Old 01-18-2008, 12:05 AM   #1
tec_neak
tec_neak is making a name for him/her selftec_neak is making a name for him/her self
fuel pump question
I didnt search or anything. but im installing a walbro pump and i cut the wires to attach the new harness to it, I just wanna know is it safe with just crimps and electrical tape? am i going to blow up?
tec_neak is offline   Reply With Quote
Old 01-18-2008, 12:13 AM   #2
brndck
brndck's Avatar
Trader Rating: (130)
Feedback Score: 130 reviews
yes. you will 'splode. no j/k. the kit should come with new electrical crimps. if it didn't, then go to your local auto parts store and buy some (get wurth brand if you can. they're more $ but by far the best ones i've ever used)
Old 01-18-2008, 12:13 AM   #3
Gavster
Gavster's Avatar
Gavster is close to perfectionGavster is close to perfectionGavster is close to perfectionGavster is close to perfectionGavster is close to perfectionGavster is close to perfectionGavster is close to perfectionGavster is close to perfectionGavster is close to perfectionGavster is close to perfectionGavster is close to perfection
Send a message via AIM to Gavster
Soldering is usually best, but youll be fine...crimp up, tape up, and go on with it!
I <3 burnt metal smell....
Gavster is offline   Reply With Quote
Old 01-18-2008, 12:26 AM   #4
tec_neak
awesome thanks!!
Old 01-18-2008, 01:09 AM   #5
fliprayzin240sx
Man w/ CTSV & a Car Seat
fliprayzin240sx's Avatar
If you soder, just make sure you do it NOT in the car near the opened gas tank...
CLICK HERE!!!
Old 01-18-2008, 09:32 PM   #6
undesiredshoe
undesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of lightundesiredshoe is a glorious beacon of light
Send a message via AIM to undesiredshoe
Open wires in the fuel tanks arent going to spark and cause horrendous things to happen, its just when those two wires touch, thats when sparks happen.
undesiredshoe is offline   Reply With Quote
Old 01-18-2008, 09:35 PM   #7
LongGrain
LongGrain's Avatar
walbro does not recommend soldering the wires. i would listen to them....
LongGrain is offline   Reply With Quote
Old 01-19-2008, 09:26 AM   #8
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
Ya, they say that for safety reasons. It's the best connection you'll get though(twisting/soldering)... And I wouldn't recommend elec. tape in your gas tank. Haha.
JVD is offline   Reply With Quote
Old 01-19-2008, 10:39 AM   #9
rokmplutonium
rokmplutonium's Avatar
rokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the roughrokmplutonium is a jewel in the rough
Theres no point in using electrical tape, it'll just fall off.
rokmplutonium is offline   Reply With Quote
Old 01-19-2008, 10:41 AM   #10
2bad240
2bad240's Avatar
2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about2bad240 has a spectacular aura about
dont use tape the glue comes off and clogs up your filter, at least mine did.
you, its whats for dinner.
2bad240 is offline   Reply With Quote
Old 01-19-2008, 10:46 AM   #11
CoasTek240
CoasTek240's Avatar
CoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud ofCoasTek240 has much to be proud of
Send a message via AIM to CoasTek240
twist &crimp ftw...no tape
CoasTek240 is offline   Reply With Quote
Old 01-19-2008, 11:28 AM   #12
deesz
deesz is making a name for him/her selfdeesz is making a name for him/her self
i pprobably wouldnt use electrical tape.
reason being over time it can get all gunky and the adheasive will wear out and it will fall off and float around in your gas tank....
the tape will be submurged in gas for long periouds of time.
why not go to radio shack and pick up a solder gun for $15 and do it the right way????
deesz is offline   Reply With Quote
Old 01-19-2008, 04:43 PM   #13
projectRDM
projectRDM's Avatar
You still have to tape up the solder joint, so that's pointless. What you've all failed to mention is heatshrink, however it too will deteriorate in the tank over time. An insulated crimp connector is fine, there's no strain on the wiring or tension of any kind.
You can also do one step better, depin the OE connector, crimp new pins on the Walbro pump's wiring, and repin the connector, making it completely OE and eliminating any other connection point.
FORMERLY R240NA
