Old 03-10-2008, 10:21 PM   #1
S14DB
AFC #1
S14DB's Avatar
LCD VS. Projection TV
My TV took a shit this weekend so I went shopping for a new one. I picked these two. I dunno what would be better in the long run. Had my last one for 7 years.
http://www.bestbuy.com/site/olspage....=1184369372565
http://www.circuitcity.com/ccd/produ....do?oid=190632
I thought the LCD would be smaller but:
-LCD is 51" wide and the Projection is 54" wide
-LCD 91lbs, projection 94lbs
-With the base the LCD is 18" deep the Projection is 16". If I get the wall mount the LCD is 7" off the wall. But that's $300.
People say that LCD is better than Projection but $1000 is a big diff.
I will not consider plasma. Don't bother.
Old 03-10-2008, 10:27 PM   #2
BustedS13
BustedS13's Avatar
looks like the projection has 120hz refresh, which, if you've seen normal and 120 side-by-side, makes a HUGE difference. i'd buy the projection on that alone. 120hz makes a normal television look like it's stop motion animation. everything looks like rudolph.
my next tv is going to be a DLP. much more bang for the buck. fuck hanging your shit on a wall.
Old 03-10-2008, 10:33 PM   #3
kandyflip445
kandyflip445's Avatar
Yeah....have fun with your rainbow effect on the DLP....lol (only some people can see it though, and it sucks that I'm one of them ><)
120hz sucks. It does this weird 'halo' crap around the fast moving objects. Looks too glitchy to me.
Too bad you won't consider plasma AJ. It's much better than those. (unless you have a shit ton of windows lol)
My 240 vBgarage
Old 03-10-2008, 10:34 PM   #4
eastcoastS14
eastcoastS14's Avatar
for that price id recommend doin what my dad did and get a pioneer plasma, seriously sick picture better than any other TV ive seen for the money
eastcoastS14 is offline   Reply With Quote
Old 03-10-2008, 10:39 PM   #5
Mi Beardo es Loco
Mi Beardo es Loco's Avatar
Location: A place where boob jobs ruined the best thing about being a fat chick.
Mi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfectionMi Beardo es Loco is close to perfection
You have to look at the contrast. I have a 45" lcd with 5000:1 contrast, which kinda sucks for watching regular tv but hd rocks! the first option is 20000:1 which is AWSOME because the highest they go up to now is 25000:1. I would say go LCD but there's honestly nothing wrong with projection because I have a 65" in my living room that picks up 1080p that is pretty damn great!
Mi Beardo es Loco is offline   Reply With Quote
Old 03-10-2008, 10:44 PM   #6
CKAMC
CKAMC's Avatar
CKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfectionCKAMC is close to perfection
plasma has been confirmed dead as of this month BTW
Not a huge fan of the A3k or the w3k line up...
I would say Sony's XBR4, and just disable the 120hz... that tech is just not there yet in my opinion... its a hit and miss depending on what your watching.
if you want the BEST color and gray/black scale for a LCD tv... I would go for a Samsung's 81F or even the 71F... 81F has the LED back lighting, but extremely expensive since its one of the first in the market that has this. 71F is the same as the 81F minus the LED back lighting.
These models I speak of you probably do not see at Best buy or circuit city... find like an ultimate electronics or some other high end electronics store... they will most likely have one for you to do a comparison.
DLP/Rear projection.. idk if you have an entertainment cabinet that you want to keep then I can see why you would look into one.
Side Note:
If you want cheap, thin thin (like an inch), 1080p, go with the Sharp D64's. If you read some of the "expert" reviews they may complain of uneven lines aka banding... but most of the recent ones out *aka new revision* most people have not seen any of this issue. 2500 for a 52" sounds like a pretty cheap price for one... even the 46" model one (considered the bare minimum size to be able to enjoy 1080p) can be found for sale as cheap as 1700! (@newegg)
Compared to some of the others for sale by sony and samsung from around 3k and beyond... fairly respectable price....
especially when sony has worked out an agreement to use sharp's manufacturing facility to help with their own production....(why? sharp has build at the moment the worlds largest LCD manufacturing plant)
CKAMC is offline   Reply With Quote
Old 03-10-2008, 10:44 PM   #7
kandyflip445
Do you even know that there isn't a standardized way of measuring contrast ratio? All these 'dynamic' contrast ratios aren't even close to being right. It's all about the advertising. And it's not just the LCD crowd doing it anymore. The new Panasonic plasmas claim a 1,000,000:1 contrast ratio.
