Old 10-18-2007, 06:12 PM   #1
dued
dued's Avatar
dued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymoredued is not welcome here anymore
Rhino Liner, Rustoleum Interior
I've been contemplating painting my damaged interior panels a flat black using Rustoleum's oil based enamel. I though of the costs involved in replacing these with either new or used parts, and wanted something that was less expensive, good finish, and repairable if damaged again. The paint is very versatile and should stick to plastic / vinyl without any problems.
Have any of you brown interior s13 owners painted your interior panels with Rustoleum? Any s14 owners done this? Also, do any of you guys know of someone who has used Rhino Liner on their dash, consoles, etc?
Any pictures of odd or clever interior solutions are appreciated.
dued is offline   Reply With Quote
Old 10-18-2007, 07:14 PM   #2
Pank
Pank's Avatar
Pank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfectionPank is close to perfection
probably not a lot of people here, but check Pirate 4x4 or something, they do this stuff ALL the time
Pank is offline   Reply With Quote
Old 10-18-2007, 07:57 PM   #3
s13pignose
s13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of lights13pignose is a glorious beacon of light
I did my lip in rustoleum textured and painted my center garnish with the same, both are plastic, so I guess it should be ok. It's kinda rhino liner looking. Just try to get an adhesion promoter I guess and make sure the surface is real clean..I use alcohol myself.
Also this is really good at promotoing adhesion. Even though all my attempts on painting my interior never went the way I wanted (messed up on sanding texture away), I always had good adhesion thanks to this....
http://www.perfectfit.com/product.as...15979&l2=15342
Basically way I was told to use it is spray the part with that first, wait like 4 secs then do a light coat of paint. Then regular coats after the first about 30secs later. I found that stuff at an automotive paint shop
s13pignose is offline   Reply With Quote
Old 10-18-2007, 08:10 PM   #4
image12's Avatar
image12 is an unknown quantity at this point
rhino lining a gutted jeep interior looks good and durable but rhino lining is heavy and not cheap.
image12 is offline   Reply With Quote
Old 10-18-2007, 08:29 PM   #5
dued
dued's Avatar
^Keeping the original texture and look is one of my main goals also. I was hoping to lightly sand the hard plastic console, and then go over it with enamel. I think that the original texture might be replaced with the Rustoleum's bumpy texture.
I really want to paint all of the parts at the same time, including door panels and dash. The reason why I'm not leaning towards vinyl die is because I would like to fix scratches and a crack in my dash before painting, probably with bondo or wood glue.
I also would like to keep away from spray paint due to it's thin layering. I would like to use Rustoleum oil based because of its thickness, durability, and easy repairs.
Old 10-18-2007, 09:01 PM   #6
Bushido
Bushido's Avatar
broadfield knows whats up when it comes to interior paint. his stuff looks 100% oem.
Old 10-18-2007, 09:35 PM   #7
s13pignose
I 2nd that...seen his work in his interior thread...very oem looking.
Old 10-18-2007, 09:56 PM   #8
zoomswimmer
zoomswimmer is making his/her stupidity well-knownzoomswimmer is making his/her stupidity well-knownzoomswimmer is making his/her stupidity well-known
I've heard if you rhino line the interior it makes the car alittle more rigid, but also heavier.
zoomswimmer is offline   Reply With Quote
Old 10-18-2007, 10:02 PM   #9
ripnbst
ripnbst's Avatar
ripnbst is making a name for him/her selfripnbst is making a name for him/her selfripnbst is making a name for him/her self
Thumbs down
Are you for reals playa? Adding Rhino lining to stiffen the car??? LMMFAO at that idea. Buy sway bars/strut bars/coilovers. I am seriously in awe at that comment, or even the thought.
In the market for a Clean Coupe
ripnbst is offline   Reply With Quote
Old 10-18-2007, 10:20 PM   #10
dued
dued's Avatar
http://www.fordmuscle.com/archives/2006/02/ProjectMXInterior/index.php
^Found a link of a company that used SEM's products to restore some vinyl interior pieces. Check out the 3 page restoration, good stuff.
That process looks good for people trying to do a color change (brown and blue s13 and s14 interiors), but I'm looking for something a little bit thicker and something that will go on over a fiberglass or bondo repair.
I'm hoping to find a satin or flat black textured enamel paint.
Old 10-18-2007, 10:33 PM   #11
B Love
B Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really niceB Love is just really nice
I wouldnt use rhino liner. Maybe in the trunk or something
B Love is offline   Reply With Quote
Old 10-18-2007, 11:34 PM   #12
dued
dued's Avatar
Alright dueds, after some research I think I've come up with a method:
no priming, easy touchup, uniform, new looking interior panels. The roller up there is called a stipple roller, it produces a textured surface similar to the factory texture on the console and dash. For the door panels, a smooth foam roller should match the original finish. If I get a chance to experiment with this method, I will be sure to post pics if possible.
For anyone out there who has a spare interior piece to experiment on, try this out and post up some results.
Old 10-18-2007, 11:37 PM   #13
projectRDM
projectRDM's Avatar
I've used SEM products for years on all my interior parts I rebuild. They have a texture coat that mimics the OE finish if sprayed properly, that backed with primer and landau black dye is a near perfect OE match.
FORMERLY R240NA
Old 10-19-2007, 06:29 PM   #14
dued
dued's Avatar
I would like to paint my glove box (discoloration and scuffs), but I'm not sure about how to remove it. I sat in my car to check it out, and the FSM states that there are 2 screws behind it.
