Old 08-10-2008, 11:14 AM   #1
Slammed180
Slammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of lightSlammed180 is a glorious beacon of light
looking for in depth wire tuck:
Ok, I really didn't want to make a thread about this, because I know it's covered somewhere, but I fail at life hardcore and can't find it.
I'm looking at tucking my engine harness and brake lines, but haven't been able to find any good write-ups on how to do it. I'm not the most electrical inclined person you'll meet, so I wanted something with alot of detail and almost step-by-step instructions. If someone has a link, or even pics of their own adventure, I'd greatly appreciate it.
Again, sorry for making a new thread about it.
Blow me, bitches.
Slammed180 is offline
Old 08-10-2008, 11:16 AM   #2
g6civcx
g6civcx's Avatar
What do you want to do with your brake lines?
g6civcx is offline
Old 08-10-2008, 11:16 AM   #3
Slammed180
Hide them. I've seen it done in a few cars, and it really cleans the look up.
Blow me, bitches.
Old 08-10-2008, 11:42 AM   #4
onehundredoctane
onehundredoctane's Avatar
onehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfectiononehundredoctane is close to perfection
^not worth it for the work. Have you ever had to bend or flair brake line before? Wiring won't be any easier, but at least if you f up the wiring you'll still be able to stop when you press the brake pedal.
I've done both wiring and brake lines before and neither is worth it to make your engine bay look clean, if the car runs and drives that's enough for me.
onehundredoctane is offline
Old 08-10-2008, 11:47 AM   #5
ericcastro
ericcastro's Avatar
somewhere, maybe on 240sxforums.com, there was an entire write up about what wires you need and what ones you didnt.
Some dude rewired his car with the stock wires, and ended up losing 40lbs of wieght from his car.
But also stated its a pain in the rear and was more just the challenge to see if he could do it, iirc.
ericcastro is offline
Old 08-10-2008, 11:54 AM   #6
bejota180sx
bejota180sx's Avatar
bejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura aboutbejota180sx has a spectacular aura about
somepeople put the brake master and clutch master and all that on the inside of the firewall like inside the dash, the fusebox/relaybox could be relocated to the inside of the car like the back or inside glove comparment(-->lol), wire tucking goes well that i bet you can find a writeup or explanation around here somewhere...
good luck it isnt any easy to do any of this but if u want something u have to work for it...
heres a pic of a engne bay (dont know if its from somebody here i cant remember where i got it from... uploaded it to help the OP) and yeah the engine is running... the owner had said about putting everything on the inside of the firewall inside the dash if im not mistaken...
hope this help out a bit
Originally Posted by Taniguchi_Is_#1 View Post
...this is zilvia; prepare to get your feelings hurt.
bejota180sx is offline
Old 08-10-2008, 12:01 PM   #7
sbanzer123
sbanzer123's Avatar
sbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the roughsbanzer123 is a jewel in the rough
heres my tucked brake lines. i ran them down along the x-member when the motor was out.
sbanzer123 is offline
Old 08-10-2008, 12:20 PM   #8
g6civcx
g6civcx's Avatar
That writeup would not be useful to everyone because each person wants different options on the car. If you don't mind copying his setup then it's ok as a guide.
That would be I. I tried to keep all the exterior lights, the gauges, and the defrost for inspection. Everything else was removed.
I agree. It's doable, but I do not recommend it to the average person. Only do it if you have the patience, perseverance, and electronic wherewithal to do a custom harness.
g6civcx is offline
Old 08-10-2008, 12:21 PM   #9
g6civcx
g6civcx's Avatar
The easiest way is to use interior mounted master cylinders and use braided lines.
Hardlines can be used but will be harder to bend.
Is this a show car?
g6civcx is offline
Old 08-10-2008, 03:24 PM   #10
bejota180sx
ive searched a bit in my free time to get that write up ericcastro mentioned but i cant seem to find it, like stated it isnt for everyone but i guess it could help out at least a bit on what to do...
Old 08-10-2008, 03:35 PM   #11
racepar1
racepar1's Avatar
Trader Rating: (106)
Feedback Score: 106 reviews
Tucking your brake lines is potentially a VERY bad idea, especially if you actually intend to drive your car. Routing them down to the x-member, like somebody else suggested in this thread, is undeniably stupid. Running your brake lines that close to your exhaust is just asking for problems. The best solution for the brake lines is to run them through the firewall and under the dash. IMO tucking wiring and lines/hoses is not worth it. You almost always end up sacrificing function to make it look pretty, which I am personally not OK with. On top of that it is a ton of work, especially to do it right.
racepar1 is offline
Old 08-10-2008, 03:54 PM   #12
sbanzer123
sbanzer123's Avatar
ive been driving my car with the brake lines rerouted along the x member for 3 years. 0 problems.
Old 08-10-2008, 04:22 PM   #13
onehundredoctane
^how often do you change your brake fluid?
I'm not jumping on the boat to a clean engine bay, but I would like to point out that the brake mastery cylinder is directly beside your turbo in most cases (if you are turbo), which would make routing your lines an ok idea. But still too much work for a look.