Contrast ratio, response time, refresh rate, and a bunch of other stuff is just marketing BS.
My 240 vBgarage
Old 03-10-2008, 10:47 PM   #8
CKAMC
CKAMC's Avatar
Make sure your looking at the constant contrast ratio, dynamic contrast may look pretty on paper but there is a reason why its called dynamic.
Old 03-10-2008, 10:47 PM   #9
kandyflip445
Side Note:
Plasma is dead, my ass.
The sales of plasma has only grown. And the technology places it as a better display than an LCD overall. The only main drawback is the reflective screen. They have the capability to produce far more shades of colors than an LCD and they don't have problems with ghosting and blur.
My 240 vBgarage
Old 03-10-2008, 10:52 PM   #10
CKAMC
CKAMC's Avatar
ROLF you really do not understand any of this stuff do you?
refresh rates are messed up in the television world, when used on computers ohh you love having a larger hz, easier on the eyes.
response time used to be an issue when LCD's first came out, but now that is no longer an issue since most of them are at near perfect.
if you say contrast ratio's are pure bs.... then how come that pioneer plasma you over has such a larger constant range than many LCD tv's?
yeah, DLP's hurt people eye's.
when I said plasma was dead, I ment it, pioneer just stated they are looking to reduce their production of plasma's and start to focus more on their LCD production line up.
Old 03-10-2008, 10:52 PM   #11
Mi Beardo es Loco
wow. I believe what I read I guess. I went to Fry's and the salesman was explaining it to me but didn't get really technical. He just said that the higher the contrast the better the look of regular television that's not HD. He said anyone could make a TV that looks great on HD but a ton of tv's can't hang when it comes to regular non hd television. Mine looks kinda crappy in my room and it's like a year old.
Old 03-10-2008, 10:56 PM   #12
CKAMC
CKAMC's Avatar
Ghosting is no longer mentioned with many flat screen's anymore... and reflective screen? close the blinds.
My only beef with plasma is why is it the best ones have problems with color scale being a bit off (with adjustment it can be fixed)
1365 x 768... come on there is more beyond 720P
Old 03-10-2008, 10:57 PM   #13
BustedS13
BustedS13's Avatar
...and you just lost all credibility in this subject
Old 03-10-2008, 10:57 PM   #14
CKAMC
CKAMC's Avatar
ugh
fry's electronics sales men ... not always the sharpest guys in the tool box.
Would it make someone feel better if I said plasma still has a burn in issue?
Old 03-10-2008, 11:01 PM   #15
kandyflip445
If you're using a HDTV for standard definition tv, then by nature it will be of less quality. SDTV comes in at 480i which is 480 lines of pixels measured vertically. The 'i' means it's interlaced, so at any given frame, only the odd or even lines are being refreshed. This leads to image artifacting or like when a baseball moves and you percieve something like a ghosting image, which is there because the last set of lines refreshed a frame earlier and don't match up.
480p is what Progressive scan DVD's are played in. They scan the entire image every frame and don't suffer from the effects of interlaced images.
So then you get 1080i, 720p, and 1080p.
HDTV's have a 'native' resolution. Meaning, if you buy a TV that is a 720p set, then you will always be watching a 720p picture. The TV will take whatever signal is coming in and run it through a scaler if it's not the correct amount of lines, and a de-interlacer for interlaced signals. The reason you would want something like a upscalling dvd player is because the scalers in the players are usually of better quality than the ones found in TV's.
When the signal is of a lower resolution and it goes through a scaler it 'adds' extra lines of video. Basically it breaks down the image and fills in the gaps.
So then with most any HDTV you're going to get a fuzzy picture. It's like putting a magnifying glass over your SDTV.
My 240 vBgarage
Old 03-10-2008, 11:02 PM   #16
kandyflip445
Bull fucking shit.
If everything was perfect and people didn't skew their numbers then they would be great numbers to go by. But the fact is that advertising has ran with it and the general public doesn't know any better.
My 240 vBgarage
Old 03-10-2008, 11:03 PM   #17
S14DB
AFC #1
S14DB's Avatar
Naw, look at your stocklists. Plasma is being discontinued faster than Projection.
