Old 07-01-2008, 10:01 PM   #1
KPNITRL
KPNITRL's Avatar
KPNITRL is making a name for him/her selfKPNITRL is making a name for him/her selfKPNITRL is making a name for him/her self
RB25DET lower harness has extra plugs and wires?
Hi, thanks for clicking.
So I'm in the final stages of wiring my RB25 into my S13 and I am totally at a loss with some extra plugs. I tried posting this on another forum but surprisingly didn't have much help. I hope some of you RB pros has some insight.
Im using a KA harness and the plugs off of the RB25
On to the pics.
So at the back of the harness there is the RB VSS plug that I need to transfer to the KA harness right? Well I dont know where or what to do with the other two plugs that are at the end of the RB harness (pic below)
Because at the end of the KA harness this is it
Then on the alternator side of the RB harness there is an extra brown plug that plugs into the AC I believe, but none on the KA. I plan on running AC so I figure I would need this plugged in, no?
What the crap are these for? Again off of the RB harness. According to what I found, the square plug has some wires that are coming from the back of the harness. One color that stood out was a green with an orange stripe which I thought was the neutral something or other, I figure this is important as well.
Again, thank you for any help. I tried looking online for a while and the best I could find was from RaceBread (awesome site) But didnt really answer some of my questions.
KPNITRL is offline   Reply With Quote
Old 07-01-2008, 10:07 PM   #2
sillyvia13
sillyvia13's Avatar
sillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfectionsillyvia13 is close to perfection
you should find a fsm and ecu pin out...
will help you best...
you can test wires find out where in ecu they are then you can find # in pinout and bam.
I dropped mine in and used like 4 wires...lol...its just a race toilet. but its runs.
sillyvia13 is offline   Reply With Quote
Old 07-01-2008, 10:17 PM   #3
KPNITRL
KPNITRL's Avatar
Thanks for the response. I actually have the R33 fsm and a 240sx fsm but no real luck with the lower harness. All I can find is a diagram of where the lower harness goes on the car. But no info on which is what.
lol, "a race toilet" thanks for the laugh.
Old 07-02-2008, 08:05 AM   #4
Z U L8R
Z U L8R's Avatar
Z U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond reputeZ U L8R has a reputation beyond repute
use your car's lower harness not the rb lower harness. cut out the knock sensors and idle control plugs from the rb's lower harness. for the reverse lights and all that, cut the plugs off the very end of the rb lower harness and splice them to your lower harness in the coordinating positions.
Dave
RB25 280z GT30/76R 441hp/381tq 11.9@125
Z U L8R is offline   Reply With Quote
Old 07-02-2008, 11:53 AM   #5
KPNITRL
KPNITRL's Avatar
Dave
Thanks for the reply. I am using the cars lower harness but at the end that harness there is only the VSS plug to tap into. But on the RB harness there is the VSS plug, and two other plugs which lead to a square plug at the other side of the RB harness. which I'm guessing would be the reverse lights and such
Old 07-02-2008, 07:51 PM   #6
Z U L8R
Z U L8R's Avatar
sounds like you got it under control then....what's not making sense to you?
Dave
Old 07-03-2008, 07:56 AM   #7
KPNITRL
KPNITRL's Avatar
its those two plugs on the RB harness (2nd pic). I'm wondering if I need to somehow wire it to the KA harness. But I don't even know what they are for.
Old 07-03-2008, 03:54 PM   #8
Z U L8R
Z U L8R's Avatar
as far as the lower harness and the tranny sensors are concerned. you have a park neutral switch (green/orange) , the speed sensor (yellow/green), the reverse switch to kick on your reverse lights, and your 5th gear position switch.
depending on how your engine's wired in essentially the only things you need to worry about is the p/n switch, reverse lights , and speedo. even if you didn't have any of em wired up the motor will still run though.
if you want. make two columns. give each plug on your rb harness a letter, then write down what 2 wire colors they have. do the same for the ka lower harness plugs, and i'll tell you what to do.
Dave
Old 07-07-2008, 07:45 PM   #9
KPNITRL
KPNITRL's Avatar
Dave your awesome!!!
Thanks so much for the continued help.
ok this is what I got. Hopefully it helps.
On the RB side:
Here are the three end plugs:
A) yellow/purple
grey/red
B) red
green/blue
C) black
green/orange
On the end of the KA harness all there is, is the VSS plug:
1) yellow/blue
yellow/black
Which Im pretty sure that my KA "1" plugs in with my RB "A" for the VSS
Now on the other end of the 240sx lower harness I have this plug:
2)
__l---l__
l 1.....2 l
l 3.....4 l
1) yellow/blue
2) white/red
3) yellow/black
4) yellow/white
Which I had to take from a car at the junkyard since I did not have a lower harness with my car.
So the plug that is on the chassis' fuse box is actually a bit different:
Chassis plug)
__l---l__
l 1 X 2 3 l
l 4 5 6 7 l
1) green/blue
X) none
2) white/red
3) yellow/blue
4) green/white
5) green/orange
6) yellow/white
7) yellow/black
Which has more wires and makes more sense to me about the extra plugs that go on the RB tranny. So Im thinking that this is the extra plug that I would have to tap into to run the reverse, neutral, and 5th gear. Which by the way, why is there a sensor for the 5th gear?
Again, thanks for the help, hopefully my "charts" give you a better idea of what I am working with.
