Old 08-18-2008, 03:07 PM   #31
xkamikazestormx
xkamikazestormx's Avatar
xkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfectionxkamikazestormx is close to perfection
Originally Posted by Def View Post
I'm pretty sure there is a diagram in the FSM that states the front/rear of the "framerails"/crossmembers being the preferred place for putting a jackstand.
There's no way I could ever jack my front subframe, and my car isn't even that low.
if i can get a jack under my front crossmember, im pretty sure you can. just use wood
xkamikazestormx is offline   Reply With Quote
Old 08-18-2008, 03:09 PM   #32
surreybc
surreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond reputesurreybc has a reputation beyond repute
the picture in the OP's post is from the fsm. you jack the front suspension member and the differential in rear.
surreybc is offline   Reply With Quote
Old 08-18-2008, 05:00 PM   #33
C. Anderson
C. Anderson's Avatar
C. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond reputeC. Anderson has a reputation beyond repute
I use the diff for raising the rear and the lower rad support for the front. I've been doing this for 6 years on all of my s chassis and have not messed up anything.
C. Anderson is offline   Reply With Quote
Old 08-18-2008, 05:36 PM   #34
Def
So like I said, the FSM(at least the S13 KA24DE Chuki one I took these pics from) specifically says to put jackstands on the "framerails."
The page number is referenced in the 2nd pic.
No idea what other FSM pic the OP pulled that pic from, but his advice isn't applicable to S13s according to Nissan.
Here's the pic specifying using the pinchwelds on a 4/2 post lift.
Old 08-19-2008, 01:30 AM   #35
surreybc
The OP better clarify where he got that diagram. maybe it is for s14.
Old 08-19-2008, 08:03 AM   #36
C. Anderson
The original diagram posted is from a s14 fsm. You can tell by the fuel tank placement. S14's have the fuel tank just behind the rear seats and s13's have their tank under the trunk.
Old 08-25-2008, 10:38 PM   #37
CoreyS13
CoreyS13 is on the path to ruinCoreyS13 is on the path to ruinCoreyS13 is on the path to ruin
Okay, here is a picture of where i jacked it up and placed the jack stand when replacing front driver side rotor. Tell me if this is correct positioning.
CoreyS13 is offline   Reply With Quote
Old 08-25-2008, 11:10 PM   #38
xkamikazestormx
that is NOT the correct place.
Old 08-25-2008, 11:20 PM   #39
CoreyS13
Please correct that then should I be jacking farther to the front or what?
Old 08-25-2008, 11:23 PM   #40
xkamikazestormx
jack up the front from the front crossmember. the rear jack it up from the diff
Old 08-25-2008, 11:32 PM   #41
drift freaq
R.I.P. Aya, always love
drift freaq's Avatar
Trader Rating: (215)
Feedback Score: 215 reviews
Originally Posted by JRas View Post
I've decided to make this thread to attempt to educate people on the design of their cars. It's come to my attention that people don't know, that their cars DO NOT have an frame-rails. The 240sx is a unibody meaning all the structural strength is from the external skin.
to read more about this structural design I recommend reading the link below:
Monocoque - Wikipedia, the free encyclopedia
these long beam type things that come down the middle of the car are called side members as you can see from the picture. This is not a frame-rail like most assume.. these are not designed to be lifted from under any circumstance.
[/B]
I will, Are cars are not full Monocoque they are semi Monocoque and though the service manual calls the rails side members they are basically a subframe rail.
Reason is they extend back from the front of the car. Both the core support and the inner fenderwells are attached to them. The Monocoque part is the passenger area back to the rear trunk or hatch area. These actually extend farther back than the Japanese domestic market ones because of federal crash safety standards.
Unlike a Honda Civic which actually is a full Monocoque chassis. If you doubt this? Ask any local body guy worth a damn and he will explain it to you, as well.
New Video
Buy my mounts!
Old 09-12-2008, 01:53 PM   #42
CoreyS13
Okay, the KA is coming out and I wanna make sure the jackstands will be in the best possible positioning. I'm thinking if they are on the cross member I may be sort of cramped. The pinch weld on the passenger front side is somewhat messed up. Any suggestions?
Old 09-12-2008, 02:02 PM   #43
jspaeth
jspaeth's Avatar
"........well my friend said you are supposed to jack it up from under the intercooler"
Daily driven
Old 09-12-2008, 03:53 PM   #44
SlideWell
SlideWell's Avatar
SlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfectionSlideWell is close to perfection
im sure nothing i can say or show will enlighten some of you, but for those who have not seen a clip or inside of the unibody, here's a pic. if you dont know where to jack a car up, i worry about our youth.
SlideWell is offline   Reply With Quote
Old 09-12-2008, 10:12 PM   #45
ManoNegra
ManoNegra's Avatar
Trader Rating: (48)
Feedback Score: 48 reviews
^seriously
and for those those that mentioned lowered cars
just drive onto 2X6s or 2x4s to get that needed additional clearance
to get a jack under the crossmember.
I actually use those $20 plastic ramps they sell at auto stores with 2x4s in front.
works like a charm.
Old 09-12-2008, 11:05 PM   #46
surreybc
re 1991 s13
I wont be jacking from suspension(cross) member or the differential unless I want to lift both wheels. The side member works fine and I have jacking knobs for the rear. Its quite hard to get the jack under the cross member. I do have the steel ramps and use them sometimes.(maybe i have jacking knobs because of lsd or hicas.no idea)
truthfully, i didnt even realize that jack position and stand postiion would be different. anyway, lets insult people to deter them from asking questions. people should learn the hard way.
Old 06-18-2012, 02:01 PM   #47
konichiwabeezy
konichiwabeezy is an unknown quantity at this point
So for the rear, you place the jack directly under the differential??
konichiwabeezy is offline   Reply With Quote
Old 06-18-2012, 02:09 PM   #48
h2v7
h2v7 is an unknown quantity at this point
yea if you can get it under there but i assume its lowered and may need driven on something to raise it high enough to jack it up.
h2v7 is offline   Reply With Quote
Old 06-18-2012, 02:12 PM   #49
konichiwabeezy
Okay and it won't damage the diff right?
Old 06-18-2012, 02:20 PM   #50
purplove
purplove's Avatar
purplove is an unknown quantity at this point
I'll admit it, I learned the hard way but figured this out on my own.
purplove is offline   Reply With Quote
Old 06-18-2012, 06:12 PM   #51
Agamemnon
Agamemnon's Avatar
You guys realize this is a 4 year old thread right?
Old 06-18-2012, 08:13 PM   #52
TheRealSy90
TheRealSy90's Avatar
So thats why my "framerails" are flat under the seats... Idiots...
Such a good signature.
Old 06-18-2012, 09:41 PM   #53
dawagarage
dawagarage's Avatar
dawagarage is an unknown quantity at this point
here's a diagram of the Z32's jack points & safety stand points for anyone who needs it
formerly known as "hotboiblaze"
ratsun: dawa (73 datsun 620)
clublexus: properD (97 sc300)
dawagarage is offline   Reply With Quote
Old 06-18-2012, 09:43 PM   #54
dawagarage
dawagarage's Avatar
dammit, didnt notice that. oh well, still important knowledge for the newer zilvians
