is close to perfection
They sell cheap Digital Multimeters, go look at Radio Shack or even Home Depot. They are an invaluable tool for diagnosing problems and testing circuits, you'll wonder how you got by without it (hmm it's that way with all tools though)
They are fast, the biggest wait is the shipping time. But figure a week or so with round trip shipping. Just call them or send them an email or PM...
MELLO*SOS is offline   Reply With Quote
Old 04-06-2007, 06:32 PM   #94
BigVinnie
BigVinnie's Avatar
BigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfectionBigVinnie is close to perfection
Originally Posted by 240silvia
He doesn't have the clutch fan on the car.....
Next.... lol.
Sterling this is the longest problem I've ever seen.
Your just retarded with bad rep anyways.
Next.... lol.
Well obviously to have this thread go on for so many pages just makes you incompetent. If the ecu throws out a code saying it's the MAF, it is something with the MAF. Just to help you out a bit you probably have a faulty ground. Within the three wires there is a Black with white strip, a white wire and an all black wire. More than likely you have a faulty ground that needs to be bypassed (this would be the black wire).
Sorry if the pics are shitty, but I have had to do this on a few s13's. Mine happens to be one of them.
Then properly ground out to the chassis.
It doesnt hurt to bypass the ground. It will save you a headache from buying a volt meter.
There you go I am tired of spoon feeding.
BigVinnie is offline   Reply With Quote
Old 04-06-2007, 07:13 PM   #95
twofortyrida1388
Well then it said 55(OK), I just checked it again and got 11 CPS. I checked all grounds and their good. Just in case Ill check it again when its light. Thank you sir, I will do that tomarrow and tell you if it does it.
Old 04-08-2007, 09:40 PM   #96
twofortyrida1388
I grounded the MAF same spot and made sure no paint or corrosion blocked it and it is still acting retarded. Step 1 buy multi meter, Step 2 test TPS, Step 3 test CTS, Step 4 new MAF, Step 5 part out KA and buy newer one. Oh before step 5 I'll send injectors out by that recommended site.
Old 04-09-2007, 10:23 PM   #97
twofortyrida1388
Dont know if this matters but before oil pan and valve cover gaskets went in they sprayed oil all over tps and basically everthing thing else in front area of hood and throttle body down is covered with gunk just straight oil and dirt.
Old 04-09-2007, 11:17 PM   #98
ripnbst
ripnbst's Avatar
ripnbst is making a name for him/her selfripnbst is making a name for him/her selfripnbst is making a name for him/her self
Well then thats probably a good place to start. I am having this same problem, I asked around locally and someone asked me if my timing has been messed with. I just recently acquired the car so I dont know if the timing is off. I am gonna check it next week and probably take it to autozone this week and have the codes pulled from the ECU. I will let you guys know what the codes are when I get time to take it. Yes this is a really long thread which I just every word of and all the recommendations help, all the useless bitching about thread length is just that, useless bitching.
In all my reading I have compiled a list of culprits here it is:
1. Injectors
2. MAF
3. Timing
4. MAF WIRING
5. Knock sensor
6. Fuel Filter
7. TPS (Throttle Position Sensor?)
8. Air entering after the MAF
9. IAVC
10. EGR
Did I miss anything?
In the market for a Clean Coupe
ripnbst is offline   Reply With Quote
Old 04-09-2007, 11:40 PM   #99
wickeds13
wickeds13's Avatar
wickeds13 is an unknown quantity at this point
Is there white smoke coming out of your exhaust? If it is it may be a blown head gasket or valve seals. If not it might be a blown valve. Cause I'm having the same problem too.
wickeds13 is offline   Reply With Quote
Old 04-10-2007, 12:00 AM   #100
twofortyrida1388
Mine doesnt even burn oil(no smoke). You forgot the KA bog curse lol. A shit load of people seem to have it and they are all unique. I guess I will rip TB out and clean it too. If this shit aint right by the time all this stuff is checked and/or replaced a newer s14 setup is going in or a low mile s13. Today my alternator belt shredded when I dropped it into second at 45 keeping this car from passing me on my way home from work. When I got home I wasnt certain and when I revved it it would pretty much die. Like it didnt come off but it shredded in half. About a pencil size thread left got me home. Wire was thrown all over.