Old 08-10-2008, 04:29 PM   #14
Kinzer SR13gtR
Kinzer SR13gtR's Avatar
Kinzer SR13gtR will become famous soon enoughKinzer SR13gtR will become famous soon enoughKinzer SR13gtR will become famous soon enough
Send a message via AIM to Kinzer SR13gtR
s13 here ya go buddy...
YO, whats up... I have a full write up on it.
PM me and I can email it to ya if you still want it.
It only to tuck your wires...
Dont bother with your Brake lines,
Unless you're related to Chip Foose or something! lol!
Kinzer SR13gtR is offline
Old 08-10-2008, 04:31 PM   #15
DRFT180
DRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud ofDRFT180 has much to be proud of
My setup
S14 Build
DRFT180 is offline
Old 08-10-2008, 04:34 PM   #16
JVD
JVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfectionJVD is close to perfection
PM me on DriftWest.
I'm currently working on my wiring(painless chassis harness/simplified engine harness with d-jetro) and learning a few things along the way. I should be able to help you out with some stuff.
What are you doing to the car? Is it track only?... or are you keeping everything(a/c, heat, etc.)?
Ps. I'm the douche JVD240 on DW.
JVD is offline
Old 08-10-2008, 04:57 PM   #17
Slammed180
Is this a show car?
It will be in a few shows when it's done. But I also intend on driving it. It will be my summer DD. the brake line idea was only an after thought. If it's as big a pain in the ass as everyone says it is, I don't want to do it. I already have to make my own hardlines (ABS Delete) so I thought I could try to hide them.
Visible brakes lines are very minor.
As for tucking the harness, it's a must. I have OCD or something and cannot STAND the look of visible wires, I just hate it. No matter the pain, I'm going to do that at least.
JVD & Kinzer: PM's will be sent. Thanks.
Blow me, bitches.
Old 08-10-2008, 05:23 PM   #18
slamn240
slamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the roughslamn240 is a jewel in the rough
more pictures please...
slamn240 is offline
Old 08-10-2008, 05:48 PM   #19
ms!3
Originally Posted by DRFT180 View Post
My setup
What type of lines are those?
ms!3 is offline
Old 08-10-2008, 06:03 PM   #20
racepar1
racepar1's Avatar
Your car is an s-13 right? If so I have some non-ABS front brake lines, you just need to find the rear line or make your own. Those little clips that hold the brakelines to the firewall are not available from the dealer anymore though, so making the stock lines look as clean as they should will be difficult.
racepar1 is offline
Old 08-10-2008, 06:03 PM   #21
DRFT180
BrakeQuip, custom made by a local shop to lengths specified by me.
another pic
S14 Build
DRFT180 is offline
Old 08-10-2008, 09:02 PM   #22
Slammed180
I doubt your hardlines are for a RHD 180SX. Thanks for lookout though. And I have the the little clips that hold them to the firewall.
Blow me, bitches.
Old 08-10-2008, 10:04 PM   #23
!Zar!
!Zar!'s Avatar
I'm sure if you give Flybert your first child, gf and free gas for life he would tuck your engine harness.
!Zar! is offline
Old 08-10-2008, 10:08 PM   #24
racepar1
racepar1's Avatar
Actually I DO have RHD non-ABS hardlines! I'll just PM you.
racepar1 is offline
Old 08-11-2008, 08:53 AM   #25
Slammed180
Don't plan on a kid (praying I'm shooting blanks)
GF- HA! he can have her.
Gas- Dunno about that one. How about my other girlfriend? lol
Blow me, bitches.
Old 08-11-2008, 09:27 AM   #26
BustedS13
BustedS13's Avatar
want to know a great way to hide your wires and brake lines? it's awesome, you can't see them AT ALL...
it's called a fucking hood.
i didn't know we were rolling '64 impala show cars
BustedS13 is offline
Old 08-11-2008, 12:55 PM   #27
nsn240
nsn240's Avatar
nsn240 is on a distinguished road
Send a message via AIM to nsn240
I just finished wire tucking my motor... pul harness.. strip completely... run everything inside the intake manifold and the power wires through the pass side fender to the fuse box. brake lines is a little over the top for stock pedal assembly etc
nsn240 is offline
Old 08-11-2008, 12:57 PM   #28
Brian
Brian's Avatar
Trader Rating: (54)
Feedback Score: 54 reviews
Honda-tech is the other way...
http://bhworld.wordpress.com/
Brian is offline
Old 08-11-2008, 03:04 PM   #29
g6civcx
g6civcx's Avatar
That's because electrical work is already expensive. Doing custom electrical work on top of that would be very expensive.
g6civcx is offline
Old 08-11-2008, 04:56 PM   #30
Slammed180
I've got a clear hood.
Isn't that what the cool kids do?
I never asked for your opinion, just for some direction. Keep it to yourself if you don't like the direction I'm taking my car in. After all it is MY car, not yours.
Blow me, bitches.
