Old 08-11-2007, 09:27 PM   #1
RevKid
RevKid's Avatar
RevKid is making a name for him/her selfRevKid is making a name for him/her self
Send a message via AIM to RevKid
where to buy an sr..but is this place legit??
lookin for an sr..this place legit??
http://osakajdmmotors.com/
thanks
revkid
RevKid is offline   Reply With Quote
Old 08-11-2007, 09:35 PM   #2
SexPanda
SexPanda's Avatar
SexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfectionSexPanda is close to perfection
Send a message via AIM to SexPanda Send a message via MSN to SexPanda
thanks
revkid
SEARCH SEARCH SEARCH! there is a topic covering this exact thing. And Osaka motors sucks from what ive read... on the topic... i found while searching.
SexPanda is offline   Reply With Quote
Old 08-11-2007, 09:37 PM   #3
boogerlovers
boogerlovers's Avatar
boogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond reputeboogerlovers has a reputation beyond repute
hey man i got my sr swapped by marco vargas at sr20 store. he has a website you should look into it. www.sr20store.com
boogerlovers is offline   Reply With Quote
Old 08-11-2007, 09:42 PM   #4
Flybert
Buying from Osaka is just as bad as buying from RNDfactory. Just don't do it.
Like boogerlovers said, look into getting your motor from Marco at SR20store. He's a real standup guy and backs up his product 100%. G-Dimension is good in my book as well.
Old 08-11-2007, 10:19 PM   #5
GSXRJJordan
GSXRJJordan's Avatar
^^^ Damn Fly you're gonna bash R&D like that? Even though Jack's not there any more, Ed still hooks it up and the mechanics aren't bad. I'd get a swap done at R&D if I needed to.
G Dimensions/Marco/Garage Boso are all good shops too ~
Old 08-11-2007, 10:39 PM   #6
RevKid
RevKid's Avatar
ive seen alot of websites but dont kno if they are legit..i just wanna kno the legit places..
Old 08-11-2007, 11:10 PM   #7
Flybert
Ed from RNDFactory "hooked it up" with a motor that looked like this on the inside. It came with a bad ECU, hacked up wiring harness, the cam timing was off, the motor had rod knock, and the sludge killed the turbo on start up. We did 4 oil changes on the motor and it was still sludged up to all hell. All he wanted to "hook us up" with is some new bearings to help with the rebuild.
New bearing don't give us the turbo back.
New bearings don't replace the grinded up crank that needs to be replaced. New bearings don't replace the rocker arms and cams that were grinded up. New bearings don't pay for the machine shop to rebuild the head and block. New bearings don't give me my weekends back troubleshooting the stupid "motorset" all to find out it has rod knock and he won't replace it.
New bearings don't do shit and Ed is kidding himself if he thinks that makes up for the way he treated us.
Ed blamed it on us for taking 4 months to get the car up and running. When you have that many things wrong with a motor and can only work on it on the weekends, how do you expect to get it running right in a months time when you have to troubleshoot every single thing that came with the motor.
He knew there was sludge in the motor at the very beginning after I had Jack talk to ed about it to find out what we should do. He knew it had a bad ECU because he replaced it. He denies the fact that the mechanical timing was off and said we installed the CAS wrong. He made it out like I was lying to him that I had to fix the mechanical timing. I know how to stab a CAS and I know how to time a motor. I had to fix the mechanical timing to get it running right because the stupid chain was off. He then said, sometimes we have to set the timing to 30 degrees to get them to run right like as if he knows all these special tricks of the trade. I feel bad for all the cars they set up to 30 degrees at their shop. Say good bye to your pistons and piston rings. I prefer OEM 15 degrees all day long, all day strong, especially with cali piss gas.
I am not knocking anyone that works at RND. My only beef is with Ed since he's the one in charge and he's the one that made the decision not to replace the block.
