Old 07-28-2007, 11:41 AM   #1
ZenkiKid
ZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud ofZenkiKid has much to be proud of
KA to engine flush or to not engine flush?
im nearing my next oil change within a couple hundred miles from now, my car just went past 155k miles on my ka24e, and i can hear my lifters sticking. Should i try out an engine flush? ive searched everywhere and all ive seen is that its dangerous to do the high pressure flush, but that is not the route that im going, i was thinking of using the flush that you just let run in your motor for a couple of minutes prior to the oil change.
what do you guys think.. yay or nay?
ZenkiKid is offline   Reply With Quote
Old 07-28-2007, 05:34 PM   #2
spitfire7
spitfire7's Avatar
spitfire7 is just really nicespitfire7 is just really nicespitfire7 is just really nicespitfire7 is just really nicespitfire7 is just really nicespitfire7 is just really nicespitfire7 is just really nicespitfire7 is just really nice
take it to a shop and ask them.
spitfire7 is offline   Reply With Quote
Old 07-28-2007, 06:15 PM   #3
nassin31spr
nassin31spr's Avatar
nassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to beholdnassin31spr is a splendid one to behold
Its safe but really doesn't do a lot. Make sure you don't go over the predetermined minutes and don't overfill it by even the smallest amount or your engine will be damaged to say the least. You could benefit more from running a higher quality oil filter and oil.
"Home is where the armor is"
nassin31spr is offline   Reply With Quote
Old 07-28-2007, 06:25 PM   #4
bigOdom1
bigOdom1's Avatar
bigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfectionbigOdom1 is close to perfection
oem oil filter ftw
bigOdom1 is offline   Reply With Quote
Old 07-28-2007, 06:54 PM   #5
jramosthe1st!
jramosthe1st! has made poor choicesjramosthe1st! has made poor choicesjramosthe1st! has made poor choicesjramosthe1st! has made poor choicesjramosthe1st! has made poor choicesjramosthe1st! has made poor choicesjramosthe1st! has made poor choices
on an engine with that many miles i'd highly advise against any sort of thinning and synthetic oils as well as many additives.
with that many miles your engine could develop leaks and begin to burn oil.
jramosthe1st! is offline   Reply With Quote
Old 07-28-2007, 06:57 PM   #6
spinitsidewayz
spinitsidewayz is making a name for him/her selfspinitsidewayz is making a name for him/her self
check your oil level... probably low. that, or your oil is really thinned out or you have a fram oil filter....
could try running a 'thicker' oil.
www.bobistheoilguy.com
Love:
89 S13 Fastback: Super stock KA24E Daily!
Hate:
89 S13 Coupe: SR20 Under the knife.
87 FC: Half Bridge Turbo Monster.
spinitsidewayz is offline   Reply With Quote
Old 07-28-2007, 06:57 PM   #7
kandyflip445
kandyflip445's Avatar
Use a good oil and filter and do some premature changes. Like 1500 miles. Auto RX seemed to do the same thing that running Redline in my car does. But it says to change out after 1500 miles. Making me think what's doing the cleaning is the filter being changed so soon. Not really the Auto-Rx.
My 240 vBgarage
Old 07-29-2007, 11:00 AM   #8
burgy240
burgy240's Avatar
burgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to allburgy240 is a name known to all
Send a message via AIM to burgy240 Send a message via Yahoo to burgy240
are you sure its the lifters sticking or is the infamous plastic ticking sound from the gaurds in the KA??
burgy240 is offline   Reply With Quote
Old 07-29-2007, 11:13 AM   #9
Phlip
Yes, I look like that
Phlip's Avatar
He said he had a KA24e, that "infamous" issue is a DE problem...
To the original poster; I don't suggest throwing a bunch of snake oils at your engine as if one will magically fix some unseen problem, I suggest proper maintenance, and the use of a Nissan OEM filter, which is among the best, as well as most cost effective when you go ahead and buy several in advance.
Weirdo
And I write too!
Old 07-29-2007, 11:25 AM   #10
BustedS13
BustedS13's Avatar
i know of three ways to do what you're talking about.
1.) buy a can of that engine flush shit. it's a silver can with a pop off lid like dog food. dump it in your oil, run your car for a bit, change your oil.
2.) buy a can of seafoam. dump it in your oil, run your car for a bit, change your oil.
3.) buy a bottle of automatic tranny fluid. dump it in your oil, run your car for a bit, change your oil.
1 doesn't seem to do much. 2 and 3 seem to really do their job.
Old 07-29-2007, 11:44 AM   #11
Jung918
Jung918's Avatar
Jung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfectionJung918 is close to perfection
Some of the engine flushed has kerosene in them which are not good for the seals as mentioned above. I did heave a lot of good things about autoRx from www.bobistheoilguy.com forums.
Jung918 is offline   Reply With Quote