Old 04-10-2007, 12:24 AM   #101
s13_gearhead
s13_gearhead's Avatar
s13_gearhead will become famous soon enoughs13_gearhead will become famous soon enoughs13_gearhead will become famous soon enough
Send a message via AIM to s13_gearhead Send a message via MSN to s13_gearhead
Thanks man. rip that egr shit out. all the shit to right. all its doing is putting exhaust back into your intake. my throttle body was soo gunky it would make a smack noise when I whould open it from all the bullshit from exhaust. Like pulling that putty shit out of it plastic container(that kid putty shit). Yeah dude if you read my first post I have fixed/replaced 90% of what it could be. now comes the exspensive shit.
You mean all the EGR does it put exhaust back into the intake? I thought it was like, exhaust gas recirculation or something!
s13_gearhead is offline   Reply With Quote
Old 04-10-2007, 11:59 AM   #102
twofortyrida1388
Yeah that is what it is. The exhaust gas gets reused with intake air. http://www.asashop.org/autoinc/nov97/gas.htm
Old 04-10-2007, 12:40 PM   #103
ripnbst
ripnbst's Avatar
Not sure, but twoforty...I am pretty sure he was kidding. I am running my car to autozone to run the ECU codes in an hour and see what comes up and I am also gonna ask if they can use their timing gun to check my timing and see what that looks like. My idle after it warms up is walkin all over the place which is why the timing is suspect to me. If it looks good then I can cross it off the list of possible culprits.
Old 04-10-2007, 12:43 PM   #104
twofortyrida1388
Well I had to make sure anyway. You never know with some people.
Old 04-10-2007, 12:57 PM   #105
drewc87
drewc87 is a well-known jackass
what about a fuel pump? have you checked to see if your getting fuel pressure?
drewc87 is offline   Reply With Quote
Old 04-10-2007, 01:54 PM   #106
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Have you checked your ECT sensor?
Also be wary of the codes that the Autozone scanner will give you. The numerical code should be right, but the text description of the problem may not be. Get the #s and look them up yourself to be sure.
Old 04-10-2007, 10:05 PM   #107
twofortyrida1388
I actually was thinking maybe fuel pump for the fact that if it is ran dry it can damage the pump because the fuel acts also as a coolant for the pump.
Old 04-11-2007, 10:31 AM   #108
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Yup. I noticed a nice power improvement going from my stock pump to the Walbro, made me think that maybe after 14 years the stock pump was a little tired... If you pick up a Walbro you should also get a Nismo FPR. This is because the Walbro has a tendency to overrun the stock FPR and cause you to run too rich. Even if the pump turns out to not be the problem at least it's upgraded and you're ready for any swap or KA-T setup.
Old 04-11-2007, 10:38 AM   #109
twofortyrida1388
Thanks man. Walbro's are awesome there on ebay for like 100 bucs. I'll check to see how much the Nismo FPR will cost. Since I work at Advance I'm thinking of just getting a brand new maf and tps. Old tps is covered with oil and dirt.
Old 04-11-2007, 11:53 AM   #110
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
There is a guy/company on here that sells the Walbros for like 90 something shipped. And the Nismo FPR is like $80 to $100ish, check performancenissan.com I think thats where I got mine from. GL
Old 04-11-2007, 01:55 PM   #111
ripnbst
ripnbst's Avatar
Took my ride to autozone and it ran 5-5, meaning A-OK. So I dont know wtf I am gonna do. What would cause this problem that wouldnt show up on the ECU? I am thinking if it was MAF related it woulda tripped the ECU. I am gonna check the timing and see what thats like. I am also thinking it might be air entering after the MAF. My buddy I showed my car to said that his dads car was acting this same way and it ended up being an intake mani. gasket. Is there any way to check if they are leaky? I am thinking it has got be air coming after the MAF aka the gaskets or its the timing. It runs pretty rich and it has no balls top-end so I think it might not be getting the air it needs. Any thoughts?
