Old 06-06-2007, 07:55 PM   #1
dopeassjackson
dopeassjackson is a well-known jackass
nismo 2way lsd oil
i got some royal purple synthetic gear oil for my nismo 2way (bought it used) and it says to use it in limited slips. im not sure if i need the friction modifier.
its 75W-90.
dopeassjackson is offline   Reply With Quote
Old 06-06-2007, 10:11 PM   #2
kouki_s14
kouki_s14's Avatar
kouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfectionkouki_s14 is close to perfection
Send a message via AIM to kouki_s14
was that a statement or question?
kouki_s14 is offline   Reply With Quote
Old 06-06-2007, 10:24 PM   #3
koukimonster139
koukimonster139's Avatar
koukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfectionkoukimonster139 is close to perfection
Send a message via AIM to koukimonster139
i dont see no question marks!!!!!!!!!!!!!!!!!!!!
ho ha ho chi chi
koukimonster139 is offline   Reply With Quote
Old 06-07-2007, 04:23 AM   #4
dopeassjackson
im not sure if i need the friction modifier?
Old 06-07-2007, 11:16 AM   #5
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
You don't need friction modifiers. All they really do it make the clutchs slip more so they make less noise. Also, not sure if your lsd recommends synthetic but some companies do and some do not.
Jung918 is offline   Reply With Quote
Old 06-07-2007, 11:34 AM   #6
420sx
420sx's Avatar
420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future420sx has a brilliant future
incorrect. do you even own a clutch type?
friction modiefiers not only reduce noise but they reduce wear by alot. most diff fluids contrain friction modiefiers for example kaaz and tomei fluids and thats what is recommended by the manufacturer.
not using fm is not going to kill you but expect to wear out your plates 2-3 times as fast.
hydropgrahics!
ls1......
420sx is offline   Reply With Quote
Old 06-07-2007, 11:41 AM   #7
kensreliableb18b
kensreliableb18b's Avatar
Location: so cal - 626, 909, 562 and 949. 818 if i feel like running away
kensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nicekensreliableb18b is just really nice
nismo can take synthetic (they include it with their own units).
kensreliableb18b is offline   Reply With Quote
Old 06-07-2007, 11:48 AM   #8
Slidin240Wayz
Slidin240Wayz's Avatar
Ditch the royal purple.
Run the motul diff fluid. You can buy 2 can shipped from shawn@rttuning and pay less than driving to a place and picking up kaaz or tomei fluid.
Carlos
Old 06-07-2007, 01:01 PM   #9
Dousan_PG
Dousan_PG's Avatar
ive used redline forever in my nismo
Aaron
Pink GodziRa
Old 06-09-2007, 04:42 PM   #10
overb0ost
overb0ost's Avatar
overb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to beholdoverb0ost is a splendid one to behold
hey, quick question.
when you install a 2way, nismo or kaaz etc. did you guys get new shims or did you reuse the old ones in the vlsd?
any difference? thanks
overb0ost is offline   Reply With Quote
Old 06-09-2007, 07:16 PM   #11
Jung918
Jung918's Avatar
Actually I have a Kaaz 2 way. I got it installed by someone that used to work at Kaaz and that is the information that he told me. I'm guessing he knows more about it then you do.
Old 06-11-2007, 06:13 PM   #12
overb0ost
overb0ost's Avatar
alright just some questions that i couldn't find answered in the past.
i got a nismo gt pro lsd and it comes with synthetic 80w90. for the break in period, i heard its better to use regular oil because of the oil properties, it actually breaks in the diff. just like engines, you use regular and then use synthetic, same theory for differentials? should i use the same grade of oil or different for break in?
also, i've heard that it is very very VERY rare that people need to reshim or relocate the shims in the differential. what would cause this to happen?
thanks!