XBR4 is another 1k. http://www.bestbuy.com/site/olspage....=1184369373431
Old 03-10-2008, 11:08 PM   #18
kandyflip445
There is definately more beyond 720p and even 1080p. But it really depends on how far you are from the TV and how big the TV is. That, and if your source isn't putting out a 1080p signal anyways then you aren't getting the full benefit.
There aren't many TV's that come with the correct settings out of the box. Like Sony LCD's usualy have a white that has more blue in it.
Calibrations are great for any TV but most people don't justify the cost for them.
Ghosting is mentioned on tv's. The Samsung 81 series has reviews about it.
A lot of people get set on one type of television and won't want to even consider another type. It really depends on your situation. Some people can't shut blinds because they have huge skylights or big window that can't be covered easily.
My 240 vBgarage
Old 03-10-2008, 11:09 PM   #19
kandyflip445
Heh, I've looked at my stock list. And I can see the SKU's that are coming out and when. They are far from dead.
My 240 vBgarage
Old 03-10-2008, 11:20 PM   #20
S14DB
AFC #1
S14DB's Avatar
Back on topic:
OR
Old 03-10-2008, 11:20 PM   #21
CKAMC
CKAMC's Avatar
Yeah he needs to, since pioneer made the announcement last week.
like I said, Sharp is extremely reasonable for the price.
too bad newegg does not carry sony's I bet they would be able to bet bestbuy's crazy price.
pricegrabber has some nice listings for the XBR4
http://electronics.pricegrabber.com/...duct/sv=title/
I forgot they made the XBR5, maybe because they are so few of that model out...
and crutchfield is always over priced....
Old 03-10-2008, 11:24 PM   #22
kandyflip445
I know about the Pioneer deal. They aren't getting out of the plasma business. They are outsourcing their panels to Matsushita (Panasonic). It still remains to be seen if this means they will be able to produce the panels to Pioneers spec. But the chances are good since Panasonic is already building a factory scheduled to be open in 09'. The Pioneers coming out this summer are still full Pioneers and will not be effected by the outsourcing.
XBR4 really isn't worth the price IMO. I would get the w3000. Sharps are good for the price too.
My 240 vBgarage
Old 03-10-2008, 11:26 PM   #23
S14DB
AFC #1
S14DB's Avatar
http://www.bestbuy.com/site/olspage....=1188560191488
$3800 I dunno if I want to spend that online at some random store.
Old 03-10-2008, 11:27 PM   #24
CKAMC
CKAMC's Avatar
if you have the space, the rear projection... probably one of the best in that market for an EXTREMELY reasonable price.
no space? I guess the W3k will do.
Old 03-10-2008, 11:28 PM   #25
CKAMC
CKAMC's Avatar
agree'd, think most of them are successful mom and pop shops...
Old 03-10-2008, 11:33 PM   #26
kandyflip445
I agree on that one.
The a3k will be dimmer the further off from the center you view while the LCD won't be. But, both at their best, I like the a3000 more. It's immaculate with something like a PS3 plugged in.
My 240 vBgarage
Old 03-11-2008, 01:17 AM   #27
kingkilburn
Philosopher King
kingkilburn's Avatar
kingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfectionkingkilburn is close to perfection
I didn't read through the thread but I've got a 64 inch DLP tv(Mitsubishi). It was almost half the price of a plasma the same size and about 1500 less than the LCD. The projected life span of the unit is longer(don't remember the exact number) than an LCD or plasma. It isn't as heavy as an LCD and has smaller outside dimensions. It doesn't have the darkest blacks but that is ok for my use. If I had the money to spend again I would make the same purchase for sure.
G O L D E N B E A R R E P U B L I C
kingkilburn is offline   Reply With Quote
Old 03-11-2008, 05:45 AM   #28
wayneside
wayneside is on the path to ruinwayneside is on the path to ruin
get the projection tv...
wayneside is offline   Reply With Quote
Old 03-12-2008, 09:56 AM   #29
S14DB
AFC #1
S14DB's Avatar
Looks like the consensus is Projection. Probably go pick it up tomorrow.
Old 03-12-2008, 01:39 PM   #30
BOROSUN
BOROSUN's Avatar
BOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfectionBOROSUN is close to perfection
the only projectors i like are the ht 1080p projectors. baller
BOROSUN is offline   Reply With Quote