Old 08-11-2007, 11:20 PM   #8
lazierhobo
lazierhobo is on the path to ruinlazierhobo is on the path to ruin
osaka is trash man, avoid them. buddy ordered an sr20 there came with a blow turbo. another guy got a 13Bturbo, had blown seals all over the place, needed a full rebuild and new rotors. not a good place to buy from.
lazierhobo is offline   Reply With Quote
Old 08-12-2007, 12:04 AM   #9
boogerlovers
your askin for legit places and we are tellin you which ones are kool and which ones to avoid, G dimensions and SR20 Store are great places to get your swap...
Old 08-12-2007, 12:13 AM   #10
GSXRJJordan
Damn Flybert that's a horror story for sure. I've always seen Ed make things right, but I guess I stand corrected for now :/
To the OP, you got your legit spots. Call em up, set up a time, and swipe that CC.
Old 08-12-2007, 01:10 AM   #11
StaticX27
StaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond reputeStaticX27 has a reputation beyond repute
I totally recommend Garage Boso for buying the motor and getting the swap.
StaticX27 is offline   Reply With Quote
Old 08-12-2007, 01:24 AM   #12
slidingsky
slidingsky's Avatar
slidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfectionslidingsky is close to perfection
JHOT Imports FTW
slidingsky is offline   Reply With Quote
Old 08-12-2007, 01:45 AM   #13
nissantfsx
nissantfsx's Avatar
nissantfsx is an unknown quantity at this point
Send a message via AIM to nissantfsx
AcuTech from San Francisco
nissantfsx is offline   Reply With Quote
Old 08-12-2007, 01:48 AM   #14
A Spec Products
A Spec Products's Avatar
If I owned a SR importer shop
I'd just rebuild all motors regardless and sell like that
OEM rebuild, nothing fancy, just back to OEM spec
You could charge more as a business, and as a customer you'd be 100% on the motor rather than guessing what's gonna happen
Not very cost effective and you won't sell the most motors, but I think less headache in the long run
And you could stand behind your product, rather than selling truly USED goods
Kinda like used wheels shops polishing all their wheels before putting for sale
And the majority of shops that people will list in this thread are gonna just be resellers, not the actual importers of the motors
A SPEC PRODUCTS CORP
Old 08-12-2007, 08:39 PM   #15
mayco_86
mayco_86's Avatar
mayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfectionmayco_86 is close to perfection
I have never heard of Garage Boso. Were is this place located.
mayco_86 is offline   Reply With Quote
Old 08-12-2007, 08:48 PM   #16
burnsauto
burnsauto's Avatar
+ for sr20store...had a friend get an engine there, pretty clean.
got mine from HT awhile back. SUPER clean. jeff is usually pretty good if a part is missing/blown/broken
Old 08-12-2007, 08:51 PM   #17
WIKID S4TEEN
WIKID S4TEEN's Avatar
WIKID S4TEEN is making a name for him/her selfWIKID S4TEEN is making a name for him/her self
Plus 1 for Marco @ www.sr20store.com
Rock wha U jock and don't talk if U ain't got!!
WIKID S4TEEN is offline   Reply With Quote
Old 08-13-2007, 02:50 AM   #18
Dousan_PG
Dousan_PG's Avatar
marco or gdimension
thats it
Aaron
Pink GodziRa
Old 08-13-2007, 03:35 AM   #19
wangan_cruiser
kouki man
wangan_cruiser's Avatar
Trader Rating: (36)
Feedback Score: 36 reviews
where is this located at? got a #?
Old 08-17-2007, 02:25 AM   #20
s13gold
s13gold's Avatar
Trader Rating: (79)
s13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfections13gold is close to perfection
Feedback Score: 79 reviews
Gardena CA. its on main and gardena blvd. same plaza spot as dori2garage and srmotorcars.
s13gold is offline   Reply With Quote
Old 08-17-2007, 02:51 AM   #21
yaba94070
yaba94070 is an unknown quantity at this point
Send a message via Yahoo to yaba94070
I totally back this dude
He knew there was sludge in the motor after I had talked to Jack about it to find out what we should do. He knew it had a bad ECU because he replaced it. He denies the fact that the mechanical timing was off and said we installed the CAS wrong. He made it out like I was lying to him that I had to fix the mechanical timing. I know how to stab a CAS and I know how to time a motor. I had to fix the mechanical timing to get it running right because the stupid chain was off. He then said, sometimes we have to set the timing to 30 degrees to get them to run right like as if he knows all these special tricks of the trade. I feel bad for all the cars they set up to 30 degrees at their shop. Say good bye to your pistons and piston rings. I prefer OEM 15 degrees all day long, all day strong, especially with cali piss gas.