How do I take the glove box out? Also, what about those white hinges that it's on?
Old 10-19-2007, 07:21 PM   #15
Full-Lock
Full-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfectionFull-Lock is close to perfection
Send a message via AIM to Full-Lock
me and a buddy used hurculiner on the interior of his car. it worked awesome..took about 3 coats to look right. the biggest pain in the ass was masking stuff off and cleaning the actual sound deadening shit. that took a good 4-5 hours. applying it was so big deal. its been done for about a month now and it still holding up strong.
Full-Lock is offline   Reply With Quote
Old 10-19-2007, 07:31 PM   #16
Bushido
Bushido's Avatar
everyone says that truck bedliner is so heavy.
how heavy are we talking here?
Old 10-19-2007, 07:42 PM   #17
Full-Lock
i dont understand when people say its ''heavy''
it can only be as heavy as the can it comes in which is like 10-15lbs?
Old 10-19-2007, 07:44 PM   #18
Bushido
Bushido's Avatar
exactly.
It can't be that heavy.. It's probably lighter than the stock sound deadening tar, which i think weighs about 45lbs.
i found this stuff:
http://www.nonslipcoating.com/truck-bed-liners.htm
sounds interesting, considering you can brush and roll it on.
it's made of recycled tires and it comes in different colors.
one gallon covers an entire truck bed.
anyone have experience with this stuff?
Old 10-19-2007, 09:16 PM   #19
dued
dued's Avatar
Anyone know how to remove the glove box in an s14?
edit: I found the two screws below the glovebox. For anyone wondering, it's the two screws attached to the white hinges.
And thank you Sir for the reply.
Old 10-19-2007, 09:26 PM   #20
Sir
Sir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud ofSir has much to be proud of
philips screws all around.
Originally Posted by drift freaq View Post
I suggest you shut the fuck up.
Sir is offline   Reply With Quote
Old 10-19-2007, 11:53 PM   #21
projectRDM
projectRDM's Avatar
If you had trouble with that, maybe you should stick to lesser hobbies. You know, huffing glue and shit.
FORMERLY R240NA
Old 10-20-2007, 08:40 AM   #22
upSLIDEdown
upSLIDEdown's Avatar
Location: VA.. And for those that keep PMing me asking what kit I have, it's Origin Stream.
upSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfectionupSLIDEdown is close to perfection
Did my Zuki in Herculiner. 3 coats. Worked great. Eventually faded to a flat finish but that's being out in the sun and weather year round. After about 3 years, it's getting a little thin on the front end, I'm gonna throw another 2 or 3 coats on it sometime soon.
upSLIDEdown is offline   Reply With Quote
Old 10-21-2007, 02:05 AM   #23
dued
dued's Avatar
Update - Got the first coat of paint on after filling the gouges with spot putty. Went with Rustoleum satin black. I thought the paint would be flatter, but it has a bit too much gloss. Going to see if I can return it for a flat black. I'll update with more information once this is done.
Old 10-21-2007, 03:34 AM   #24
*Kung Fu Grip*
*Kung Fu Grip*'s Avatar
*Kung Fu Grip* is not welcome here anymore*Kung Fu Grip* is not welcome here anymore*Kung Fu Grip* is not welcome here anymore*Kung Fu Grip* is not welcome here anymore*Kung Fu Grip* is not welcome here anymore*Kung Fu Grip* is not welcome here anymore*Kung Fu Grip* is not welcome here anymore*Kung Fu Grip* is not welcome here anymore*Kung Fu Grip* is not welcome here anymore
Send a message via AIM to *Kung Fu Grip*
We need PICS!!! lol
*Kung Fu Grip* is offline   Reply With Quote
Old 10-21-2007, 04:51 AM   #25
ChingSR20
ChingSR20's Avatar
ChingSR20 is an unknown quantity at this point
Originally Posted by Bushido View Post
exactly.
The sound deadening in the car is way less then 45lbs its more like 15lbs.
ChingSR20 is offline   Reply With Quote
Old 10-21-2007, 05:05 AM   #26
yokotas13
yokotas13's Avatar
LOL at spot putty
yokotas13 is offline   Reply With Quote
Old 10-21-2007, 10:09 PM   #27
dued
dued's Avatar
Red face
***Final Results***
I don't own a digital camera so bear with the text! My conclusion is that Rustoleum's black paints are too glossy! Other than that, the finish came out flawed, with paint bubbles and dirt debris.
I would not recommend that Rustoleum be used on your interior panels with the roll on method. I would however, like to see some of it sprayed on, or some other sprayed on material (rhino, line x, etc.)
So, due to my lack of good results, I do not recommend this.
Old 10-21-2007, 10:10 PM   #28
B Love
I think spray would probably work best
Old 10-21-2007, 10:55 PM   #29
Tearlessj
Tearlessj's Avatar
***Final Results***
You got bubbles because the paint was not thinned enough. Dirt because you didnt clean enough. The only way to roll on the paint without bubbles is to thin it, and that means it wont be textured. I would reccomend some bumper coating for interior painting. Just go to the local auto paint store and get some. Of course, it wont be textured.
Nagasaki Motors
Friends help you move. Real friends help you move bodies.
Tearlessj is offline   Reply With Quote
Old 10-22-2007, 11:01 AM   #30
Bushido
Bushido's Avatar
well, since you already screwed up the dash by paining it, why not just get a quart of some bed liner coating and try it out?
and take some pics.