Old 04-11-2007, 03:19 PM   #112
MELLO*SOS
LAID OUT
MELLO*SOS's Avatar
Yes you need to pressure test the intake system. Look at this post I just wrote on another site... It's for a turbo motor but the concept and procedure is identical for NA engine...
Originally Posted by Me on the "other board"
You don't really need to seal off the end by the TB, if you want to test the entire system for leaks. If you wanted to test a specific component you could do like you say and put a cap on the "other end" of the cold pipe. All you really need is a pressure test adapter, either build your own or buy one:
Then clamp it to the MAF or compressor inlet or hotpipe inlet with a silicone coupler. Set your tank (or inline) regulator to your test pressure (5-20psi) and pressurize the system. You can listen for leaks and/or spray suspected leaks with soapy water.
Old 04-11-2007, 05:35 PM   #113
twofortyrida1388
Thanks a lot mello88. With your ongoing help I'm sure we will fix this damn annoyance.
Old 04-11-2007, 05:50 PM   #114
ladiesman8527
ladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enoughladiesman8527 will become famous soon enough
i made one of them things when i had a bad vacuum leak that i couldnt find. it was a really big help.
ladiesman8527 is offline   Reply With Quote
Old 04-11-2007, 05:56 PM   #115
twofortyrida1388
I'm gonna hit up Home Depo and make one. I really hope its tps or something else other than intake mani.
Old 04-20-2007, 09:07 PM   #116
twofortyrida1388
I'm gonna make that tip to test any leakage this weekend and tell you what happens.
Boost Coming soon...
Old 04-23-2007, 11:22 AM   #117
twofortyrida1388
I compression tested the intake and it turns out my fpr actuator had a busted hose. But I put a new hose on and that was a bitch. It is right on the fire wall basically. But when I replaced it my car still bogged but ran much stronger 1st-4th. It didn't struggle as much to get to a hundred. I retested it and there is still a hissing coming from behind intake mani and I can't ell from where. The hose is fine. It sounds like its coming from the actuator but its not cracked or anything it seems fine. Does anyone know what it could be back there leaking. I now know its a vacuum issue and not anything else.
Old 04-23-2007, 11:49 AM   #118
ladiesman8527
what about the line from the brake booster to the intake mani? ive had troubles with those leaking before. i recommend changing that line to a one piece line. its a two piece line from the factory and that just makes more potential places to leak.
Old 04-23-2007, 12:23 PM   #119
Taba13
Taba13's Avatar
Taba13 is an unknown quantity at this point
Send a message via AIM to Taba13 Send a message via MSN to Taba13 Send a message via Yahoo to Taba13
the fatter of the black wire community in the lastic sheild above the fuel rail!
sneaky little thing it is, mine too had this ever so slight bump in it, so i thought about it, roamed around here for a few minutes and decided to check this bump out, i pulled apart the black shielding right in area of that bump, what i noticed was seriously something for all to consider.
the white wire inside the wrapped silver shielding wire was cracked just enough for 1 measly little strand of that shield to touch the cracked part of the white wire, that crack exposed the internal copper inside the white shield, therefore making a short.
unfortunately im just looking as to why my KA isnt as perky as i have tuned it to be, yeah it moves but not how i expect.
SO point is: check that wire, it is always better to be absolutely positive, if it means cutting it in 2 just to solder it back together so be it, at least it was checked intensively.
thanks to all who actually suggested that wire!
cardomain~~~myspace~~~www.tabadesigns.com
Taba13 is offline   Reply With Quote
Old 04-25-2007, 10:52 AM   #120
twofortyrida1388
I have arlready checked the wire. My problem is a vacuum leak. The car is getting worse its like my oil leaks a shitload more and the car is driving shitty. Its overheating by my standards. The gauge doesn't say it in dash but I can def tell. Its getting soo hot my thin Al. cai is sizzling to the touch even after 10 or so minutes of the car sitting off with the electric fan blowing.