If they would of given me something like that i would of droped that shit back off and said F u guys and got my money back... weather i would of had a motor or not lol
i haven;t herd to bany good things from there to... have 2 blocks from venious but i dno anyhting about them....
one 2 many 240's and I just keep coming back for more
yaba94070 is offline   Reply With Quote
Old 08-17-2007, 02:57 AM   #22
yaba94070
wish i would of know about them from the start
Old 08-17-2007, 07:40 AM   #23
FinalDrive
FinalDrive's Avatar
FinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud ofFinalDrive has much to be proud of
www.jhotimports.com
as i say in every "where to buy an SR thread"...
they own the salvage yard in japan, they own the shipping company, they own the stateside retail operation as well
i can vouch for the two SR motor sets that i bought from them, plus a few dozen that i've seen locally from them
FinalDrive is offline   Reply With Quote
Old 08-17-2007, 08:42 AM   #24
Unholy S14
Unholy S14's Avatar
Trader Rating: (-3)
Unholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfectionUnholy S14 is close to perfection
Feedback Score: -3 reviews
Send a message via AIM to Unholy S14
jhot or jarco for me
parting out dark blue 89 hatch, PM me if you need anything.
Unholy S14 is offline   Reply With Quote
Old 08-17-2007, 10:05 AM   #25
vvtisupra
vvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond reputevvtisupra has a reputation beyond repute
Send a message via AIM to vvtisupra
I got my engine from Dori 2 Garage. Decent price and offers a 30 day start up warantee and my s13 blacktop was clean as a whistle.
http://www.fuckdrama.com/
vvtisupra is offline   Reply With Quote
Old 08-19-2007, 01:42 AM   #26
uhtjoogoorih
uhtjoogoorih is an unknown quantity at this point
i had marco do my swap beginning of the year and i'd definitely recommend him. he may charge a little bit more than others, but he will give you the state of mind with brand new belts, refreshed engine and everything you need to make sure the car is reliable. if you can, go check out his shop and talk to him. and if he has extra parts lying around, he'll hook it up. he threw in a nismo racing clutch, and a 3" greddy downpipe he had lying around with the install. another thing i liked about marco was that he only works on 1 car at a time to make sure everything's perfect. so no need to worry about a shady job from him.
before going to marco, i almost had it done at R&D, but i went to their shop to talk with one of the guys, since they were pretty cheap. but the first thing the guy said to me was "we can do the swap for you, but we don't guarantee our work." after hearing that, i just walked out and called up marco to set an appointment. you should definitely stop by his shop, on Gardena Blvd and Western Ave and check it out for yourself. but make sure you give him a call as he's not in the shop at times.
uhtjoogoorih is offline   Reply With Quote
Old 08-19-2007, 10:01 AM   #27
Diabolical
Diabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymoreDiabolical is not welcome here anymore
Osaka sucks ass they send engines that knock
Diabolical is offline   Reply With Quote
Old 08-19-2007, 10:10 AM   #28
StaticX27
Also, if you wanted to pay a little bit more, check out Ernie Fixmer's place. If you buy the motor, he'll install it for around $3000. Now, before you gawk at the price, understand that Ernie basically does a half rebuild on the block for that price. I don't remember the entire list, but I know things like greddy head gasket were on the list of things you get for that price. His mentality is like what A spec said, sell an engine that isn't a "used" part, so that way he can stand by his work and never see a motor ever come back. I know he does sell engines as well, I'm just not remembering the price.
His shop is located in L.A., and I'm sorry for the half coherent post, my brain is still hurting
